For power system engineers
The primary objective of a modern electric power system is to meet energy demands cost-effectively without ever compromising safety. For power system engineers, ensuring absolute reliability and continuous operation is a constant priority. Robust protection systems and highly effective maintenance protocols are the foundational elements required to achieve these goals.
Substation Protection and Maintenance Handbook
This handbook is designed to build both a qualitative and quantitative understanding of the protection and maintenance techniques utilized in grid substations. Across 12 chapters and 8 appendices, it provides a comprehensive guide to the working principles, construction details, performance metrics, and practical applications of essential electrical equipment.
Structure and Overview
Chapter 1: Power Systems Overview A foundational introduction to modern power systems.
Chapters 2–4: Core Substation Equipment Detailed coverage of the operating principles, routine maintenance, and testing procedures for power transformers, circuit breakers, and instrument transformers.
Chapters 5–7: Protective Relaying An in-depth look at relay systems, covering fundamental principles (Chapter 5), classifications of various relay types (Chapter 6), and standardized relay testing procedures (Chapter 7).
Chapters 8–11: Practical Relay Applications A guide to applying protective relays within the power system. This section begins with fault level calculations and relay coordination (Chapter 8), followed by specific, applied protection schemes for transformers, transmission lines, and shunt capacitor banks (Chapters 9–11).
Chapter 12: DC Systems An overview of substation batteries and battery charging systems.
Appendices and Supplementary Information
The eight appendices provide valuable quick-reference material for engineers and technicians. This includes standard electrical device numbers and definitions, a comprehensive glossary of relay terminology, transmission line parameters, and cable construction details.
For practical comparison, the appendices also include typical test results for power transformers, circuit breakers, instrument transformers, and various relays.
Title:Substation Protection and Maintenance Handbook – Sajjad Rizvi, Gaurav Sharma
Pages:305
Recommended Study – The Ten Most Dangerous Noises in a Low-Voltage Substation
