Study specialized electrical engineering articles, papers & video courses in low/high voltage areas. Save 50% on all courses with the Enterprise Plan.
Home / Technical Articles / How Motor Really Works?
Motor action
Figure 1 - A motor action
The basic working of a motor is based on the fact that when ‘a current carrying conductor is placed in a magnetic field, it experiences a force’.
If you take a simple DC motor, it has a current-carrying coil supported in between two permanent magnets (opposite pole facing) so that the coil can rotate freely inside. When the coil ends are connected to a DC source then the current will flow through it and it behaves like a bar magnet, as shown in Figure 1.
As the current starts flowing, the magnetic flux lines of the coil will interact with the flux lines of the permanent magnet.
This will cause a movement of the coil (Figures 1a, 1b, 1c, 1d) due to the force of attraction and repulsion between two fields. The coil will rotate until it achieves the 180° position, because now the opposite poles will be in front of each other (Figure 1e) and the force of attraction or repulsion will not exist.
The role of the commutator: The commutator brushes just reverse the polarity of DC supply connected to the coil. This will cause a change in the direction of the current of the magnetic field and start rotating the coil by another 180° (Figure 1f).
The brushes will move on like this to achieve continuous coil rotation of the motor.
Similarly, the AC motor also functions on the above principle; except here, the commutator contacts remain stationary, because AC current direction continually changes during each half-cycle (every 180°).
Resource: Practical Troubleshooting of Electrical Equipment and Control Circuits – M. Brown
(Get it from Amazon)
9 Comments
  1. Wayne A. Francis
    Dec 28, 2014
    Very simple and effective disposition of technical information. Keep up this good work.
  2. suhasini
    May 18, 2014
    Awesome effort by the contributors of EEP. Have I had a source like this during my graduation, I would have been in a super cool hard core engineering job!!! Anyways better late than never..so I still try to learn whenever possible
  3. Joshua
    May 18, 2014
    How can I determine the power factor in a three phase motor?
  4. joshua
    May 18, 2014
    I love this site ,it helps me develop my engineering skills
  5. Mani Manz
    Aug 21, 2013
    clearly said . . . the non alignment of two magnetic fields makes the motor to rotate continously. . .
  6. sasi kumar
    May 29, 2013
    very nice, Thank you
  7. Md Ebrahim Shah
    Feb 24, 2013
    motor is just a device which convert electrical energy to rotation energy.
  8. chavan2294
    Feb 08, 2013
    wonder full, with simple language, thank you sir for your great contribution in electrical field
Leave a Reply to joshua
78  −  seventy five  =
