What does this spreadsheet do?
Program is designed as per ANSI/IEEE 80 Code, it calculates step potential of switchyard, touch potential of switchyard, total length of earthing mat conductor, size of earthing mat conductor and total number of earthing rods.
Input fields As per ANSI/IEEE Std 80-1986 code
- Length of Area Occupied by Earthing Grid
- Width of Area Occupied by Earthing Grid
- Fault level at Incoming Bus
- Incoming Voltage
- Outgoing Voltage
- Soil Resistivity
- Resistance of Main Earthing Mat
- Resistance of surface Material (Crushed Rock )
- Thickness of Surface Material (Crushed Rock)
- Depth of Earthing Grid Conductor
- Diameter of Earthing Grid Conductor
- Reference Depth of Grid
- Spacing between Parallel Conductor of Grid
Software: | Earthing Mat Design For Substation |
Version: | 22.12.2012 ![]() |
Developer: | Jignesh Parmar |
Size: | 46 Kb |
Price: | Free |
Can anyone tell me soil treatment procedure for Single Grounding with reference to Standard…
Please tell me what is the basis of selection of Ambient Temperature-35 Degree.
Are the step & touch voltages calculated for HV substations ? or they should be calculated for LV projects as street lighting poles or LV water pumps projects too ?
It is better if you would show us how these are derived
This portal is very informative. What are the requirement for premium membership?
What is the tolarable value of GPR/EPR for earthing grid calculation?
Sir,
Can u send me the details required to design an earth mat for 33/11 KV PSS
thanks alot
Excellent;
Ellithy
Professor in Power systems
I want to give a seminar on grid Earthing..Can u give me detail info about it?
Sir,
In the design procedure for earthing it is said that as we doubles the length of the rod the resistance will be reduced by 40% and when we increase the size of the electrode the resistance decreases by 10%. i am getting this . with reference to what equation the above mentioned conclusions is reached
