Introduction to Electric Shock
Electric current passing through the body, particularly alternating current at power frequencies of 50 Hz and 60 Hz, may disrupt the nervous system, causing muscular reaction and the painful sensation of electric shock. The most common reaction is to be thrown off the conductor as a result of the muscular contraction.
However, in a small number of instances, the consequence is death from cardiac arrest, or from ventricular fibrillation (where the heart muscle beats in a spasmodic and irregular fashion) or from respiratory arrest.
An authoritative guide on the topic is published in IEC 60479. The following text concentrates on the most common situation of a shock from a continuous power frequency ac waveform.
The magnitude of the current is the applied voltage divided by the impedance of the body. The overall circuit impedance will comprise the body of the casualty and the other components in the shock circuit, including that of the power source and the interconnecting cables. For this reason, the voltage applied to the body, which is commonly known as the touch voltage, will often be lower than the source voltage.
The impedance of the body is determined by the magnitude of the touch voltage (there being an inverse relationship between impedance and voltage) and other factors, such as the wetness of the skin, the cross-sectional area of contact with the conductors, and whether or not the skin is broken or penetrated by the conductors.
As a general rule of thumb, at an applied voltage of 230 V at 50 Hz, the total body impedance for a hand-to-feet path will be in the range 1000 Ω to 2500 Ω for most of the population, falling to around 750 Ω at voltages in excess of about 1000 V.
The path that the current takes through the body has a significant effect on the impedance. For example, the impedance for a hand-to-chest path is in the order of 50 per cent of the impedance for a hand-to-foot path. Moreover, the current’s path through the body is a significant determinant of the effect on the heart.
Table 16.1 summarizes the physiological effects of current passing through the body.
Electric shock accidents are most common on low-voltage systems and are usually subdivided into two categories of direct contact and indirect contact shocks. A direct contact shock occurs when conductors that are meant to be live, such as bare wires or terminals, are touched. An indirect contact shock occurs when an exposed conductive part that has become live under fault conditions is touched, as depicted in Fig. 16.1.
Examples of an exposed conductive part are the metal casing of a washing machine and the metal casing of switchgear. This type of accident, which requires two faults to occur (the loss of the earth connection followed by a phase-to-earth fault), is quite common.
Physiological Effects
Table 16.1 The effect of passing alternating current (50 Hz) through the body from hand-to-hand
Current (mA) | Physiological effect |
0.5–2 | Threshold of perception |
2–10 | Painful sensation, increasing with current. Muscular contraction may occur, leading to being thrown-off |
10–25 | Threshold of ‘let go’, meaning that gripped electrodes cannot be released once the current is flowing. Cramp-like muscular contractions. May be difficulty in breathing leading to danger of asphyxiation from respiratory muscular contraction |
25–80 | Severe muscular contraction, sometimes severe enough to cause bone dislocation and fracture. Increased likelihood of respiratory failure. Increased blood pressure. Increasing likelihood of ventricular fibrillation (unco-ordinated contractions of the heart muscles so that it ceases to pump effectively). Possible cardiac arrest |
Over 80 | Burns at point of contact and in internal tissues. Death from ventricular fibrillation, cardiac arrest, or other consequential injuries |
First Aid with Emergency Defibrillator
When providing first aid to an electric shock casualty, the first action should be to remove the cause by switching-off the supply or otherwise breaking contact between the casualty and the live conductor. Cardiopulmonary resuscitation may be required.
Where a defibrillator is not immediately available, the first aider should carry out cardiopulmonary resuscitation until either the casualty recovers or professional assistance arrives.
SOURCE: J.M. Madden
Good 😊 work
Nice works
Actually I want to know more about fluorescent fittings
I’m happy that I know about electrical safety
Being working in pharmaceutical industry as Manager from mechanical background from the last 12 years,it had always been my urge to know about electrical and electronics safety and other basics as I am keen to join EHS course.
Ur articles will help me a lot sir
Pls kindly share for IEC standards related to controls voltages which are daily touch and control with our hands.
To Know electricity you have to know safety first. Thanks for this article.
That’s why we all should take care of Electricity :p since sometimes Electrical shock may kill us if we didn’t pay attention for the safety guidelines !
Exactly! We all know what is and what it does, but when it happens… it appears that we actually do not know :)
Hi, I have a question on table 16.1. is the unit for current is mA or A? Because I think if 80mA in Dc isn’t that much, or it will be totally different case in AC?
Thanks.
