CYBER WEEK OFFER 💥 Save 20% on PRO Membership Plan and Video Courses with the coupon CYM23 and learn from experienced engineers.
Home / Technical Articles / 7 Most Common Motor Enclosure Types Defined By NEMA Standards
Important role of enclosure
The enclosure of the motor must protect the windings, bearings, and other mechanical parts from moisture, chemicals, mechanical damage and abrasion from grit. NEMA standards MG1-1.25 through 1.27 define more than 20 types of enclosures under the categories of open machines, totally enclosed machines, and machines with encapsulated or sealed windings.
7 Most Common Motor Enclosure Types Defined By NEMA Standards (on photo: Louis Allis Pacemaker Premium NEMA motor – louisallis.com)
The 7 most common types of enclosures are:
1. Open Drip Proof (ODP)
Premium Efficient Super-E motor with Open Drip Proof (ODP) construction by BALDOR
Allows air to circulate through the windings for cooling, but prevent drops of liquid from falling into motor within a 15 degree angle from vertical. Typically used for indoor applications in relatively clean, dry locations.
2. Totally Enclosed Fan Cooled (TEFC)
Weg NEMA Premium Efficiency - Three Phase TEFC Motors
Weg NEMA Premium Efficiency – Three Phase TEFC Motors
Prevents the free exchange of air between the inside and outside of the frame, but does not make the frame completely air tight. A fan is attached to the shaft and pushes air over the frame during its operation to help in the cooling process.
The ribbed frame is designed to increase the surface area for cooling purposes.
The TEFC style enclosure is the most versatile of all. It is used on pumps, fans, compressors, general industrial belt drive and direct connected equipment.
Total Enclosed Fan Cooled vs Open Drip Proof (TEFC vs ODP)
3. Totally Enclosed Non-Ventilated (TENV)
DAYTON DC Motor, PM, TENV, 1/3 HP, 1800 rpm, 24VDC
Similar to a TEFC, but has no cooling fan and relies on convention for cooling. No vent openings, tightly enclosed to prevent the free exchange of air, but not airtight.
These are suitable for uses which are exposed to dirt or dampness, but not very moist or hazardous (explosive) locations.
4. Totally Enclosed Air Over (TEAO)
US Motors - Refrigeration Duty TEAO Motor, 1/2 HP, 3-Phase, 1140 RPM Motor
US Motors – Refrigeration Duty TEAO Motor, 1/2 HP, 3-Phase, 1140 RPM Motor
Dust-tight fan and blower duty motors designed for shaft mounted fans or belt driven fans. The motor must be mounted within the airflow of the fan.
5. Totally Enclosed Wash down (TEWD)
Baldor's Washdown Duty Motor
Baldor’s Washdown Duty Motor for food processing, packaging, pharmaceuticals, or applications where motors are regularly exposed to high pressure wash down.
Designed to withstand high pressure wash-downs or other high humidity or wet environments. Available on TEAO, TEFC and ENV enclosures totally enclosed, hostile and severe environment motors:
Designed for use in extremely moist or chemical environments, but not for hazardous locations.
6. Explosion-proof enclosures (EXPL)
SIEMENS's explosion proof motor for hazardous environments
SIEMENS’s explosion proof motor for hazardous environments, such as in chemical plants, the oil industry, in gas works, in wood and plastic processing industry or in agriculture.
The explosion proof motor is a totally enclosed machine and is designed to withstand an explosion of specified gas or vapor inside the motor casing and prevent the ignition outside the motor by sparks, flashing or explosion.
These motors are designed for specific hazardous purposes, such as atmospheres containing gases or hazardous dusts. For safe operation, the maximum motor operating temperature must be below the ignition temperature of surrounding gases or vapors.
Explosion proof motors are designed, manufactured and tested under the rigid requirements of the Underwriters Laboratories.
7. Hazardous Location (HAZ)
Motor 3-Phase, 5 HP - to Power Fans, Blowers, Pumps or Air Compressors in Areas That Meet the National Electrical Code for Hazardous Locations
Motor 3-Phase, 5 HP – to Power Fans, Blowers, Pumps or Air Compressors in Areas That Meet the National Electrical Code for Hazardous Locations
Hazardous location motor applications are classified by the type of hazardous environment present, the characteristics of the specific material creating the hazard, the probability of exposure to the environment, and the maximum temperature level that is considered safe for the substance creating the hazard.
The format used to define this information is a class, group, division and temperature code structure as defined by the National Electric Code (NFPA-70).
The following hazardous locations are defined:
1) CLASS I
  • Group A: Acetylene
  • Group B: Butadiene, ethylene oxide, hydrogen, propylene oxide, manufactured gases containing more than 30ydrogen by volume.
  • Group C: Acetaldehyde, cyclopropane, diethyl ether, ethylene.
  • Group D: Acetone, acrylonitrile, ammonia, benzene, butane, ethanol, ethylene dichloride, gasoline, hexane, isoprene, methane (natural gas), methanol, naphtha, propane, propylene, styrene, toluene, vinyl acetate, vinyl chloride, xylene.
2) CLASS II
  • Group E: Aluminum, magnesium, and other metal dusts withsimilar characteristics.
  • Group F: Carbon black, coke or coaldust.
  • Group G: Flour, starch orgrain dust.
3) CLASS III
  • Easily ignitable fibers,such asrayon, cotton, sisal, hemp, cocoa fiber, oakum, excelsior and other materials of similar nature.
The NEMA enclosure description is similar to the IEC Index of Protection (IP) code. The NEMA designations are more descriptive and general, whereas the IEC IP codes are more precise and narrowly defined by a 2-digit code, with the first digit defining how well protected the motor is from solid objects and the second digit describing how well protected the motor is from moisture.
For example, a NEMA “OpenDrip Proof (ODP)” motor corresponds to an IP22 and a NEMA “Totally Enclosed” motor corresponds to an IP54, a NEMA “WeatherProof” motor to an IP45, and a NEMA “Wash-Down” motor toan IP55.
Reference: Understanding Motor Nameplate Information: NEMA vs. IEC Standards – Continuing Education and Development, Inc.
21 Comments
  1. Azhar Ameen
    Dec 22, 2022
    Dear Sir could I have your EMAIL ADDRESS?
    THANKS
  2. Craig
    May 02, 2022
    I feel it varies with the Manufacturer. Some will clearly define it as an XPFC = Explosion Proof Fan Cooled, while others may include just the Class and Division and leave the Enclosure type TEFC. As for the modifications, it will specifically depend on the Hazard Classification of the area it is intended to be used. It is critical to safety that a proper study of the area be completed by qualified personnel, and not some average know it all (like me).
  3. John DeLacy
    Mar 08, 2022
    Is it unusual for an Explosion Proof motor to also carry a TEFC rating? What mods are required for such motors to be considered TEFC/Explosion Proof?
  4. Himanshu
    Sep 17, 2020
    which motor will suitable for 250 deg temperature, This is regarding tunnel ventilation system
  5. Mark Hiebert
    Aug 11, 2020
    I am new to building maintenance and have a question about a vertical mounted WEG motor on a circ pump used for a chiller application. It calls for occasional lubrication, however the manual is not specific on how to do this. There are no
    drip caps anywhere or a site glass.
    Does anyone out there have an answer for this?
  6. hazman
    Sep 10, 2019
    TEFC and TEFV motors are same ?
  7. Dan Comeau
    Nov 23, 2017
    I think the image for ODP is showing a TEFC and the TEAO is showing in ODP motor. Something mixed up there. Thanks!
    Dan
    • Rafiq Abdul
      Feb 12, 2018
      Dan,
      I agree with you because the name and definition for TEAO states that enclosure is similar to TEFC but does not have its own cooling fan. But the photo for TEAO clearly exposes the stator coils.
      TEFC (Totally Enclosed Fan Cooled):
      This enclosure type has an external fan which blows air across the motor frame’s external cooling fins. The air inside the motor recirculates and is cooled by heat transfer through the frame.
      TEAO (Totally Enclosed Air Over):
      This enclosure is similar to TEFC but does not have its own cooling fan, rather it sits in an airstream such as in a ventilating duct. Most often, this motor is powering a direct-coupled fan and is mounted right in the air duct that it is blowing air through.
      • Ivor Niggebrugge
        Oct 14, 2020
        After looking at the images, I was curious if anyone else noticed that the pictured motors did not align with the type and description. As pointed out the image under TEAO motor has visible stator windings. The ODP is definitely a TEFC. My experience has been that TEAO motors typically have a fan that is not driven off the shaft of the motor to drive the equipment. My experience is also limited to above NEMA products.
  8. anokye francis
    May 09, 2017
    great work keep it up
  9. Larry Lightman
    Mar 31, 2017
    Hi Edvard, do you know if there are any public domain calculations that can be used in a spreadsheet to calculate core loss?
  10. Paul McCutcheon
    Sep 30, 2016
    Is there also force cooled or force ventilated TEFV
    where there is a dedicated blower to cool the motor
  11. ANANDA MAJUMDAR
    Jan 24, 2016
    Please check the picture of the motor provided as an example for ODP motor – is it ok ?
  12. emeka
    Oct 04, 2015
    I am working on ventilation system of a battery room compartment as research project. what is the type of electric motor do i need for the ventilation fan.
  13. CHANDRAKANT SUTAR
    Sep 25, 2015
    i want to be a member for your news letter, updates, solutions on problems,
  14. mohammed sharief
    Jul 14, 2015
    Dear Sir,
    Can you please provide the material or compete guide of Testing Commissioning, and Installation operational Maintenance of electrical equipment in Industrial and substation plants
  15. Rajesh Chandravanshi
    Jun 27, 2015
    Please send me newsletter regularly
  16. wesonga michael
    Dec 18, 2014
    Loooking forward to sharing electrical engineering
  17. Shaker Ahmed Biplob
    May 29, 2014
    I want to be member in your site, What is the procedure of membership?
  18. Ashok Parikh
    Aug 12, 2013
    Dear Edvard,
    I am unable to download your highly informative articles relevant to induction motors. Can you be of any help.
    Regards,
    Ashok Parikh
      Hi Ashok,
      I’m working on it, I know that there is a problem. printfriendly.com has changed something, and now print in PDF don’t work.
      It will be fixed soon!
Leave a Reply to anokye francis
  ×  one  =  9
