Home / Technical Articles / What will happen to digital substations once the internet drops dead for good?
The goods & bads of digital substations
Here at EEP, we have already covered multiple aspects of digital substations, ranging from design, upgradations, and whatnot. We may continue writing till eternity and still be left playing catchups with the latest addition to advancements in power systems design and operation. Nevertheless, in this article, our focus shall be on the possible contingencies and turn of events when the coveted connectivity of modern digital substations goes haywire.
Or, how to cope if the internet or ethernet is down in digital substations? Normally, a fully automated digital substation in a power grid is connected to a remote server through the internet over an optical channel.
Remote communication or the internet we know of today is associated with many functionalities in a digital substation, and its disruption is never a desirable situation for substation engineers.
  1. Demarcation of digital substations
  2. Emergence of ethernet and internet in digital substations
  3. What if no ethernet?
  4. Internet in digital substations
    1. Remote supervision and control
    2. Teleprotection
    3. Remote maintenance
  5. Conclusion and frequent queries
    1. Do digital substations fail to operate when the internet is down?
    2. Are digital substations ready for offline or analog operation?
    3. What could engineers do in that situation to maintain the power supply?
    4. Bracing against the internet failure: “Redundancy, contingency plans, and skilled technicians.”
Substation automation, time synchronization, data acquisition, monitoring, and alarming are some of the primary functions either facilitated or enhanced by digital substations, having already existed in different forms and phases. The availability of a modern communication backbone has been instrumental in transforming the way substations are designed and operated.
That is what demarks the operational territory of a digital substation – IEC 68150 compliant communication and interoperability between the process and station level equipment, all channeled through ethernet or optical link.
The primary substation appliances like circuit breakers, power transformers, lightning arrestors, switches, etc. have remained almost the same over the years, irrespective of the communication modes adopted. So, it is fair to say that the concept of digital substations marks its territory starting from the selection of protective equipment (conventional versus IEDs – Intelligent Electronic Devices) and their mode of communication with sensors/ actuators and control centers.
Breach or abnormalities in this territory could trigger a catastrophe in substations.
Figure 1 – A concept diagram of a digital substation
The introduction of microprocessor-based relays in the early 1970s in substations laid the foundation for the current sophisticated version of Substation Automation Systems, aided by first-generation digital serial communication options- RS 232 and RS 485.
Although very capable, they had their limitation in data transfer rate and coverage, which eventually pushed for the inception of ethernet, a more advanced serial data communication standard.
Initial forms of serial communications and respective ports primarily facilitated debugging of equipment and data acquisition. For instance, RS 232 was a suitable option for relaying information to SCADA systems and not for automation systems due to their point-to-point connectivity, low data transfer rate, and transmission coverage.
RS 485 was a clear upgrade over RS 232 due to its fast data transmission rate and differential mode of operation that allows multidrop connections suitable for automation systems.
Still, the substation automation systems were never at full potential until the introduction of ethernet as the ultimate serial communication option for digital substations. Their fast data transfer rate, connection flexibility via cable or fiber, and support for redundant connection topologies made them stand out from the rest.
As the substations now depend on ethernet connectivity more than ever, IEC 61850, an international standard defining communication protocols for intelligent devices at electrical substations, has readily succeeded the MODBUS, DNP3, and IEC 60870-5-103 communication protocols.
Figure 2 – Substation communications diagram
Arguably the most important role of ethernet in a digital substation is the formation of the Process bus, a high-speed Ethernet communication network. Whether it be a replacement of traditional multicore copper cable wiring to switchgear or feeding sampled values from instrument transformers to IEDs, ethernet remains at the helm of them all.
Guided by IEC 61850-9.2, ethernet communication network as process bus has been instrumental in cost reduction, easy maintenance, upgradations, and implementation of fast and reliable substation automation systems in digital substations.
As of now, healthy ethernet connectivity remains a bare minimum requirement for functioning digital substations, and if it is gone or somehow jeopardized, it’s hard to pinpoint remedial options.
There could be multiple ways of strengthening of ethernet network in digital substations to reduce interruptions. One such example is illustrated in the figure below that uses two redundant LAN networks in a star topology. Under normal conditions, the second LAN can be dedicated for engineering access that requires connectivity to the corporate network and internet.
This provision of a separate ethernet network for engineering access makes it easy to shield the network during any possible intrusion through that path.
Bishal Lamichhane
Profile: Bishal Lamichhane
