Home / Technical Articles / Field devices and signals used for LV SCADA operations
Estimated Study Time: 11 minutes
Low voltage SCADA applications
At low voltage level, SCADA applications are usually used for process control and monitoring of equipment. Furthermore, incoming circuit breakers or switch disconnectors inside large LV switchboards may also be operated remotely, by the command given from the SCADA working station.
Field devices and signals used for LV SCADA operations (photo credit: adbro.co.uk)
Automatic transfer switch function between several supply sources may also be incorporated into PLC and SCADA applications. Outgoing circuit breakers are rarely controlled remotely, but they can be done as well.
Monitoring of equipment usually assumes collection of following signals:
  1. Circuit breaker or switch disconnector status (open, closed, trip)
  2. Contactor status (open, closed)
  3. Variable frequency drive, or similar device status (ready, run, faulty)
  4. Various type of protection, e.g. temperature or pressure transformer protection (activated, not activated)
  5. Temperature inside a switchboard (exact value, or as a binary ok/not ok signal)
  6. Switchboard door (open, closed)
Inside production plants, treatment plants, and other industrial facilities, process monitoring and control is a major part of SCADA application. Various process-related values are collected from field measuring devices and transferred to PLCs.
Typical examples are: temperature, pressure, level, flow… PLC is a brain of automated process. It controls process related values via various actuators, according to programmed application software.
Signals from every PLC in the plant are transferred to SCADA station, for the purpose of monitoring and control. All relevant conditions, measurements, and alarms are shown on SCADA screens.
Some, or all available commands towards field equipment, may be given remotely, using the SCADA screen. An example of a simple SCADA system block diagram is given in Figure 1.
Miodrag Kokotovic - Author at EEP-Electrical Engineering Portal
Miodrag Kokotovic
Graduated from Faculty of Electrical Engineering, within University of Belgrade, in the field of electrical power systems. Expert in electrical part of tender preparation, design, procurement, construction and commissioning of treatment plants and pumping stations, electrical power quality and energy management.
Profile: Miodrag Kokotovic
