Home / Download Center / Electrical Software and MS Excel Spreadsheets (Calculations of cables, voltage drop etc.) / Power factor correction calculations for power system – MS Excel Spreadsheet
Power factor correction calculations for power system - MS Excel Spreadsheet
Power Factor correction using a static capacitor
Calculation formulas as follows:
  • Q1 =  I losses + Cu losses
  • Q2 = PkW · (Tanφ1 – Tanφ2)
  • I losses = 2% ·  Str
  • Cu losses = USC% · Str
  • Q = Q1 + Q2
  • Q1 = Reactive power to be compensated at the terminals of a transformer due to no load and load losses.
  • Q2 = Reactive power to be compensated due to total reactive components of lighting, power and mechanical loads.
  • Q = Overall reactive power to be compensated to achieve target power factor.
  • I losses = Transformer no load losses = Iron core losses.
  • Cu losses = Transformer load losses = Copper losses.
  • Str = Transformer rating (KVA).
  • P = Maximum demand load on the Main distribution board (kW).
  • φ1 = Inverse cosine of power factor before compensation.
  • φ2 = Inverse cosine of target power factor.
  • Usc% = Short circuit percentage impedance voltage of the transformer.
Power Factor Values assumptions before compensation:
  • For lighting outlets = 0.96
  • For power outlets and receptacles = 0.8
  • For motors = 0.8
Inputs = Transformer size + Transformer type + kVA Max. demand load for the whole system + PF before compensation + Target value of PF.
Outputs = Reactive power to be compensated at the terminals of a transformer due to no load and load losses.
  • Reactive power to be compensated due to total reactive components of lighting, power and mechanical loads
  • Overall reactive power to be compensated to achieve target power factor + circuit breaker size required to protect the capacitor bank.
Software:Power factor correction calculations for power system – MS Excel Spreadsheet
Version:
Developer:Mahmoud Salama
Price:
Download:Here đź”— (Get Premium Membership) | Video Courses | Download Updates
50% Discount đź’Ą - Save 50% on all 90+ video courses with Enterprise Membership plan.
27 Comments
  1. Samir Amin
    Nov 09, 2023
    Thanks for the Great effort.
    Can you please email this excel sheet to me.
  2. khalid Naeim
    Aug 17, 2023
    Thank you very much for your nice effort .
    Please I need excel sheet for Power factor correction and other equipment for substation
    Best wishes.
  3. Peter Aiu Gebaea
    Aug 17, 2023
    This very great. I NEED a copy of that spread sheet. Can you email it to me.
    regards,
    Peter
  4. [email protected]
    Jun 14, 2023
    i need excel sheet of electrical load calculation
  5. ABHINAV
    Apr 15, 2023
    GOOD
  6. Benjamin Tettey
    Jan 31, 2023
    Template very good how do I download?
  7. masauso phiri
    Jan 30, 2023
    How do I download this spreadsheet
  8. Val
    Jan 28, 2023
    Hi, I would highly appreciate if you could share it with me. It will help me with my university.
  9. [email protected]
    Nov 07, 2022
    need it for study
  10. sanati hassan
    Sep 28, 2022
    tnx ur cooperations
  11. Hussien chehab
    Jun 09, 2022
    Hope we can do a schedule for PF correction instead of calculating each type of load separately
  12. chems
    May 10, 2022
    good very nice
  13. Zagi Mefah
    May 25, 2020
    Need training on power factor correction
  14. Naimish
    Feb 17, 2020
    A 1000-KVA transformer is loaded to 850 KVA at a power factor of 0.82
    lag. Calculate the leading kVAR necessary to correct the power factor to 0.95 lag.
    If the transformer has a rated conductor loss equal to 1.0% of the transformer rating,
    calculate the energy saved assuming 24-hour operation at the operating load.
  15. Akram Mufaddal Alfadeel
    Sep 01, 2019
    very nice
  16. Mojtaba Dadashi
    Aug 31, 2019
    hi, I seeking standard that report desirable Power Factor in distribution network.
    is it possible anyone guide me.
  17. md rahmat kamil
    May 17, 2019
    sir request 1kva transformer design and calculation winding bobbin size select
    testing report valve with reference range
    send me sir pdf
  18. Segun Omotosho my
    May 17, 2019
    Good topics,
    Thanks so much.
    thanks so much
  19. Jacques Habimana
    May 17, 2019
    Merci beaucoup pour votre contribution dans le métier
  20. Isaac Asiedu Mensah
    May 16, 2019
    This is helping me to learn more. Infact I’m very happy, please keep it up
  21. Andres Avelar
    May 16, 2019
    LES AGRADEZCO POR LA OPORTUNIDAD QUE NOS DAN EN AMPLIAR NUESTROS CONOCIMIENTOS AL PRESENTAR EXCELENTES ARTĂŤCULOS. FELICIDADES
  22. Jordan Araujo
    Nov 17, 2016
    Thanks for such a great and very useful tools for electrical engineering. This is a great website for our profession.
  23. Hapsari Dewi
    Nov 14, 2016
    Thank You for the article and the excel spreadsheet
  24. SUBODH JHA
    Aug 19, 2014
    THANKS FOR SUCH A GOOD INFORMATION & KNOWLEDGE.
  25. Mahmoud Salama
    Aug 15, 2014
    Many Thanks for publishing this calculation sheet on your reputable site. it gave me much pleasure and confidence to create other sheets to share knowledge and introduce Fast tools.
  26. Abdul Azim Mohammad
    Aug 10, 2014
    Thank you somuch for your various articles on elect engg subsubjects which are extremely helpful for we engineers
  27. Mohammad Aljundi
    Aug 10, 2014
    I just want to express my deep gratitude for all the very useful tools you post here.
twenty seven  +    =  thirty four
