Home / Technical Articles / Cooling and Ventilation of Electric Motors (IC)
Cooling and ventilation of electric motors (IC)
The surface cooling using flat ribs combined with a defined inner cooling circuit with shaft-mounted fan inside the motor ensure optimum motor utilization.
Electrical and Mechanical Losses
All rotating electrical machines generate heat as a result of the electrical and mechanical losses inside the machine. Losses are high during starting or dynamic braking.
Also, losses usually increase with increased loading. Cooling is necessary to continuously transfer the heat to a cooling medium, such as the air. The different methods of cooling rotating machines are classified in the standards IEC 34.6 and AS 1359.21.
For AC induction motors, cooling air is usually circulated internally and externally by one or more fans mounted on the rotor shaft. To allow for operation of the machine in either direction of rotation, fans are usually of the bi-directional type and made of a strong plastic material, aluminum, or steel.
In addition, the external frames of the motor are usually provided with cooling ribs to increase the surface area for heat radiation.
The most common type of AC motor is the totally enclosed fan cooled (TEFC) motor, which is provided with an external forced cooling fan mounted on the non-drive end (NDE) of the shaft, with cooling ribs running axially along the outer surface of the motor frame.
These are designed to keep the air flow close to the surface of the motor along its entire length, thus improving the cooling and self-cleaning of the ribs. An air-gap is usually left between the ribs and the fan cover for this purpose.
Internally, on smaller TEFC motors, the rotor end-rings are usually constructed with ribs to provide additional agitation of the internal air for even distribution of temperature and to allow the radiation of heat from the end shields and frame.
Special precautions need to be taken when standard TEFC induction motors are used with AC variable speed drives, powered by VVVF converters. For operation at speeds below the rated frequency of 50 Hz, the shaft mounted fan cooling efficiency is lost. For constant torque loads, it is sometimes necessary to install a separately powered forced cooling fan (IC 43) to maintain adequate cooling at low speeds. On the other hand, for prolonged operation at high speeds above 50 Hz, the shaft mounted fan works well but may make excessive noise. Again, it may be advisable to fit a separately powered cooling fan.
Larger rotating machines can have more elaborate cooling systems with heat exchangers.
The system used to describe the method of cooling is currently being changed by IEC, but the designation system currently in use is as follows:
  • A prefix comprising the letters IC (index of cooling)
  • A letter designating the cooling medium, this is omitted if only air is used
  • Two numerals which represent:
    1. The cooling circuit layout
    2. The way in which the power is supplied to the circulation of the cooling fluid, fan, no fan, separate forced ventilation, etc
Figure 1 - Designation of the most common methods of cooling
SOURCE: Practical Variable Speed Drives – Malcolm B.
12 Comments
  1. Mirkomil
    Aug 10, 2023
    this site very useful. thanks
  2. Robert
    Jul 26, 2021
    I have six 3000hp motor that sit inside of (2) buildings. Would like to install a vent system to move the heat out of the building. Do you help design system like this?
  3. Jatt Haji
    Sep 05, 2020
    I’m electrical chargeman, need to ask and suggestion or opinion….
    Motor
    KW: 22
    FLA: 33.9
    SF: 1.25
    Class: F
    Motor always run more from FLA (normally 34.5) OL setting 37.8 (110%) from FLA setting.
    If continue run the amp more than FLA can effected the motor winding insulation and by the end motor grounded (winding insulation burn out)
    please share the answer …you cooperation highly appreciated….
  4. Graham Ison
    Nov 06, 2019
    The reference to AS 1359.21 is to the 1974 code that was superseded in 1996 by 1359.106. That code has since been withdrawn. The IEC 60034.6 is the appropriate reference.
  5. mostafa haghi
    Aug 26, 2019
    I wanted to know how to remove the drive shaft
  6. Dharmesh Chanawala
    Jul 29, 2019
    Hi…
    What is MOC (Material of Construction) of Cooling Fan for Hazardous Area (Zone 1), Anti Static & Anti Corrosive?
  7. MAHI
    May 30, 2018
    what is the impact or influance of changing the cooling fan on non -drive end shaft of an vertical electric motor of 225 kw power with another which is not the same and it make noise?
  8. Atul Verma
    Nov 20, 2015
    What is the impact of additional cover (normally made of GI sheet) on electrical motor???
    Isi ti actually required or just to protect from external environment????
  9. Raghu
    Dec 06, 2014
    Guys I’m a electrical engineer working in a plant, which has both ac and dc motors. I just want to see how many of u can answet this….
    Why even a small ac motor(induction) have ribs on its body for cooling but even the largest of dc motors(we in our plant have upto 1MW DC MOTOR) don’t have ribs for cooling on their body?
    • db
      Jul 02, 2015
      DC machines see a DC field in the gap! The stator mounted magnets do not generate any eddy currents which could generate heat. No other heat generating source in the stator (no windings).
      P.S.
      I am not sure if you asked this because you don’t know ( which is OK to ask ) or, if you trying to sound like a smart ass – in which cases, mission accomplished!
    • Venkatesh shendge
      Apr 10, 2019
      Dear sir,
      I’m not confirm about your question but according to me in case of ac motors there are many losses. Such as due to inductance, reactance. Also the tenancy of ac current is to flow from the surface of the conductor. Which tends to reduction in the cross section of conductor and increase in CU losses. Which in case increases heat and hence ac motors requires more cooling than dc.
      Please sheare your answer.
      Thank you!!!
  10. Julius Were
    Aug 06, 2014
    I like your explanation ,it is short and very vivid
Leave a Reply to Graham Ison
eighty  +    =  ninety
