Home / Technical Articles / Basic parameters used in lighting you should know
Luminous flux
Luminous flux
Abbreviation:φphi
Unit:lmlumen
The luminous flux describes the quantity of light emitted by a light source. The luminous efficiency  is the ratio of the luminous  flux to the electrical power consumed (lm/W). It is a measure of a lamp’s  economic efficiency.
Luminous intensity
Luminous intensity
Abbreviation:I
Unit:cdcandela
The luminous intensity describes the quantity of light that is radiated in a particular direction. This is a useful measurement for directive lighting elements such as reflectors. It is represented by the luminous intensity distribution curve (LDC).
Illuminance
Illuminance
Abbreviation:Ephi
Unit:lxlux
Illuminance describes the quantity of luminous flux falling on a surface. It decreases by the square of the distance (inverse square law). Relevant standards specify the required illuminance (e.g. EN 12464 “Lighting of indoor work-places”).
Illuminance:
E(lx) = luminous flux (lm) / area (m2)
Luminance
Luminance
Abbreviation:L
Unit:cd/m2
The luminance is the only basic lighting parameter that  is perceived by the eye. It specifies the brightness of  a surface and is essentially dependent on its reflectance (finish and colour).
SOURCE: Zumtobel Staff – The Lighting Book
  1. Fahad
    Aug 28, 2017
    A really basic and helpful article. Thanks.
  2. Albert simiyu
    May 11, 2015
    explain the technology how the quantity of natural lights controls the quantity of illumination of the building?
  3. tabokhadra
    Sep 25, 2012
    you should add UGR AND GLARE
Leave a Reply to tabokhadra
two  ×    =  six
