Home / Download Center / Electrical Engineering Books and Technical Guides / Electricity generation, t&d guides / Placement and rating planning of feeders & transformers for LV/MV distribution networks
Allocation and Sizing of Distribution Transformers and Feeders
Distribution network planning is primarily identified by the allocation and sizing of distribution transformers. The location of transformers directly specifies the length and route of MV and LV feeders. Therefore, location and rating of transformers should be determined along with the length and size of MV and LV feeders.
For this purpose, an optimization procedure is required to minimize the investment cost of transformers and feeders; while, the loss cost is minimized and the system reliability is maximized. The voltage drop and the feeder current as constraints need to be maintained within their standard range.
Distribution system planning is an important issue in power engineering. The term distribution system consists of Low Voltage (LV) and Medium Voltage (MV) networks.
Planning of LV network is to find the placement and rating of distribution transformers and LV feeders. This is implemented to minimize the investment cost of these devices along with the line loss.
Planning of MV network is to identify the location and size of distribution substations and MV feeders. The objective of MV network planning is to minimize the investment cost along with the line loss and reliability indices such as SAIDI (System Average Interruption Duration Index) and SAIFI (System Average Interruption Frequency Index).
Typical distribution transformer service area (LV zone)
There are several limitations which should be satisfied during the planning procedure.
The bus voltage as a constraint should be maintained within a standard range. The actual feeder current should be less than the rated current of the feeder. Improving the voltage profile, line loss and system reliability is a main concern planning of distribution networks particularly for semi-urban and rural areas.
Supporting the load growth and peak load level is another factor which should be considered in the planning procedure.
The voltage drop and line loss are two factors which should be considered in the planning procedure. Various approaches can be performed to keep the bus voltage within a standard range and minimize the line loss. Finding the optimal voltage level is a choice for alleviating the voltage drop. However, it is commonly determined using the voltage level of the distribution networks located close to the planning area.
Installing capacitors is another way which highly increases the voltage level and reduces the line loss. The Voltage Regulators (VRs) are also common elements for covering these problems.
Typical distribution transformer service area (MV zone)
Reliability is another issue in planning of distribution networks. Long length of distribution lines increases the probability of occurrence of a failure in distribution lines which leads to a low system reliability. Installation of Cross-Connections (CC) is a useful way to lighten this difficulty.
Injecting the active and reactive powers, Distributed Generators (DG) decrease the reliability indices and improve the voltage profile. However, their high investment cost prevents the power engineers from wide use of these devices.
In practical distribution networks, the loads are growing gradually. Additionally, the load level is changing during a period. Conventionally, transformers and feeders need to be upgraded to support the load growth and peak load level. However, upgrading the transformer and feeder rating for peak load level, which is 1-2% of a year, may not be cost benefit.
That is why other supporters such as capacitors and DGs can be installed to avoid extra upgrades of transformers and feeders.
Regarding the discrete and nonlinear nature of the allocation and sizing problem, the resulting objective function has a number of local minima. This underlines the importance of selecting a proper optimization method.
Optimization methods are categorized into two main groups:
  1. Analytical-based methods and
  2. Heuristic-based methods.
The analytical methods have low computation time, but they do not deal appropriately with the local minima. For solving the local minima issue, the heuristic methods are extensively applied in the literature.
In this research, both analytical and heuristic methods will be implemented in Matlab, Discrete Nonlinear Programming (DNLP) as an analytical approach and Discrete Particle Swarm Optimization (DPSO) as a heuristic approach.
Title:Placement and rating planning of feeders & transformers for LV/MV distribution networks (Thesis) – Iman Ziari at School of Engineering Systems; Faculty of Built Environment and Engineering; Queensland University of Technology; Queensland, Australia
Pages:207
Futrther Study – Load flow analysis of 138/69 kV substation using ETAP (Electrical Transient & Analysis Program)
9 Comments
  1. Capt. Waris Shaheen
    Feb 21, 2023
    It involves cumbersome & lengthy procedure for transferring fee.
    Shall appreciate if membership condition is waived off for old engineers.
    Best regards
  2. Martín Martínez
    Oct 01, 2022
    I woul like t leave my modest coment
    I estimate that it is not convenient to install a transformer in the same room with MV switchgear equipment since is possible (no necessarily but probable) that transformer may catch fire in a fail. at least I think there should be a simple wall or better fire wall bettween the transformer and MV switchgear equipment. please see the firts photograf in thos article.
    Thanks for leavin me this commnet
  3. Moses Afenyo Dordzi Dzotefe
    Jun 09, 2020
    I’m looking for job I’m ELECTRICAL DESIGN ENGINEERING can I get job in your company sir
  4. PURSHOTAM Kumar Sharma
    Sep 05, 2019
    Very good/useful article for those people who are working in electrical distribution network.
  5. Tapan Kumar Das
    Sep 05, 2019
    Enjoyed by reading the article. Very useful for people working in distribution network.
  6. Prakash Das
    Sep 05, 2019
    How to apply job
  7. Yash Singh
    Sep 04, 2019
    Your article really helps me to keep track of the latest development in electrical technology
  8. Irshad Ali
    Sep 04, 2019
    Superhero engineer. A lot of things want to search from gaining more knowledge such that learning is as practical in all time during studying
  9. Sean Niktabe
    Sep 04, 2019
    I enjoy reading your articles. They keeps me well informed.
