Home / Download Center / Electrical Engineering Books and Technical Guides / Electricity generation, t&d guides / The essentials of high-voltage breakdown and electrical discharges
High-voltage design & technology
This section covers some of the design principles required to successfully design and build high-voltage systems. It also discusses the commercial high-voltage technology required to bring complete ion source systems together.
The fundamental physics of high-voltage breakdown and electrical discharges
The fundamental physics of high-voltage breakdown and electrical discharges (on photo: HV testing and research laboratory; credit: epsteinglobal.com)
Electrodes
Electrode design
Electrodes are used to shape the electric field or as a source/sink for current. Field shaping electrodes are used in accelerating, deflecting and focusing beams. Current source/sink electrodes are used in plasma generation and beam dumps.
Some electrodes such as extraction electrodes can be both field shaping and current sinking.
Electrode design obviously depends on application. For field shaping electrodes, the shape of the electrode is critical. For current source/sink electrodes, the sputtering resistance and current-carrying capability is critical.
If the electrode’s aim is to shape fields while avoiding unwanted discharges, the key to high-voltage electrode design is smoothness, both microscopically and macroscopically. Electrodes should be physically smooth and have gently curving features with large radii.
Using modern finite element techniques, the electric fields produced by electrodes can be accurately calculated. This allows designs to be tested and optimized before manufacture. Extraction and beam acceleration electrodes can be modeled and simulated beams tracked through them.
Corona shields
Corona shields are a type of field shaping electrode used to shield sharp points that would otherwise suffer from corona. The sharp points are usually unavoidable components like bolts or other fixtures and fittings.
A corona shield increases the radius of these points by literally covering them up with rounded electrodes that are electrically connected so they are effectively at the same potential. Other names for corona shields are guard rings and stress rings.
Figure 1 shows two examples of how to shield a point with two different types of corona shield.
Two examples of shielding a point with corona shields
Figure 1 – Two examples of shielding a point with corona shields
Sputtering
Sputtering is where ions bombard electrode surfaces, knocking atoms off the surface. This process causes erosion of the electrode surface. Electrodes in plasmas suffer the most from sputtering.
Sputtering eventually leads to failure of the plasma electrode system. The process also slowly deforms extraction electrodes.
Electrode materials
For cathodes in high-sputter environments, molybdenum or tungsten are often used. For field shaping electrodes, any conductive material can be used, so material choice is application-dependent.
For higher fields, electrodes must be smooth and highly polished to minimize surface irregularities. Polished 316L stainless steel is commonly used for most applications.
For operation at very high field strengths in vacuum >10 MV m−1 d.c., titanium or its alloys give lower spark rates, especially when used as the cathode electrode material.
Titanium–aluminium–molybdenum alloy and pure titanium produce approximately equal spark rates. Titanium–vanadium or titanium–manganese alloys have the lowest spark rates of all.
Title:The essentials of high-voltage breakdown and electrical discharges – D.C. Faircloth at Rutherford Appleton Laboratory, Chilton, UK
Pages:39
  1. omara
    Oct 27, 2018
    The subject is good & useful but some times more details required.
