Home / Download Center / Electrical Software Reviews / Spreadsheet to calculate the size of neutral earthing transformer
Earthing transformer
When the system neutral may not available, earthing transformer may be used to obtain the neutral. The neutral point of transformer to the earth ground network provides a reference point of zero volts.
This spreadsheet calculates the following parameters of a neutral earthing transformer:
  1. Total capacitive charging current (It).
  2. Neutral earthing transformer secondary current.
  3. Required grounding resistor value at primary side (Rp).
  4. Required resistance value at secondary side (Rsec).
  5. Neutral earthing transformer X/R Ratio
  6. Fault current through neutral – single line to ground fault (If)
  7. Rating of neutral earthing transformer (P).
It might be interesting to read technical article about all types of neutral earthing in power distribution: Part 1 and Part 2.
Software:MS Excel Spreadsheet to calculate the size of neutral earthing transformer
Version:
Developer:Jignesh Parmar
Price:Free
25 Comments
  1. Edson Francisco Piloro
    Apr 17, 2020
    Good morning Mr jignesh, i van not download the sheet. Can you send to my e-mail please: edsonfrancisco [email protected]
  2. John Paul Laranja Tagari
    Dec 19, 2019
    sir what is the password to unprotect the workbook?
  3. Frank D. Nouahn
    Oct 05, 2019
    what is maximum amperage rating for 3 phase 100KVA transformer at continue load?
  4. Tahir
    Oct 05, 2019
    Well, i got it. Thanks sir.
  5. James K
    Jan 19, 2018
    am unable to download please send the sheet to [email protected]
  6. Thom James Kajawa
    Jan 18, 2018
    Good day sir
    I have not yet used the spread sheet but is it able to calculate size of grounding wire of 3 phase transformers.
  7. Navaneeth
    Sep 16, 2016
    Neutral to earth voltage is increasing from mV (no load) to 4V when the high pressure pumps are working ( total load reaches to 630 KW ).and the neutral current is 14 amps .Do u have any solution for the above .Using Generator for the source
  8. Edvard
    Feb 22, 2016
    Will be fixed very soon, please be patient… Tnx!
  9. ranko
    Feb 22, 2016
    I am unable to download the sheet.
    Can you kindly send the same to me at my email address
  10. kamlesh shah
    Jan 25, 2016
  11. nitin
    Jan 21, 2016
  12. saugat poudel
    Jul 24, 2015
    Sir, thanks for upload. How do you determine the transformer overloading factors?
    Did you follow any standards? Please reply…
  13. Ugyen Thinley
    Jun 10, 2015
    Can you kindly send the same to me at the following address.
    [email protected]
    with best regards
    ugyen thinley
  14. Ramkumar
    Jul 13, 2014
    how to download, please give idea to download ur spread sheet
  15. Deepak Dubey
    Jul 13, 2014
    Dear Mr. Jignesh.
    [email protected]
    regards
    Deepak
11  −    =  nine
