Home / Technical Articles / Electrical Thumb Rules You MUST Follow (6)
Electrical Thumb Rules You MUST Follow, Part 6
Electrical Thumb Rules You MUST Follow, Part 6 (On photo: View in the Transformer Room in the underground area during White House renovation on March 26, 1952 – via trumanlibrary.org)
Continued from: Electrical Thumb Rules You MUST Follow (Part 5)
12 electrical thumb rules to follow:
  1. Transformer earthing wire / Strip size
  2. Motor earthing wire / Strip size
  3. Panel earthing wire / Strip size
  4. Electrical equipment earthing
  5. Earthing wire (As per BS 7671)
  6. Area for transformer room: (As per NBC-2005)
  7. Span of transmission line (Central electricity authority)
  8. Max. lock rotor amp for 1-phase 230V motor (NEMA)
  9. Three phase motor code (NEMA)
  10. Service factor of motor
  11. Type of contactor
  12. Contactor coil
Size of T.C or DGBody EarthingNeutral Earthing
<315 KVA25×3 mm Cu / 40×6 mm GI Strip25×3 mm Cu Strip
315 KVA to 500 KVA25×3 mm Cu / 40×6 mm GI Strip25×3 mm Cu Strip
500 KVA to 750 KVA25×3 mm Cu / 40×6 mm GI Strip40×3 mm Cu Strip
750 KVA to 1000 KVA25×3 mm Cu / 40×6 mm GI Strip50×3 mm Cu Strip
Go back to Rules ↑
Size of MotorBody Earthing
< 5.5 KW85 SWG GI Wire
5.5 KW to 22 KW25×6 mm GI Strip
22 KW to 55 KW40×6 mm GI Strip
>55 KW50×6 mm GI Strip
Go back to Rules ↑
Type of PanelBody Earthing
Lighting & Local Panel25×6 mm GI Strip
Control & Relay Panel25×6 mm GI Strip
D.G & Exciter Panel50×6 mm GI Strip
D.G & T/C Neutral50×6 mm Cu Strip
Go back to Rules ↑
EquipmentBody Earthing
LA (5KA,9KA)25×3 mm Cu Strip
HT Switchgear50×6 mm GI Strip
Structure50×6 mm GI Strip
Cable Tray50×6 mm GI Strip
Fence / Rail Gate50×6 mm GI Strip
Go back to Rules ↑
Cross Section Area of Phase, Neutral Conductor(S) mm2Minimum Cross Section area of Earthing Conductor (mm2)
S<=16S (Not less than 2.5 mm2)
16<S<=3516
S>35S/2
Go back to Rules ↑
Transformer SizeMin. Transformer Room Area (M2)Min. Total Sub Station Area( Incoming HV,LV Panel, T.C Roof) (M2)Min. Space Width (Meter)
1 x 16014909
2 x 1602811813.5
1 x 25015919
2 x 2503012113.5
1 x 40016.5939
2 x 4003312513.5
3 x 40049.516718
2 x 5003613014.5
3 x 5005417219
2 x 6303613214.5
3 x 6305417619
2 x 8003913514.5
3 x 8005818114
2 x 10003914914.5
3 x 10005819719
– The capacitor bank should be automatically switched type for substation of 5MVA and higher.
– Transformer up to 25 KVA can be mounted direct on pole.
– Transformer from 25 KVA to 250KVA can be mounted either on “H” frame of plinth.
– Transformer above 250 KVA can be mounted plinth only.
– Transformer above 100 MVA shall be protected by drop out fuse or circuit breaker.
Go back to Rules ↑
VoltageNormal Span
765 KV400 to 450 Meter
400 KV400 Meter
220 KV335,350,375 Meter
132 KV315,325,335 Meter
66 KV240,250,275 Meter
Go back to Rules ↑
HPAmp
1 HP45 Amp
1.5 HP50 Amp
2 HP65 Amp
3 HP90 Amp
5 HP135 Amp
7.5 HP200 Amp
10 HP260 Amp
Go back to Rules ↑
HPCode
<1 HPL
1.5 to 2.0 HPL,M
3 HPK
5 HPJ
7 to 10 HPH
>15 HPG
Go back to Rules ↑
HPSynchronous Speed (RPM)
3600 RPM1800 RPM1200 RPM900 RPM720 RPM600 RPM514 RPM
1 HP1.251.151.151.15111
1.5 to 1.25 HP1.151.151.151.151.151.15>1.15
150 HP1.151.151.151.151.151.151
200 HP1.151.151.151.151.1511
> 200 HP11.1511111
Go back to Rules ↑
TypeApplication
AC1Non Inductive Load or Slightly Inductive Load
AC2Slip Ring Motor, Starting, Switching OFF
AC3Squirrel Cage Motor
AC4,AC5,AC5a, AC5b,AC6aRapid Start & Rapid Stop
AC 5aAuxiliary Control circuit
AC 5bElectrical discharge Lamp
AC 6aElectrical Incandescent Lamp
AC 6bTransformer Switching
AC 7aSwitching of Capacitor Bank
AC 7bSlightly Inductive Load in Household
AC 5aMotor Load in Household
AC 8aHermetic refrigerant compressor motor with Manual Reset O/L  Relay
AC 8bHermetic refrigerant compressor motor with Automatic Reset O/L  Relay
AC 12Control of Resistive Load & Solid State Load
AC 13Control of Resistive Load & Solid State Load with Transformer Isolation
AC 14Control of small Electro Magnetic Load (<72 VA)
AC 15Control of Electro Magnetic Load (>72 VA)
Go back to Rules ↑
12. Contactor coil
Coil VoltageSuffix
24 VoltT
48 VoltW
110 to 127 VoltA
220 to 240 VoltB
277 VoltH
380 to 415 VoltL
Go back to Rules ↑
Jignesh Parmar
9 Comments
  1. Shamshad Alam
    Oct 22, 2022
    Do we require separate GI wire for cable gland to earth strip?
  2. Dipankar Rai
    Sep 26, 2020
    Motor earthing wire / Strip size for < 5.5 KW should be 8 SWG GI Wire.
  3. Madhu
    Sep 17, 2019
    Hi sir iam working for railways, What are steps to follow to reduce energy consumption, we converted 100%LED energy efficient motors, pumps, rather than this what more can we do for save energy, we are using solar also in our station
  4. Rajesh Kaley
    Apr 28, 2017
    Hi Jignesh,
    We have to do motors as well electrical panels body earthing as per standard electricity rules.Can you please guide which is the applicable rule number so that we can refer to that.
    Rajesh
    • M.K.V.V.S NAIDU
      Nov 20, 2020
      Dear mr.Rajesh,
      As every electrical engineer aware the size of the earth strip/wire should able to carry current during short circuit. based on this we need to select he size of earthing conductor.
  5. Sikandar
    Nov 05, 2015
    You are working very well and your website article is very helpful for electrical technology. i love this type of site and save this link for further visiting.
    you can see by site by link
    http://www.electricalonline4u.com/2015/10/wiring-of-distribution-board.html
  6. Muhamma Younad Rana
    Oct 09, 2014
    Every body i want to know about energy conservation in detail,so i am working as a power and electric chief engineer in Pakistan with the largest group incorporate in Pakistan House of Habib(HOH) Pakistan and also i am working on energy saving project.
  7. Narbheshankar Modha
    Dec 23, 2013
    Pl. arrange to give full technical detail about protection relay setting and co ordination
  8. Engr Khan
    Dec 09, 2013
    Superb..I was expect the same from you people… Also, Can i write these type articles for Electrical engineering portal.com…as i have wrote many articles like this for Electrical Technology
    As you can see as a ref
    Three Phase Electrical Wiring Installation in Home
    http://www.electricaltechnology.org/2013/12/three-phase-electrical-wiring.html
Leave a Reply to Shamshad Alam
  +  eighty six  =  ninety six
