Protection Relays
The relay is a well known and widely used component. Applications range from classic panel built control systems to modern interfaces between control microprocessors and their power circuits or any application where reliable galvanic separation is required between different circuits. Altough considered to be a relatively simple component, the electromechanical relay and its technology is complex and often misunderstood.
Relay control and protection guides
History of relay
The earliest electrical relays were developed in the 1830s, as people began to recognize that such switches could be extremely useful. Historically, electrical relays were often made with electromagnets, which continue to be used today, although for some applications solid state relays are preferred. They key difference between electromagnetic and solid state options is that electromagnetic relays have moving parts, and solid state relays do not.
Electromagnets also conserve more energy than their solid state counterparts do.
Usage of relay
One of the reasons an electrical relay is such a popular tool for electricians and engineers is that it can control electrical output which is higher than the electrical input it receives. In the example discussed above, if the ignition connected directly to the battery, heavy duty insulated wiring would be needed to connect the steering column to the battery, and the ignition switch would also need to be much more robust.
By using a relay, relatively lightweight wiring can be used, saving space and increasing vehicle safety.
A variety of circuits can be connected to an electrical relays. Relays can be used as amplifiers for electrical energy, as in the car example, and they can also connect to things like alarm switches, activating when a circuit is broken to trigger an alarm.
Many electrical failsafe systems utilize electrical relays which turn on or off in response to things like a current overload, irregular current, and other issues which may arise. These electrical relays trip to shut the system down until the problem can be addressed.
Besides exploring EEP’s guides and papers in this section, we recommend checking Romero Engineering’s free resources.
Lecture notes in power system protection
Protection is the art or science of continuously monitoring the power system, detecting the presence of a fault and initiating the correct tripping of the circuit breaker. The objectives of… Read more
Jun 22, 2020
41 Comments
  1. ALVIN LUMUMBA
    Jul 07, 2022
    Hello we are a supplying company based in kenya we would like to inquire about some protection relays
  2. Amit
    May 28, 2020
    Electrical relay diagram and p nid symbool book not available pls upload again.. Thanks
  3. ZANE Ilyas
    Sep 17, 2019
    Very interested
  4. Md.Masum Billah
    Sep 15, 2019
    I LIKE THE BOOK
  5. Richard Gayi
    Aug 20, 2019
    Thanks very much for this site. Thank your whole team for putting up this site.
  6. Padmanaban A
    Jan 14, 2019
    Thank you!, sir, your relay protection updating details have very useful for me for relay testing.
  7. Pedro Valverde
    Nov 19, 2018
    Today (11/19/2018) you published an article on protective relays polarity. I would like to download a copy. Thankyou.
  8. dinesh
    Oct 22, 2018
    Dear sir, i would have the guideline document related to scheme preparation of protective lines , transformer , generator etc.
  9. chatha thai
    Aug 15, 2018
    I want to download this file
  10. Syed Zohaib Hassan
    May 10, 2018
    sir pls tell me how differential relay works ?
  11. Satish kumar
    Feb 09, 2018
    I have a crompton greaves drive in a equipment, i am unable to vary its speed from HMI. Also unable to find drive manual.
    Can you help with probable solution
  12. Pedro
    Aug 25, 2017
    Thanks for information
  13. Hassan M. Fallatah
    Aug 05, 2017
    Tahnk you very much for this website and for it’s team
  14. Jawaid Akhound
    Mar 05, 2017
    Sir.
    In India What % of T&D Losses are standardized.
    • Madhav
      Jan 11, 2018
      Hello Jawaid,
      Here is a short reply to your query..
      Here in India 33kV, 22kV and 11kV level is considered as sub-transmission or HV distribution voltage level. Being a vast country distribution network and parameters differ widely from State to State and so does the T&D loss level. The loss level (which includes losses in HV lines and LT lines) in some pockets is around 10% and even less than that. However, it is as high as 30 to 40% in some rural and remote pockets.
  15. yasaamaan
    Sep 15, 2015
    We have two Thyro-A (AEG) in our substaion and both of them flashing on pulse inhibit.
    we checked LED MESSAGES and have been detected that one of Frequency error or SYNC error can be occured, and SYNC error has more probability. If SYNC error be right fault, how can i remove it? Can you help me please?
  16. Dinu
    Aug 25, 2015
    Good work. thanks for the information
  17. Abhishek shukla
    Aug 09, 2015
    10+2 + iti electrician one year exp appertince plz sir my carreyear job requirements ho to sir plz bta na ya my number 9811092589
  18. Kousha CS
    Jul 18, 2015
    I am looking for Protection engineer who know completely about MIcom P 44 series distance Relays any body interested please contact me immediately
    Salary package will be good
    Mobile: 9986101267
    Email: [email protected]
  19. Bipin Shah
    Jun 03, 2015
    I would like to know the reason for equi- potential wires getting disconnected at CT body end from main transformer incomer feeder. Feeder tripped on transformer differential & LV side restricted earth fault protection. Pls Explain…
    • madhusudhna rao
      Aug 22, 2015
      yes it is possible, when ever equipotential ring is disconnected from ct there is a chance of occuring error on measuring of ct, actual current flow on ct and measured current on ct will differ in that situation u get the trip from both differential and ref protection.
  20. Asghar
    May 18, 2015
    please explain can we use measurement CT’s for protection relay ? if not so why ?
    • sunilkumar
      Jul 24, 2015
      because of the ct winding always short suppose it is used for protection it will be open that time huge current flow through the ckt and it will damage the property or human body.
  21. jegatheshwaran
    May 13, 2015
    i had no idea about numerical relay, please tell full detail about that how to make setting,progarmming,configuration and progarmming logic. please sir,
  22. Daniel Zebene
    Apr 11, 2015
    thanks u very much, I am interested for particpate and to became member of this website.
  23. syed aijaz mohiuddin
    Sep 13, 2014
    HI,
    please, can u give me the details of dry type transformer for the maintenance point of view.and also the over -under voltage relay…feeder protection relays..
    thanking you..
  24. iman ramang
    Aug 19, 2014
    As i know for Voltage Drop maximum allowable on VAC is 5%
  25. Moloi
    Jun 12, 2014
    What is the recommended voltage drop in Alternating Current{AC} and Direct current {DC}
  26. hadi218
    Jul 12, 2013
  27. Avinash
    Feb 26, 2013
    can any one share “pilot protective relaying by walter Elmore” or “Numerical Differential Protection by Gerhard Zeigler”
  28. kalkish
    Aug 08, 2012
    Good site..Happy to see that the data are given thro industrial products(GE,Siemens,ABB like)
  29. marg
    Jul 16, 2012
    i want all information about relays.and specially information on ‘numerical relay protection for motor’
  30. bahaa91
    Apr 26, 2012
    Congratulations for this website
    This website is very helpful
    B R I
  31. Bishoy
    Mar 29, 2012
  32. Vinay Kumar
    Feb 07, 2012
    Good Job boss, really inspired especially application enginners like us….
  33. [email protected]
    Jan 11, 2012
    You have done a excellent job. This website is very useful for begineers and even for expert as well.
  34. seanmoo
    Jan 07, 2012
    Just joined after seeing reference on Linkedin and really impressed by the sites contents. Great work.
    Sean
  35. harjit
    Dec 13, 2011
    dear u really did great job ., i just want to know that ,can you provide me some elecrical formules for calculation for relay , like for didtance protection relay , or diff. protection relay
    thnx a lot
      Thank you for kind words Harjit! I wrote down your request, and I’ll try to find something.
      BR
  36. Gilmar
    Oct 28, 2011
    Congratulations for this website .
    Gilmar
    São Paulo -Brazil
      Thank you Gilmar! Me and my team did a great efforts to make EEP to be like it is now.
      BR,
  +  seventy one  =  seventy nine
