Home / Technical Articles / Coal handling plant in a thermal power generating station
Coal Handeling Mine/Plant in a thermal power generating station
Introduction to Coal handling plant
In a coal based thermal power plant, the initial process in the power generation is “Coal Handling”. So in this article i will discuss the overall processes carried out at a Coal Handling plant in a coal based thermal power generating station.
The huge amount of coal is usually supplied through railways. A railway siding line is taken into the power station and the coal is delivered in the storage yard. The coal is unloaded from the point of delivery by means of wagon tippler. It is rack and pinion type. The coal is taken from the unloading site to dead storage by belt conveyors. The belt deliver the coal to 0m level to the pent house and further moves to transfer point 8.
The transfer points are used to transfer coal to the next belt. The belt elevates the coal to breaker house. It consists of a rotary machine, which rotates the coal and separates the light dust from it through the action of gravity and transfer this dust to reject bin house through belt.
The belt further elevates the coal to the transfer point 7 and it reaches the crusher through belt. In the crusher a high-speed 3-phase induction motor is used to crush the coal to a size of 50mm so as to be suitable for milling system. Coal rises from crusher house and reaches the dead storage by passing through transfer point 8.
Stages in coal handeling power plant
Equipment used in a coal handling plant
1. Pull chord switch
A series of such switches are arranged in series at a 1m distance on the side of conveyor belt. The power supply to rotor of the conveyor belt is established only if all switches in series are connected.
2. Vibrating feeder
The coal stored in a huge hub is collected on the belt through vibrations created by the vibrating feeder.
3. Flap gates
These are used to channelize the route of coal through another belt in case the former is broken or unhealthy. The flap gates open let the coal pass and if closed stop its movement.
4. Magnetic separator
these are used to separate the ferrous impurities from the coal.
5. Metal detector
These are detect the presence of any ferrous and non-ferrous metal in the coal and sends a signal to a relay which closes to seize the movement of belt until the metal is removed. It basically consists of a transmitter and a receiver.
The transmitter consists of a high frequency oscillator, which produces a oscillations of 1500 Hz at 15V. The receiver receives this frequency signal. If there is any presence of metal in the coal. Then this frequency is disturbed and a tripping signal is send to relay to stop the conveyor belt.
6. Belt weightier
It is used to keep an account of the tension on the belt carrying coal and is moves accordingly to release tension on the belt.
7. Reclaim hopper
Reclaimation is a process of taking coal from the dead storage for preparation or further feeding to reclaim hoppers. This is accomplished by belt conveyors.
Steam generation from coal
1. Tipplers
Coal from the coal wagons is unloaded in the coal handling plant. This unloading is done by the “Tipplers”. This coal is transported up to the raw coal bunkers with the help of conveyor belts.
2. Crush House
After hand picking foreign material, coal is transported to the Crush house by conveyor belts where it is crushed to small pieces of about 20 mm diameter. The crushed coal is then transported to the store yard. Coal is transported to bowl mills by coal feeders.
3. Bowl Mill
The coal is pulverized in the bowl mill, where it is grounded to a powder form. The mill consists of a round metallic table on which coal particles fall.
This table is rotated with the help of a motor. There are three large steel rollers, which are spaced 120” apart. When there is no coal, these rollers do not rotate but when the coal is fed to the table it packs up between rollers and the table and this forces the rollers to rotate.
Coal is crushed by the crushing actions between the rollers and rotating tables.
4. Furnaces
This crushed coal is taken away to the furnace through coal pipes with the help of hot and cold air mixture from P.A Fan. P.A Fan takes atmospheric air, a part of which is sent to Air pre-heaters for heating while a part goes directly to the mill for temperature control.
Atmospheric air from F.D Fan is heated in the air heaters and sent to the furnace as combustion air.
5. Boiler
Boiler used in the power plant is suspended type. This prevents it from getting deformed, when a subjected to very high temperatures.
The boiler is divided into two cylindrical parts namely the Primary and the Secondary boiler. Water from the boiler feed pump passes through economizer and reaches the boiler drum. Water from the drum passes through down comers and goes to bottom ring header. Water from the ring header is divided to all the four side of furnace.
Due to heat and density difference the water rises up in the water wall tubes.
Water is partly converted to steam as it rises up in the furnace. This steam and water mixture is again taken to the boiler drum where the steam is sent to super heaters for superheating.
The super heaters are located inside the furnace and the steam is superheated (540°C) and finally it goes to turbine. Flue gasses from the furnace are extracted by induced draft fan, which maintains balance draft in the furnaces with forced draft fan. These flue gasses emit their heat energy to various super heaters in the pant house and finally pass through air pre-heaters and goes to electrostatic precipitator where the ash particles are extracted. Electrostatic precipitator consists of metal plates, which are electrically charged.
Ash particles are attracted on to these plates, so that they do not pass through the chimney to pollute the atmosphere.
Regular mechanical hammers blows cause the accumulation of ash to fall to the bottom of the precipitator where the bottom of the precipitator where they are collected in a hopper for disposal. This ash is mixed with water to form slurry and is pumped to ash pond.
Bipul Raman
9 Comments
  1. Sandip Saha
    Jan 01, 2024
    Having Experience of Washeries of more than 7 years and power plant coal handling system of more than 13 years. Presently working as project coordinator and have responsibilities of 04 sites. Looking for a job where I can share my experience and contribution for increasing skills of organization.
  2. Dean John
    Mar 28, 2021
    What is Dome Valve ? | Principle, Features and Valves
    Dome Valve is Used in the Pneumatic Phase Dense Conveying Application. An isolation valve used in many applications where conventional valves like ball valve, butterfly valve and slide gate.
  3. James Slusher
    Oct 13, 2020
    Anyone know what the Average cost per square foot it is to build a coal prep plant? I have an 11 story 1000 Tons per hour Plant that has been idle for a few years and needs to updated – Im trying to figure out what it would cost would be to upgrade it, or tear it down and rebuild it. Would appreciate anyones input for a guess of what the cost per square foot is for building prep plants.
  4. Arun Chhatry
    Jan 25, 2018
    I am general order supplier located at Korba Chhatisgarh and looking after different power plants and i am entrustedin electrical items dealership.
    Please help us
    Arun Chhatry
  5. UMESH PANDEY
    Nov 24, 2015
    NEED A CONTRACTOR FOR COOL HANDLING PLANT.CONSTRUCTION AND COMMISSIONING WITH CIVIL ELECTRICAL AND MECHANICAL WORKS ALONG WITH COMISSIONING AND HANDLE WORKS.
    • Debnath Pahari
      Jan 25, 2021
      Sir, If there is any job for Electrical Operation or Electrical Maintenance, Can you please refer me for any job?? I need a job, I am working in a Coal handling plant in electrical isolation, please do something for me, I will be thankful to you very much.
  6. bhikham sahu
    Jul 05, 2015
    Mai branch instrumentation I need to chp coal information
Leave a Reply to UMESH PANDEY
27  −  twenty three  =
