Home / Download Center / Electrical Software and MS Excel Spreadsheets (Calculations of cables, voltage drop etc.) / Selection Of MCCB, ELCB For Main-Branch Circuit (MS Excel Spreadsheet)
Selection of main and branch circuit breakers
Spreadsheet calculates the following:
  • Size and type of main MCCB, RCCB and ELCB for continuous and non-continuous load
  • Sensitivity of MCCB, RCCB and ELCB
  • Size of cable
  • Size and type of sub-circuit MCCB and MCB for continious and non-continious load
  • Total load
  • Main and branch circuit current.
Software:Selection of MCCB, ELCB for main-branch circuit – MS Excel Spreadsheet
Version:22.8.2012 New
Developer:Jignesh Parmar
Price:Free
36 Comments
  1. Chunyu Cao
    Oct 31, 2023
    Thank you for your share
  2. Engr. Biswas Alokesh
    Oct 08, 2023
    Thanks for your Sheets
  3. jose antonio salazar hidalgo
    Nov 21, 2021
    Hello
    I would like to know how the cable selection works because, for example, for a motor load current of 180.4 Amp, and selecting a 2.5 mm2 cable in the drop-down cell, it is indicated that this cable size is OK (green color ) with a maximum length of 8 meters
    it is impossible that this size of cable can support this load
    For all the above, I would like to know if I am misusing this spreadsheet
    Best regards, thank you in advance and I look forward to your response.
  4. Bhargav Solanki
    Aug 02, 2021
    Spreadsheet is not working.Help.
    • Mayank Shukla
      Mar 23, 2022
      Working, full all information for corresponding fields
  5. GAN SAIK NGAI
    Apr 14, 2021
    Dear Sir,
    Your programs are useful unless we can fully understand the actual derivations i.e the formulae in the respective cells. However, most of your formulae in the respective cells are locked with password. Thus, rendered your program ineffective. This is the main reason
    for the many complaints from your readers.
    1. Could you let me know how do I unlock your passwords
    2. If there is any cost involved, please let me know:
    a) The process
    b) The cost
    c) What are my other benefits
    d) What are the eligible duration
    Looking forward to receive your quick response.
    Regards,
    (Mr. Gan Saik Ngai)
  6. Mahesh Bende
    Sep 26, 2020
    Im a Electrical Engineer.I found your site very helpfull and has very useful contents.
  7. PARTHA MUKHERJEE
    Sep 24, 2020
    DEAR SIR,
    CAN YOU PLEASE SUGGEST A BOOK WHEREIN I CAN GET ALL THE IMPORTANT FORMULAE FOR ELECTRICAL ENGINEERING DESIGN CALCULATIONS READY HAND FOR PROJECT ENGINEERING RELATED TO ELECTRICAL SYSTEM DESIGN.
    I AM A BE ELECTRICAL ENGINEER PRESENTLY RETIRED AGED 67 YEARS HAVING PUT UP AN INDUSTRIAL EXPERIENCE IN PROJECTS FOR 38 YEARS.
    THANKS.
    PARTHA
  8. Zarni Thein
    Sep 24, 2020
    Thanks a lot for your sharing.
  9. JOEL SONGANO
    Sep 24, 2020
    Very Nice.
    How to increase the wire size?
  10. Julio Abel Otárola Luna
    Sep 23, 2020
    It is a very good tool for the development of electrical circuits.
    Please send me you application.
    Thanks.
  11. Ayappa Shetty
    Jun 03, 2020
  12. James Khalil
    Oct 02, 2019
    1. You should not include FUR (Future) load when sizing Over Current Protection Device (OCPD) for a specific load. The size of the OCPD should Be to protect the current load, otherwise the OCPD is NOT protected.
    2. the NEC FLA of motor loads are HP driven and not KVA driven. Also the circuit trip amps can be up to 250% of the FLA. see NEC Table 430-250
  13. Debmalya Dasgupta
    Sep 27, 2019
    Hi Jignesh,
    I am working in a project where there are 12 nos. LV (415V) motors fed from MCC located about 1.1kM away from the motors. There are LCS located near the motors.understand from another project that in such long distance cases, when a stop signal is given from LCS, the contactor remains picked up due to the stored energy due to cable capacitance. Kindly advise some mitigation measures in this kind of situation to avoid mal-operation.
    Debmalya
  14. Abdelkawy Almasry
    Sep 26, 2019
    Really its very excellent and good explanation.
  15. biji mathew
    Jul 01, 2018
    useless … the spreadsheet is not working ….
  16. mamad azad
    Mar 26, 2017
    hi.pleaze pass???
  17. Roman Bogdanov
    Dec 29, 2016
    Hi, How I can get a password for datasheets?
  18. Chanh
    Aug 25, 2016
    I don’t understand some symbol in calculator spreadsheet. Would you like to send me a table for these symbol. I hope your reply soon.
    Thanks and best regards.
  19. Dharmendra
    May 21, 2016
    Sir,
    The Selection of MCCB spreadsheet I can not select more than 120 sq mm cable size , so please update this sheet for other size of cable
  20. Ala Sharief
    May 14, 2016
    The excel file shown above is not calculating well for cable selection , i make test for 3 phase load with current 474 A , and i set cable size 10 mm^2 and excel sheet still give that cable design is O.K. ??!!!!
  21. ahmed abozied
    Feb 20, 2016
    pleas how to open XLS file ,iam try do not open
  22. Hor Chin EK
    Oct 14, 2015
    may I have the password?
  23. gaspar
    Aug 25, 2015
    can i have the password plz? ty
  24. jose
    Jul 23, 2015
    tripping amp rating is wrong no decimal point ..
    overall good work..
  25. kishore
    Aug 11, 2014
    Sir, trying to work with the XL, can’t access, it’s pass word protected,
  26. Kelvin Wong
    Jul 21, 2014
    I have downloaded this excel worksheet but I cannot access to it as it is being protected by a password can I have the password so I can start to use this excel work sheet?
  27. NPT Châu
    Jun 04, 2014
    Thank Ad very much!
  28. Abdul Wahid
    Jun 03, 2014
    Thanks alot
  29. sudhir
    Mar 27, 2014
    How to download this file
  30. Patrick Weerasinghe
    Feb 10, 2014
    I down loaded the XL on MCCB selection but could not use as the message comes that it is write protected
  31. henry02
    Oct 14, 2013
    Thanks a lots. Excellent !!!
  32. nmr
    Jun 17, 2013
    For tension free live and Stres free life pl learn Rajayoga-meditation.
    My dear brothers and Sisters, this is God message to all of u,
    Pl see http://www.brahmakumaris.com where God/Shiva Paramata/Our father/ Father of Jesus/Almight authority/Supreme soul is teaching rajayoga (mediation), give real peace, real happy and ever young. Shiva paramata, is going to establish a purity/diety world for us. Co-operate with our father-lord shiva to establish a new diety world for us, for our childrens etc,., Now or Never… no god no peace…. Know god and know peace. Pl do not neglect this message.. Please co-operative with god lord shiva paramata and give u r internet technolozy for establishment of better world tomorrow.
    Thank
    U r well wisher.
    God’s messanger
  33. Edvard
    Nov 27, 2011
    I agree, excellent explanation.
  34. Eagle2011
    Nov 27, 2011
    tnx , they are very useful
7  ×    =  twenty eight
