Home / Technical Articles / 7 Most Common Motor Enclosure Types Defined By NEMA Standards
Important role of enclosure
The enclosure of the motor must protect the windings, bearings, and other mechanical parts from moisture, chemicals, mechanical damage and abrasion from grit. NEMA standards MG1-1.25 through 1.27 define more than 20 types of enclosures under the categories of open machines, totally enclosed machines, and machines with encapsulated or sealed windings.
7 Most Common Motor Enclosure Types Defined By NEMA Standards (on photo: Louis Allis Pacemaker Premium NEMA motor – louisallis.com)
The 7 most common types of enclosures are:
1. Open Drip Proof (ODP)
Premium Efficient Super-E motor with Open Drip Proof (ODP) construction by BALDOR
Allows air to circulate through the windings for cooling, but prevent drops of liquid from falling into motor within a 15 degree angle from vertical. Typically used for indoor applications in relatively clean, dry locations.
2. Totally Enclosed Fan Cooled (TEFC)
Weg NEMA Premium Efficiency - Three Phase TEFC Motors
Weg NEMA Premium Efficiency – Three Phase TEFC Motors
Prevents the free exchange of air between the inside and outside of the frame, but does not make the frame completely air tight. A fan is attached to the shaft and pushes air over the frame during its operation to help in the cooling process.
The ribbed frame is designed to increase the surface area for cooling purposes.
The TEFC style enclosure is the most versatile of all. It is used on pumps, fans, compressors, general industrial belt drive and direct connected equipment.
Total Enclosed Fan Cooled vs Open Drip Proof (TEFC vs ODP)
3. Totally Enclosed Non-Ventilated (TENV)
DAYTON DC Motor, PM, TENV, 1/3 HP, 1800 rpm, 24VDC
Similar to a TEFC, but has no cooling fan and relies on convention for cooling. No vent openings, tightly enclosed to prevent the free exchange of air, but not airtight.
These are suitable for uses which are exposed to dirt or dampness, but not very moist or hazardous (explosive) locations.
4. Totally Enclosed Air Over (TEAO)
US Motors - Refrigeration Duty TEAO Motor, 1/2 HP, 3-Phase, 1140 RPM Motor
US Motors – Refrigeration Duty TEAO Motor, 1/2 HP, 3-Phase, 1140 RPM Motor
Dust-tight fan and blower duty motors designed for shaft mounted fans or belt driven fans. The motor must be mounted within the airflow of the fan.
5. Totally Enclosed Wash down (TEWD)
Baldor's Washdown Duty Motor
Baldor’s Washdown Duty Motor for food processing, packaging, pharmaceuticals, or applications where motors are regularly exposed to high pressure wash down.
Designed to withstand high pressure wash-downs or other high humidity or wet environments. Available on TEAO, TEFC and ENV enclosures totally enclosed, hostile and severe environment motors:
Designed for use in extremely moist or chemical environments, but not for hazardous locations.
6. Explosion-proof enclosures (EXPL)
SIEMENS's explosion proof motor for hazardous environments
SIEMENS’s explosion proof motor for hazardous environments, such as in chemical plants, the oil industry, in gas works, in wood and plastic processing industry or in agriculture.
The explosion proof motor is a totally enclosed machine and is designed to withstand an explosion of specified gas or vapor inside the motor casing and prevent the ignition outside the motor by sparks, flashing or explosion.
These motors are designed for specific hazardous purposes, such as atmospheres containing gases or hazardous dusts. For safe operation, the maximum motor operating temperature must be below the ignition temperature of surrounding gases or vapors.
Explosion proof motors are designed, manufactured and tested under the rigid requirements of the Underwriters Laboratories.
7. Hazardous Location (HAZ)
Motor 3-Phase, 5 HP - to Power Fans, Blowers, Pumps or Air Compressors in Areas That Meet the National Electrical Code for Hazardous Locations
Motor 3-Phase, 5 HP – to Power Fans, Blowers, Pumps or Air Compressors in Areas That Meet the National Electrical Code for Hazardous Locations
Hazardous location motor applications are classified by the type of hazardous environment present, the characteristics of the specific material creating the hazard, the probability of exposure to the environment, and the maximum temperature level that is considered safe for the substance creating the hazard.
The format used to define this information is a class, group, division and temperature code structure as defined by the National Electric Code (NFPA-70).
The following hazardous locations are defined:
1) CLASS I
  • Group A: Acetylene
  • Group B: Butadiene, ethylene oxide, hydrogen, propylene oxide, manufactured gases containing more than 30ydrogen by volume.
  • Group C: Acetaldehyde, cyclopropane, diethyl ether, ethylene.
  • Group D: Acetone, acrylonitrile, ammonia, benzene, butane, ethanol, ethylene dichloride, gasoline, hexane, isoprene, methane (natural gas), methanol, naphtha, propane, propylene, styrene, toluene, vinyl acetate, vinyl chloride, xylene.
2) CLASS II
  • Group E: Aluminum, magnesium, and other metal dusts withsimilar characteristics.
  • Group F: Carbon black, coke or coaldust.
  • Group G: Flour, starch orgrain dust.
3) CLASS III
  • Easily ignitable fibers,such asrayon, cotton, sisal, hemp, cocoa fiber, oakum, excelsior and other materials of similar nature.
The NEMA enclosure description is similar to the IEC Index of Protection (IP) code. The NEMA designations are more descriptive and general, whereas the IEC IP codes are more precise and narrowly defined by a 2-digit code, with the first digit defining how well protected the motor is from solid objects and the second digit describing how well protected the motor is from moisture.
For example, a NEMA “OpenDrip Proof (ODP)” motor corresponds to an IP22 and a NEMA “Totally Enclosed” motor corresponds to an IP54, a NEMA “WeatherProof” motor to an IP45, and a NEMA “Wash-Down” motor toan IP55.
Reference: Understanding Motor Nameplate Information: NEMA vs. IEC Standards – Continuing Education and Development, Inc.
20 Comments
  1. Craig
    May 02, 2022
    I feel it varies with the Manufacturer. Some will clearly define it as an XPFC = Explosion Proof Fan Cooled, while others may include just the Class and Division and leave the Enclosure type TEFC. As for the modifications, it will specifically depend on the Hazard Classification of the area it is intended to be used. It is critical to safety that a proper study of the area be completed by qualified personnel, and not some average know it all (like me).
  2. John DeLacy
    Mar 08, 2022
    Is it unusual for an Explosion Proof motor to also carry a TEFC rating? What mods are required for such motors to be considered TEFC/Explosion Proof?
two  +  4  =
