Content
- Standard: Western Power Company
- Water Safely Clearance on Electrical Fires
- Minimum Approach Distance for Authorized Person
- Minimum Approach Distance for Ordinary Person
- Minimum Approach Distance for Vehicle and Plant for Ordinary Person
. - Standard: New Zealand Electrical Code
- Min. Safe Distance between Buildings and Overhead Line
- Min. Safe Distance for excavation near Overhead Line
- Min. Safe Distance for Tower Carin near Electrical Tower
- Min. Safe Vertical Distance above Railway Track
- Min. Distance between two Conductors on Same Supports
- Min. Distance between two Conductors on Different Supports
- Min. Safety Distance from Electrical Apparatuses
- Min. Approach Distance for Non-Competent Person near exposed Live Parts
- Min. Approach Distance for Competent Person near exposed Live Parts
. - Standard: ETSA Utilities
- Standard: UK Power Networks – EI 02-0019
1. Standard: Western Power Company
Voltage | Minimum distances between a nozzle producing a fog stream of fresh water and a live conductor |
Up to 750 V | 1.5 Meter |
750 V to 15 KV | 4.0 Meter |
15 KV to 230 KV | 5.0 Meter |
This is the minimum distance that must be maintained by a person, vehicle or mobile plant.
Voltage | Distance (minimum) |
Up to 1 KV | 0.7 Meter |
1 V to 6.6 KV | 0.7 Meter |
6.6 KV to 11 KV | 0.7 Meter |
11 KV to 22 KV | 0.7 Meter |
22 KV to 33 KV | 1.0 Meter |
33 KV to 66 KV | 1.0 Meter |
66 KV to 132 KV | 1.2 Meter |
132 KV to 220 KV | 1.8 Meter |
220 KV to 330 KV | 3.0 Meter |
Voltage | Distance (min) |
Up to 1 KV | 3.0 Meter |
1 V to 6.6 KV | 3.0 Meter |
6.6 KV to 11 KV | 3.0 Meter |
11 KV to 22 KV | 3.0 Meter |
22 KV to 33 KV | 3.0 Meter |
33 KV to 66 KV | 3.0 Meter |
66 KV to 132 KV | 3.0 Meter |
132 KV to 220 KV | 4.5 Meter |
220 KV to 330 KV | 6.0 Meter |
Voltage | Distance (min) | |
Mobile Plant | Vehicle | |
Up to 1 KV | 3.0 Meter | 0.6 Meter |
1 V to 6.6 KV | 3.0 Meter | 0.9 Meter |
6.6 KV to 11 KV | 3.0 Meter | 0.9 Meter |
11 KV to 22 KV | 3.0 Meter | 0.9 Meter |
22 KV to 33 KV | 3.0 Meter | 0.9 Meter |
33 KV to 66 KV | 3.0 Meter | 2.1 Meter |
66 KV to 132 KV | 3.0 Meter | 2.1 Meter |
132 KV to 220 KV | 3.0 Meter | 2.9 Meter |
220 KV to 330 KV | 6.0 Meter | 3.4 Meter |
2. Standard: New Zealand Electrical Code
Voltage | Pole | Tower |
11 kV to 33 kV | 2 Meter | 2 Meter |
33 kV to 66 kV | 6 Meter | 6 Meter |
66 kV and Above | 8 Meter | 8 Meter |
Description of Clearance | From Pole (Min) | From Tower (min) |
Excavation in land more than 750mm depth | 8 Meter | 12 Meter |
Excavation in land up to750mm depth | 2.2 to 5 Meter | 6 to12 Meter |
Excavation in land up to 300mm depth | 2.2 Meter | 6 Meter |
Construction near 11KV to 33KV Line | 2.2 Meter | 6 Meter |
Construction near 33KV to 66KV Line | 6 Meter | 9 Meter |
Construction near 66KV and more | 8 Meter | 12 Meter |
Wire Fence near 1KV to 66KV Line | 2.2 Meter | 2.2 Meter |
Wire Fence near 66KV and more | 5 Meter | 5 Meter |
Description of Clearance | Distance (Min) |
Mobile Carin movement | 4.0 Meter |
Tower Carin movement | 4.0 Meter |
Moving Activity above height of Tower | 4.0 Meter |
Hedge Cutter movement | 4.0 Meter |
Earthed conductors | 5.5 Meter |
Stay wires | 5.5 Meter |
Conductors up to 33 kV | 6.5 Meter |
Conductors above 33 kV to 220 kV | 7.5 Meter |
Conductors above 220 kV. | 8 Meter |
High Voltage Circuit | High Voltage Circuit | Distance between circuits (min) |
Up to 33 KV | Up to 1KV | 1.0 Meter |
Up to 33 KV | More than 1KV | 1.2 Meter |
33 KV to 110 KV | Up to 1KV | 1.5 Meter |
33 KV to 110 KV | More than 1KV | 2.0 Meter |
More than 110 KV | All | 2.5 Meter |
High Voltage Circuit | Distance (min) |
Up to 1 KV | 0.6 Meter |
1 KV to 33 KV | 1.2 Meter |
33 KV to 66 KV | 1.8 Meter |
110 KV | 2.4 Meter |
More than 220 KV | 2.8 Meter |
Description of Clearance | Distance (min) |
Passage In front of Metal-Clad Switchgear (UP to HV) | 1.0 Meter wide 2.5 Height |
Passage In rear or side of Metal-Clad Switchgear (UP to HV) | 1.0 Meter wide 2.2 Height |
Passage at any side of Metal-Clad Switch gear containing Bare conductor (UP to HV) | 0.8 Meter wide 2.2 Height |
Below 110 kV | 4.0 Meter |
220 kV and above | 6.0 Meter |
Below 1 kV | 0.5 Meter |
11 kV | 1.5 Meter |
22 kV | 2.0 Meter |
33 kV | 2.5 Meter |
66 kV | 3.0 Meter |
3. Standard: ETSA Utilities
Vertical Clearances between Services
Service | LV Cable | HV Cable |
Common Pipe | 0.100 Meter | 0.100 Meter |
Gas Pipe | 0.200 Meter | 0.200 Meter |
Sewer Pipe | 0.300 Meter | 0.300 Meter |
Water Pipe | 0.600 Meter | 0.600 Meter |
Horizontal Clearances between Services
Sewer Pipe | 1.0 Meter | 1.0 Meter |
4. Standard: UK Power Networks – EI 02-0019
Cable Installation Depths
Voltage | Area | Depth (min) |
Low Voltage | Footways, grass verges or private property | 0.450 Meter |
Carriageways (including road crossings) | 0.600 Meter | |
Normal agricultural land (not deep ploughing) | 1.0 Meter | |
Agricultural land subject to deep ploughing | 1.2 Meter | |
11 KV to 20 KV | Footways, grass verges or private property | 0.600 Meter |
Carriageways (including road crossings) | 0.750 Meter | |
33 KV to 132 KV | Footways, grass verges or private property | 0.9 Meter |
Carriageways (including road crossings) | 0.9 Meter | |
Auxiliary Multi-core & Multi-pair Cables | Footways, grass verges or private property | 0.450 Meter |
On Cable Ladder for LV to HV | The Horizontal clearance between cables on cable ladders | 2X Dia of Cable of Largest Cable or min 150 mm |
The clearance from a supporting wall | 20 mm | |
The vertical clearance between cables is greater | 150 mm | |
If the number of cables > 4, they are to be installed in a horizontal |
Minimum Approach Distance of Crane or Moving Part from Live Conductor
Voltage | Without Safety Observation | For ordinary Person | |
Un insulated portions | Insulated portions | ||
Up to 1KV | 2 Meter | 1.0 Meter | 3.0 Meter |
11 KV | 2 Meter | 1.4 Meter | 3.0 Meter |
22 KV | 2.4 Meter | 2 Meter | 3.0 Meter |
33 KV | 2.4 Meter | 2 Meter | 3.0 Meter |
66 KV | 2.8 Meter | 2 Meter | 3.0 Meter |
132 KV | 3.0 Meter | 3.0 Meter | 3.0 Meter |
220 KV | 4.8 Meter | 4.8 Meter | 6.0 Meter |
330 KV | 6.0 Meter | 6.0 Meter | 6.0 Meter |
500 KV | 8.0 Meter | 8.0 Meter | 8.0 Meter |
Minimum Fixed Clearances for Electrical Apparatus (Isolation Points)
Voltage | Fixed Clearance |
Up to 11Kv | 0.320 Meter |
11KV to 33KV | 0.320 Meter |
33KV to 66KV | 0.630 Meter |
66KV to 132KV | 1.1 Meter |
Need to know minimum approach distance to a MV transformer(11kv,22kv) for ordinary persons,and can a technition touch the transformer body safely.
Greeting…
i am not sure you will advise my enquiry as I saw you not answer any comments .
could you please advise that if there are any article in BS standard mention for the clearance between MV,LV & other utilities as mention here in this informative article.
appreciation your helpful
I am looking for a flat. 66Kv line is just 5 miters away from balcony. is it safe?
no it is not safe ,minimum distanse shoud be 8 meter
It is a great article.
Would you please refer to the standard that you got this information from, in order to be more specific when I negotiate with others.
what is the distance between underground HV(11kv) and LV(415 v) cable
What should be the phase to phase and circuit to circuit distance between 380kV XLPE directly buried 1C cable in flat formation?
Pls, What is the distance of 66 KV – O.H.T.L from tower to another ? Thanks
Excellent article.
Are there any regulations in India governing safe distance for construction activities ? How are they governed.
Good Day,
may send us a quote for tester live line 220/330kv as soon as possible.
And for how long can it take for us to get it?
My Regards
Ms pumulo
+260966497718
Safe distance between phase to phase &phase to earth& other arrival is best arrival. thank you.
In a 33 KV feeder line , at what distance isolation needs to be provided
What will be the permissible distance between high voltage tower and stone quarry and crushing unit please also suggest the related laws and information thanking you
Hello Mr. Parmar,
Very informative article. What is the safe distance between a High Voltage Power grid tower and a crushing unit as per law? It will be helpful if you can point me to any related Act or article for more information.
By crushing unit I meant a stone quarry
Respected sir,
i would like to know easy way to trouble shoot a series aeronautical ground lighting circuit
I am looking for the safe distance between a person sitting 8 hours per day next to a medium voltage cable 10 kv
