Home / Download Center / Electrical Engineering Books and Technical Guides / Alternative (renewable) energy guides / Design of 33kV switchyard (equipment, SLD, and layout) for small hydro-power plant
Main single line diagram
Major considerations for the selection of an economical and suitable main single line diagram and switching scheme for a substation are voltage level, site limitation and general and special considerations.
Voltage level
Power carrying capability of transmission lines increases roughly as the square of the voltage. Accordingly disconnection of higher voltage class equipment from bus bars get increasingly less desirable with increase in voltage levels. High structures are not desirable in earthquake prone areas.
Therefore in order to obtain lower structures and facilitate maintenance it is important to design such substations preferably with not more than two levels of busbars.
Site considerations
Practical site consideration at a particular location e.g. lack of adequate flat area for layout of equipment in the substation may also influence the choice in such locations. Pollution caused by location near to sea or some other contaminated atmosphere may also affect layouts.
At some locations completely indoor substations may be required.
General miscellaneous considerations
Other considerations in the selection of a suitable arrangement and layout are given below:
  1. Repair or maintenance of the equipment should be possible without interruption of power supply.
  2. Expansion of substation should be easily possible.
  3. In seismic prone areas height of structures should be as low as possible.
  4. The outgoing
Switching schemes for switchyards
Main single line diagrams for different schemes which may be considered for designing a substation for SHP up to 25 MW are as follows:
Unit switching schemes
A “unit” scheme providing outdoor switching of the generator and transformer bank as a unit on the high-voltage side only, is shown in Figure 1. The unit scheme is well suited to power systems where loss of large blocks of generation is difficult to tolerate. The loss of a transformer or transmission line in all other arrangements may mean the loss of more than a single generating unit.
Small power systems may not be able to compensate for the loss of multiple units, as could occur using other arrangements. The “unit” scheme makes maintenance outages simpler to arrange.
Unit Generator Transformer Connection
Figure 1 – Unit Generator Transformer Connection
Several generators sharing one transformer
In case of small power stations feeding large power system several generators may share single transformer. See Figure 2.
Generators with Generator Breakers and Sharing a Transformer
Figure 2 – Generators with Generator Breakers and Sharing a Transformer
Switchyard layout
Low level layout of the switchyard of step up station should be provided. Layout of switchyard may be generally designed in accordance with Central Board of irrigation and power manual on SubStation layout for 36 kV and above.
Rural electrification standard be adopted for 12 kV substations. See Figure 3.
12 kV Outdoor Switchyard with Pole Structure
12 kV Outdoor Switchyard with Pole Structure (click to expand)
Transformer Layout
Layout of transformer is discussed as it is the largest piece of equipment in a substation and it is, therefore, important from the point of view of handling and station layout.
In small hydro stations transformer are installed in the switchyard and the bay width is determined by transformer dimensions. Handling of transformer is normally done by the powerhouse crane and for large transformer rails are laid from powerhouse to the site of installation in switchyard.
For this purpose bi-directional rollers are provided on the transformers. Arrangement for removal of transformer in case of repair/maintenance without disturbing other equipment is required and also affects layout. In order to reduce the chances of spread of fire, transformers are provided with a soaking pit of adequate capacity to contain the total quantity of oil.
Sometimes where feasible drainage arrangements are provided to drain the oil away from the transformers in case of fire. Besides, separation wall are provided in between the transformers and also between the transformer and roads within the substation.
Title:Design of 33kV switchyard (equipment, SLD, and layout) for small hydro-power plant – Alternate Hydro Energy Centre, Indian Institute of Technology Roorkee
Pages:107
Suggested Reading – Electrical thumb rules for switching, isolating and earthing
8 Comments
  1. NDIFREKE JACKSON INOKON
    Mar 06, 2026
    I would really appreciate if you can deal more on machines reliability and part of control circuits.
    Currently am a quality control manager with spie energy.
  2. Chisanga
    Feb 19, 2023
    What software do you use for that design?
  3. Fidelis
    Nov 15, 2021
    I’ve been receiving your mails and I can proudly say I love what you’ve dedicated your life to.
    Thanks for being so selfless.
    I am an Electrical Engineering student from Nigeria. I would really be happy if you can make a post on electrical layout design for residential and commercial buildings.
  4. Rashad Abajihad
    Aug 30, 2021
    is very nice one continue as such
  5. rahul kumar
    Aug 09, 2021
    interested
  6. Tesfamichael
    Sep 05, 2020
    Please i want to read the file but i could not download
  7. Malav trivedi
    Jul 24, 2020
    I m mechanical student,but also interested in electrical field.
  8. Kenan
    Jul 23, 2020
    Your essay is very understandable and to the point. Keep emailing
