Home / Technical Articles / Example of MV/LV network structure with dual fed main MV switchboard
MV dual fed switchboard with 2/3 type transfer
Connected to article: Example of standard MV/LV network structure
Network structure:
  • MV consumer substation;
  • The main MV switchboard can be backed up by a generator set and it feeds two MV/LV transformers;
  • MV switchboard can be GIS or AIS and consist of following cubicles:
    – two incoming feeders (from utility)
    – two transformer cubicles
    – bus riser and bus coupling cubicle(s)
    – two outgoing transformer cubicles (supplying LV switchboard)
    – two cubicles connected to generators for backup power supply
  • The main low voltage switchboard has a dual power supply with coupler
  • Each bus section of the main low voltage switchboard has a UPS system feeding a priority circuit
  • The secondary switchboards, terminal boxes and motor control centers are fed by a single source
Reference: Protection of Electrical Networks – Christophe Prévé
  1. Filvert ramiso
    Jun 28, 2017
    Oman Bechtel
  2. Mahmoud khalil
    Dec 22, 2016
    Thanks, for your article, please give us more design details,
  3. John chandra
    Apr 26, 2015
    Very good articles and lessin for engineer
  4. Nidal otti
    Dec 01, 2014
    This is vere good
    • Nidal otti
      Dec 01, 2014
      I want to to know what are you have a new in mv
Leave a Reply to Mahmoud khalil
  ×  four  =  twelve
