Home / Technical Articles / How Do I Choose the Best Site for My Wind Turbine?
How Do I Choose the Best Site for My Wind Turbine?You can have varied wind resources within the same property. In addition to measuring or finding out about the annual wind speeds, you need to know about the prevailing directions of the wind at your site. If you live in complex terrain, take care in selecting the installation site. If you site your wind turbine on the top of or on the windy side of a hill, for example, you will have more access to prevailing winds than in a gully or on the leeward (sheltered) side of a hill on the same property.
In addition to geologic formations, you need to consider existing obstacles such as trees, houses, and sheds, and you need to plan for future obstructions such as new buildings or trees that have not reached their full height. Your turbine needs to be sited upwind of buildings and trees, and it needs to be 30 feet above anything within 300 feet. You also need enough room to raise and lower the tower for maintenance, and if your tower is guyed, you must allow room for the guy wires.
Whether the system is stand-alone or grid-connected, you will also need to take the length of the wire run between the turbine and the load (house, batteries, water pumps, etc.) into consideration. A substantial amount of electricity can be lost as a result of the wire resistance—the longer the wire run, the more electricity is lost.
Using more or larger wire will also increase your installation cost. Your wire run losses are greater when you have direct current (DC) instead of alternating current (AC).
Obstruction Of The Wind By a Building Or Tree
So, if you have a long wire run, it is advisable to invert DC to AC.
SOURCE: Small Wind Electric Systems
  1. Mohamed
    Jan 02, 2014
    Thank You
  2. Leo Gomez
    Jan 02, 2014
    Excelente articulo
Leave a Reply to Leo Gomez
six  +  three  =
