Home / Download Center / Electrical Engineering Books and Technical Guides / Electrical engineering guides / The basic electrical engineering course for first-year students
Theory & practical implementation
This basic electric engineering course is common to first-year branches of studying. At the end of the course the student is expected to know the fundamental of electrical engineering as well as the practical implementation of fundamental theory concepts.
The basic electrical engineering course for first year students
The basic electrical engineering course for first year students (photo credit: US Coast Guard Academy via Flickr)
Students will learn strong basics of Electrical Engineering and practical implementation of Electrical fundamentals. They’ll also learn different applications of commonly used electrical machinery.
Unit 1 – Basic Laws
Basic Laws: Ohm’s law, Kirchhoff’s voltage and current laws, Nodes-Branches and loops, Series elements and Voltage Division, Parallel elements and Current Division, Star-Delta transformation, Independent sources and Dependent sources, source transformation.
OHM’S LAW: At constant temperature, the current flowing through a conductor is directly proportional to the potential difference(p.d) in volts across the two ends of the given conductor and inversely proportional to the resistance (R) in ohms (Ω) between the ends of the same conductor.
In all practical problems of electrical calculations, it is assumed that the temperature rise is within limits, so that electrical properties such as insulation and conduction properties of the given material are not destroyed. Hende, Ohm’s law is mathematically stated as:
I = V/R or V=R×I or R=V/I
KIRCHOFF’S CURRENT LAW: KCL states that the total current entering a junction is equal to the total current leaving the junction, or
The algebraic sum of the currents at the junction (node) will be zero. At node n, (2 + 3 + 4) = (1 + 6 + 5) Or 2 + 3 + 4 − 1 − 6 − 5 = 0.
KIRCHOFF’S VOLTAGE LAW: KVL is based on the law of the law of conservation of the energy, states that the algebraic sum of voltage drops in a closed loop is zero.
e1 + e2 + e3 = V
e1 + e2 + e3 − V = 0
Flow of currents in loop is assumed +ve from higher potential to lower potential in elements and +ve from lower to higher potential in Sources.
Unit 2 – AC Fundamentals I
AC Fundamentals-I: Reviews of Complex Algebra, Sinusoids, phasors, Phasor Relations of circuit elements, Impedance and admittance, Impedance Combinations, Series and Parallel combination of inductors and capacitors, Mesh analysis and Nodal analysis.
Parallel Connection of Capacitors
Review of Complex Number:
In order to analyze AC circuit, it is necessary to represent multi-dimensional quantities. In order to accomplish this task, scalar numbers were abandoned and complete numbers were used to express the two dimensions of frequency and phase shift at one time.
In mathematics, ‘i’ is used to represent imaginary numbers. In the study of electricity and electronics, j is used to represent imaginary numbers so that there is no confusion with I, which in electronics represents current (i). It is also customary for scientist to write the complex number in the form of + .
Generation of sinusoidal AC voltage
Consider a rectangular coil of N turns placed in a uniform magnetic field as shown in the figure. The coil is rotating in the anticlockwise direction at an uniform angular velocity of ω rad/sec.
When the coil is in the vertical position, the flux linking the coil is zero because the plane of the coil is parallel to the direction of the magnetic field. Hence at this position, the emf induced in the coil is zero. When the coil moves by some angle in the anticlockwise direction, there is a rate of change of flux linking the coil and hence an emf is induced in the coil according to Faradays Law.
When the coil reaches the horizontal position, the flux linking the coil is maximum, and hence the emf induced is also maximum. When the coil further moves in the anticlockwise direction, the emf induced in the coil reduces. Next when the coil comes to the vertical position, the emf induced becomes zero.
After that the same cycle repeats and the emf is induced in the opposite direction. When the coil completes one complete revolution, one cycle of AC voltage is generated.
Unit 3 – AC Fundamentals II
AC Fundamentals-II: RMS and average values, Form factors, Steady state Analysis of series, Parallel and Series Parallel combination of R,L,C with Sinusoidal excitation, Instantaneous power, Real power, Reactive power and Apparent power, concept of Power factor, Frequency.
Unit 4 – Network Theorems and Resonance
Network Theorems and Resonance: Superposition theorem, Thevinin’s theorem, Nortorn’s theorem, Maximum Power Transfer Theorem, Reciprocity theorem, Resonance in Electrical circuits: Analysis of series and parallel Resonance.
Calculate and measure the open circuit voltage using Thevenin theorem
Unit 5 – Fundamentals of Electrical Machines
Fundamentals of Electrical Machines: Construction, Principle, Operation and Application of (i) Single phase Transformer (ii) Single phase Induction motor (iii) DC Motor.
Title:The basic electrical engineering course for first-year students – Gokaraju Rangaraju Institute Of Engineering And Technology
Pages:103
13 Comments
  1. Christine mbanze
    Feb 04, 2026
    It was very easy and simple to understand
    Thanks for breaking it down for us
  2. Abdulai kanu
    Sep 28, 2025
    Looks so educative
  3. tap wangkei
    Nov 16, 2023
    Thank you for the wonderful work you are doing, I am an up coming electrician from South Sudan and I would love to continue learning from this institute.
  4. Tayo Samuel Oluwatosin
    Nov 25, 2022
    I’m an Electrical Engineering student from Nigeria.
  5. Yusufu Ayub Kushonga
    Jul 29, 2022
    Good work
  6. Olusaanu Eyimofe Enoch
    Jul 19, 2022
    2(4+5)×-3(4+5)
    8+10×-12-10
    18×-22
    =396
    • hemantshukla19
      Oct 11, 2022
      it should be (-)486
      2(4+5)x -3(4+5)
      2(9)x-3(9)
      18x-27
      -486
  7. Saleh
    May 22, 2022
  8. bamukisa joel
    Oct 19, 2021
    thanks a lot
  9. Maxamed Craxman sh maxamed
    Jul 15, 2021
    My name is mohamed I am for Somalia 🇸🇴 I’m bachelor of information Technology
    I working Electrical engineering at hand workers 😒
  10. tim ramsy
    Nov 12, 2020
    yeah it can
  11. Thusego keitirile
    Nov 03, 2020
    Excellent
  12. Ikenna Agwoye
    Jan 13, 2020
    First of all, I thank you immensely for the great work you’re doing here.
    Please I want to know if you can post an article on comprehensive, modern building services engineering, electrical… from step 1 to handover/commissioning.
    I will also appreciate it if you can give me some book references in same regard.
    Thanks so much again.
