Calculate Size Of DOL and Star-Delta Starter Components
Easy way to calculate motor torque, fuse, CB, OL relay and contactor
For both DOL and Star-Delta Starter input fields are:
  1. System Voltage (V)
  2. Phase (1ph/3ph)
  3. Type of Motor (single phase, 3-phase induction, synchronous, wound rotor etc.)
  4. Motor Size (HP or kW)
  5. Motor Code (A, B, C… -H)
  6. Motor Efficiency (%)
  7. Motor RPM
  8. System P.F
  9. Application of Motor (motor load in household application, hermetic refrigerant comperssor motor etc.)
According to above inputs, following starters components are calculated:
Motor Torque / Current
  • Motor Rated Tourque (Full Load)
  • Motor Starting Torque
  • Lock Rotor Current IL (Min)
  • Lock Rotor Current IL (Max)
  • Motor Starting Current
  • Motor Full Load Current (Line)
  • Motor Full Load Current (Phase)
Fuse (As per NEC 430-52)
  • Non-Time Delay Fuse (Max)
  • Time Delay Fuse (Max)
Circuit Breaker (As per NEC 430-52)
  • Instantaneous Trip Circuit Breaker (Max)
  • Inverse Time Circuit Breaker (Max)
Over Load Relay Setting
  • Relay Min (70% of FLC Phase)
  • Relay Max (120% of FLC Phase) or
  • Relay Setting (100% of FLC Line)
Contactor (for DOL starter)
  • Type of Contactor
  • Making / Breaking Capacity of Contactor:
  • Main Contactor (100% of FLC Line):
Contactor (for Star-Delta Starter)
  • Type of Contactor:
  • Main Contactor (58% of FLC Line):
  • Delta Contactor (58% of FLC Line):
  • Star Contactor (33% of FLC Line):
Transient Time Delay Setting (for Star-Delta Starter)
Software:Calculate Size Of DOL and Star-Delta Starter Components
Version:10.6.13
Developer:Jignesh Parmar
Price:Free
Calculate Size Of DOL and Star-Delta Starter Components (Contactor Configuration Sheet)
31 Comments
  1. AMARNATH
    Oct 07, 2021
    thank you, Great
  2. Mahmoud Okasha
    Oct 30, 2020
    Very Good program. but i prefer to put some legend for some definitions such as motor code.
  3. Nk
    Aug 28, 2020
    All files are protected, we cant edit it.
  4. MinCoi
    Nov 15, 2019
    Thanks you!
  5. Dheeraj
    Sep 07, 2019
    Thanks for it 😊 s very help full and very good information
  6. Sylvestr wamango
    Jun 24, 2019
    This is great i have learn alot so far …
  7. afzal
    Feb 19, 2019
    thanks for such a great work sir:)
  8. emmanuel ganalon
    Oct 19, 2018
    good day sir i have 10hp ,230v, 60hz, 3 phase motor drive for fan blower can you give me the exact capacity of magnetic contactor relay, overload relay, breaker, and fuse thank you….
  9. Parveen Kumar
    Mar 07, 2018
    very useful tool —————-thanks
  10. gendhul
    Nov 28, 2017
    very help full
  11. ashok rao
    May 23, 2017
    Helpful
  12. j
    Nov 21, 2016
    This is great !
  13. Hayetom
    Oct 15, 2016
    Help full thank you !
  14. ali alizadeh
    Sep 29, 2016
    Thank You so much it is very helpful
  15. alwyn
    Nov 14, 2015
    Very useful tool………… thanks a lot…………
  16. Viral Zala
    Oct 04, 2015
    Really Very useful tool. Thanks a lot.
  17. daxesh
    Jun 26, 2015
    how to download this excel formet
  18. vikas singh
    Jun 05, 2015
    how we check the rating and size of cable use in system
  19. Roshan Mishra
    Mar 31, 2015
    thx buddy….awesom work hav done.
  20. sunil
    Aug 26, 2014
    I have more information
  21. M.lotfi
    Aug 26, 2014
    it’s better that this calculator do with MATLAB software(GUI)/
  22. M.lotfi
    Aug 26, 2014
    Tnks very much!! that is simply and very usfull!
  23. Glenn George
    Jun 27, 2014
    Please add me to this group.
  24. Mohammed
    May 05, 2014
    Jignesh Parmar——— thank you ——- go ahead
  25. Mubarak kahouli
    Apr 08, 2014
    Thanks. I need to download the software
  26. Mubarak kahouli
    Apr 08, 2014
    Hi
    Tanks a lot.I need your help to download the software, because I cant do it.
  27. Naseem
    Mar 04, 2014
  28. eepower
    Oct 05, 2013
    thank you very much
  29. eng.ibrahim
    Oct 05, 2013
    that’s very good
  30. nileking99
    Aug 24, 2013
    5hanks a lot for the useful tool.
  31. MAHENDRAN R.
    Jul 28, 2013
    Very useful tool for every electrical engineer… special thanks to ” Jignesh Parmar”
  ×  one  =  six
