Home / Technical Articles / Five factors that mess up motor efficiency and how to improve it
Motor efficiency vs Energy losses
It must be emphasised that the standard electric motor is already a very efficient device with efficiencies above 80% over most of the working range, rising to over 90% at full load. However, because of the high energy consumption, and the very large number of installed units, even a small increase in motor efficiency can have a major impact on costs.
5 Factors That Mess Up Motor Efficiency and How To Improve It
5 Factors That Mess Up Motor Efficiency and How To Improve It (on photo: Baldor M2510 Motor; 10 HP; 230/460 V; 27.2 A; 1760 RPM; 60 Hz)
The efficiency of an electric motor depends on the choice of materials used for the core and windings, their physical arrangement and the care and precision with which they are handled and assembled.
Losses can be categorised into two groups. Those that are relatively independent of load (constant losses), and those that increase with load (load dependent losses).
The factors that affect efficiency are:
  1. Conductor content – load dependent
  2. Magnetic steel -mainly constant
  3. Thermal design – mainly load dependent
  4. Aerodynamic design – constant
  5. Manufacture and quality control – constant
1. Conductor Content
Resistive losses in the windings increase with the square of the current (which increases with the load) and normally account for around 35% of the total losses.
These resistive losses can be reduced by putting more copper into the windings – using a thicker gauge wire – and improving manufacturing techniques to shorten the end windings (which do not contribute to output power, but do contribute to loss).
Since more copper requires more space, both for the end windings and in the stator slots, the volume of material in the magnetic circuit would be reduced, leading to earlier saturation and increased iron losses. Consequently, it is necessary to increase the length of the magnetic core, and sometimes the diameter as well.
Normally, the increased length is accommodated by increasing the overhang at the non-drive end of the unit. Because copper losses are load-dependent, the benefit of increasing the copper content is most apparent at high loading. Since the coefficient of resistance of copper is positive, the losses increase as temperature rises.
Loss against load for a typical standard motor
Figure 1 – Loss against load for a typical standard motor
Go back to Motor Efficiency Factors ↑
2. Magnetic steel
Magnetic steel is the most expensive component of the motor, so any increase in the total amount used is undesirable on cost grounds. The iron losses are of two types – hysteresis loss and eddy current loss.
Hysteresis loss is due to the non-linearity of the flux density/magnetising force curve and is a property of the steel itself and to minimise it two properties are required – a low energy loss and good high field permeability, i.e. the steel must be easy to magnetise and must not saturate at high flux densities of up to 1.8 Tesla.
This is the subject of on-going research that is making promising progress. Eddy-current losses are due to induced current in the stator laminations and are reduced by reducing the thickness of the laminations and by ensuring good insulation between adjacent laminations.
Figure 2 - Magnetization and hysteresis curves
Figure 2 – Magnetization and hysteresis curves
Thinner laminations are, naturally much more expensive to produce and more difficult to handle, so the chosen thickness is always a compromise. Magnetic losses are particularly important when the supply is distorted by harmonics because eddy current losses increase with the square of the frequency while hysteresis losses are proportional to frequency.
The benefit of using improved magnetic steel is a reduction in loss across the whole of the working range, but, because it is not load dependent, it is particularly apparent at low loadings.
3. Thermal design
New modelling techniques have allowed the production of motors with optimised cooling flow, reduced clearances (increasing the efficiency of the magnetic circuit) and lower copper losses. Lower losses and good thermal design result in lower operating temperatures and hence a longer service life.
Reliance high efficiency explosion-proof motor by Baldor Electric Company
Figure 3 – Reliance high efficiency explosion-proof motor by Baldor Electric Company (photo credit: feedandgrain.com)
4. Aerodynamics
Most electric motors are cooled by drawing air through the windings by an integral fan and exhausting it over the externally ribbed casing. The airflow is complex and computer modeling has been used to optimize the design of the fan and cowling to produce more efficient cooling with a lower noise level.
Windage losses can be reduced by careful design of the rotor.
The introduction of stresses in the magnetic steel during motor assembly can increase iron loss by up to 50%. By considering assembly techniques at the design stage and by paying attention to handling techniques, this increase in iron loss during manufacture has been reduced to negligible proportions. Eccentricity between the stator and rotor generates harmonic fluxes with consequently higher losses.
The overall result of these improvements is an increase in efficiency of 3% (corresponding to a reduction in loss of about 30%) at full load and a halving of losses at low loads. Figure 4 shows the comparison between the efficiency of 75 kW standard and high efficiency motors against actual load.
Comparison of efficiencies of standard and high-efficiency motors
Figure 4 – Comparison of efficiencies of standard and high efficiency motors
Because many motors spend considerable time running at low loading or idling, designers of high efficiency units have paid great attention to reduction of the constant losses.
The result is a halving of losses at loadings less than 25% load and an efficiency improvement of 3 to 5% at full load, a reduction in losses of about 28%. This represents an impressive achievement.
Reference // A Good Practice Guide to Electrical Design – Copper Development Association
15 Comments
  1. Gaviola Irish Joy
    Sep 12, 2022
    It was a very amazing to know that how to prevent losses and improved energy efficiency, I hope it will continue to improve!
  2. Paul Kowal
    Aug 22, 2020
    Another method of increasing conductor content is by using a rectangular or square condctor instead of round. In 2000, Denso introduced an alternator using a rectangular conductor for its stator coil. This design features a square-wire stator, offering increased winding density for more output in a smaller size. By raising the winding density (space factor) from 45 percent to 70 percent, DENSO made this alternator 20 percent lighter and increased the output 50 percent higher than a conventional type.
  3. Mayank P Shah
    Dec 21, 2019
    can we run induction motor of 380 Volts 50 Hz on 415 Volts 50 Hz supply.What is the effect on motor performance like speed,torque,power etc
  4. I A KHAN
    Aug 08, 2019
    Can any body calculate the saving of power from higher rating to lower rating ,
    I have started movement to reduce the power saving and seen some motor running higher capacity motor irrespective to load as example
    On motor rating 75 kw, FL-130A SIEMENS MAKE is running on 55 amp at voltage 410 v ac 50 hz , If I replace the same motor with 37 kw rating at same scenario. How much power we shall be save
    PL REPLY
    I A khan
  5. I A KHAN
    Aug 08, 2019
    WHAT WAS PARAMETER IS REQUIRED TO IMPROVED THE EFFICIENCY OF MOTOR BESIDE THIS ANOTHER QUESTION FOR MOTOR TO CONVERT THE DELTA TO STAR
    EFIIFCIENCY MATTER
    Related question the following scenario in our plant
    1- Is un balance voltage at motor terminal –like R –Y phase 405 v ,B-R-420,B-Y 412V ,50HZ
    2- Cooling system
    3- Alignment
    4- Speed
    As per your opinion what was the standard parameter required for get the better efficiency beside this or as per your view .
    Delta connection to star connection
    We have 250kw,960, rpm motor running load 50 kw, PF 0.27 system voltage -410 vand current 172 AMP in star-delta connection . if shall converted motor connection converted in star same PF 0.95 ,Load 50 kw amp -102A
    Can you calculate the saving is it possible or not along with advantage and disadvantage
    I A khan
  6. VASANT N KALE
    Sep 21, 2018
    VERY INFORMATIVE ARTICLE
    I HAVE SOME QUERY
    1] AS STATED IN ARTICLE ” STEEL CORE IS MOST EXPENSIVE PART IN MOTOR THAN COPPER”
    PLEASE EXPLAIN
    2] WHAT IS OPTIMUM COST EFFECTIVE RATIO COPPER & IRON CORE
    3] IS THERE THUMB RULE FOR CALCULATING COPPER REQUIREMENT FOR HP/NOS OF POLES
    SQUIRREL CAGE 415/440 V THREE PHASE 50HZ MOTOR
    RGDS
  7. FERNANDO UGARTE
    Sep 20, 2018
    EXCELENTE APORTE ME INTERESA MUCHO ESTE TEMA, PARTICULARMENTE ESTOY TRABAJANDO CON REDUCCIÓN Y MEJORAMIENTO DE LA EFICIENCIA DE UN PROCESO EN GLOBAL Y PARTE IMPORTANTE DE ELLO SON LOS MOTORES ELÉCTRICOS Y SUS FACTORES DE POTENCIA Y PERDIDAS INTERNAS PROPIAS. GRACIAS POR EL APORTE
  8. yiga francis xavie
    May 09, 2018
    what brings about the difference in total energy measured on sub meters and that of the main meter.
    could it be that i need to change the sub meters? because the difference is too high to take it be normal energy losses
  9. Lee
    Jan 20, 2017
    The power triangle (Heineken)…nice!
  10. john carlo
    Feb 01, 2016
    i think beer symbolizes the REAL POWER, REACTIVE POWER ,& APPARENT POWER.hehe. that’s my opinion
  11. Don - PLC Programming
    Dec 26, 2015
    Well, Ed, I am the opposite of Deon. I too was curious because of the beer bottle, and would not have clicked through to article if it was not for wondering what the beer bottle had to do with it. I think it was a clever marketing ploy for the article, be intentional or non-intentional. :)
      Hehe, Don, you’re damn right :) I tought I overextend with the meaning of the word ‘Mess’ with a beer on pic, but yes, it’s a kind of marketing trick to attract readers. I’m bringing it back :)
      Thanks for the comment!
  12. Deon
    Dec 23, 2015
    Hi, I do not see any reason for the beer bottle next to the motor in the article. My personal view is that it distract the attention from the good article.
    Cheers
    D
      Well Deon, I stopped and thought about what you just said, and decided to change the image. You were right, it’s a kind of inappropriate, thank you.
Leave a Reply to FERNANDO UGARTE
eighty three  +    =  eighty four
