Home / Technical Articles / How Sensitive Circuits Are Affected By Noise And What Can You Do About It?
Noise voltage
Noise is only important if it is measured in relation to the communication signal, which carries the data or information. Electronic receiving circuits for digital communications have a broad voltage range, which determines whether a signal is binary bit ‘1’ or ‘0’.
How are sensitive circuits affected by noise?
How are sensitive circuits affected by noise? (photo by Jim Hartland at Flickr)
The noise voltage has to be high enough to take the signal voltage outside these limits for errors to occur.
The power and logic voltages of present day devices have been drastically reduced and at the same time, the speed of these devices has increased with propagation times now being measured in picoseconds. While the speed of the equipment has gone up and the voltage sensitivity has gone down, the noise conditions coming from the power supply side have not reduced at all.
The best illustration that can be given of this condition is to consider where the signal voltage has been and what is happening to it compared to the noise voltage (see Figure 1).
In years gone by, signal voltages may have been 30 V or more but since then have steadily been decreasing. As long as the signal voltage was high and the noise voltage was only 1 V, then we had what most instrument engineers would call a very high signal to noise ratio, 30:1.
Most engineers would say you have no problem distinguishing the signal as long as you have such a high signal to noise ratio.
As the electronic equipment industry advanced, the signal strength went down further, below 10 and then below 5. Today we are fighting 1-, 2- and 3 V signals and still finding ourselves with 1, 2 and 3 V of electrical noise. When this takes place for brief periods of time, the noise signal may be larger than the actual signal.
The sensors within the sensitive equipment turn and try to run on the noise signal itself as the predominant voltage.
Relative magnitudes of signal and noise (then and now)
Figure 1 – Relative magnitudes of signal and noise (then and now)
When this takes place, a parity check or a security check signal is sent out from the sensitive equipment asking if this particular voltage is one of the voltages the sensor should recognize.
Usually, this check fails when it is a noise voltage rather than the proper signal that it should be looking at and the equipment shuts down because it has no signal. In other words, the equipment self-protects when there is no signal to keep it operating.
When the signal to noise ratio has fallen from a positive direction to a negative direction, the equipment interprets that as the need to turn off so this it will not be running on sporadic signals.
In the top portion of Figure 1, a 20–30-V logic signal is well in excess of the noise that is occurring between the on and off digital signal flow.
In the bottom picture, however, the noise has raised its head above the area of the logic signal which has now dropped significantly into the 3–5 V range and perhaps even lower.
You will also notice that the difference between the upper and lower pictures in the graph shows the speed with which the signal was transmitted. In the upper graph, the ons and offs are relatively slow, evidenced by the large spaces between the traces.
In the lower graph, the trace is now much faster. There are many more ons and offs jammed into the same space and as such, the erratic noise behavior may now interfere with the actual transmission.
The ratio of the signal voltage to the noise voltage determines the strength of the signal in relation to the noise. This ‘signal to noise ratio’ (SNR) is important in assessing how well the communication system will operate. In data communications, the signal voltage is relatively stable and is determined by the voltage at the source (transmitter) and the volt drop along the line due to the cable resistance (size and length).
The SNR is therefore a measure of the interference on the communication link. The SNR is usually expressed in decibels (dB), which is the logarithmic ratio of the signal voltage (S) to noise voltage (N).
SNR formula
An SNR of 20 dB is considered low (bad), while an SNR of 60 dB is considered high (good). The higher the SNR, the easier it is to provide acceptable performance with simpler circuitry and cheaper cabling.
In data communications, a more relevant performance measurement of the link is the bit error rate (BER). This is a measure of the number of successful bits received compared to bits that are in error. A BER of 10–6 means that one bit in a million will be in error and is considered poor performance on a bulk data communications system with high data rates.
A BER of 10–12 (one error bit in a million million) is considered to be very good. Over industrial systems, with low data requirements, a BER of 10–4 could be quite acceptable. There is a relationship between SNR and BER. As the SNR increases, the error rate drops off rapidly. Most of the communications systems start to provide reasonably good BERs when the SNR is above 20 dB.
Resource: Grounding, bonding, shielding and surge protection – G. Vijayaraghavan
(Buy this book at Amazon)
  1. Alex Martinich
    Jul 13, 2014
    Pointing to the smarter use of energy, it should be emphasized that lighting wastes around the world, large amounts of power, that means basically fuel. Savings could be important if most of light sources be replaced by higher lumens per watt ratios lamps, i.e. fluorescent, gas or vapor discharge (w/ series-reactors/ballast) led (in series to match voltages), etc.
    Children (future citizens) will appreciate our measure/move.
  2. Alex Martinich
    Jul 12, 2014
    Dear Edvard, Thanks a lot for the valuable articles that you usually include.
    I only would suggest that a correction (linguistic, not relevant) could happen on a word inside your Resumè, i.e. facilities instead of fascilities (assuming that no political intention is involved).
  3. jibran
    Jun 11, 2014
    your portal is the best portal I have seen ever.
Leave a Reply to Alex Martinich
sixty nine  −  sixty eight  =
