Home / Technical Articles / Learn To Interpret Single Line Diagram (SLD)
Single line diagram (SLD)
We usually depict the electrical distribution system by a graphic representation called a single line diagram (SLD). A single line can show all or part of a system. It is very versatile and comprehensive because it can depict very simple DC circuits, or a very complicated three-phase system.
Learn To Interpret Single Line Diagram - SLD (on photo: An example of 66/6.6kV power substation single line diagram)
We use universally accepted electrical symbols to represent the different electrical components and their relationship within a circuit or system. To interpret SLDs you first need to be familiar with the electrical symbols. This chart shows the most frequently used symbols.
Individual electrical symbols
SymbolIdentificationExplanation
Transformer symbolTransformerRepresents a variety of transformers from liquid filled to dry types. Additional information is normally printed next to symbol indicating winding connections, primary /secondary voltages and KVA or MVA ratings.
Drawout circuit breaker symbolRemovable or drawout circuit breakerNormally represents a MV drawout circuit breaker 5kV and above.
Future drawout circuit breaker symbolFuture removable or drawout circuit breaker positionRepresents a structure equipped to accept circuit breaker in the future, commonly known as provisions.
Non-drawout circuit breaker symbolNon-drawout circuit breakerRepresents a fixed mounted low voltage circuit breaker.
Removable or drawout circuit breaker symbolRemovable or drawout circuit breakerRepresents a drawout low voltage circuit breaker.
Disconnect switch symbolDisconnect switchRepresents a switch in low or medium/high voltage applications (open position shown)
Fuse symbolFuseRepresents low voltage and power fuses.
Bus duct symbolBus ductRepresents low and medium/high voltage bus duct.
Current transformer symbolCurrent transformerRepresents current transformers mounted in assembled equipment. A ratio of 4000A to 5A shown.
 Potential or voltage transformerPotential or voltage transformerRepresents potential transformers usually mounted in assembled equipment. A ratio of 480V to 120V shown.
 Ground (earth) symbolGround (earth)Represents a grounding (earthing) point
 Battery symbolBatteryRepresents a battery in an equipment package
 Motor symbolMotorRepresents a motor and is also shown with an “M” inside the circle. Additional motor information is commonly printed next to symbol, such as horsepower, RPM and voltage.
 Normally open (NO) contact symbolNormally open (NO) contactCan represent a single contact or single pole switch in the open position for motor control
 Normally closed (NC) contact symbolNormally closed (NC) contactCan represent a single contact or single pole switch in the closed position for motor control
 Indicating light symbolIndicating lightThe letter inside circle indicates the color. The color red is indicated.
 Overload relay symbolOverload relayProtects a motor should an overload condition develop.
Capacitor symbolCapacitorRepresents a variety of capacitors.
Ammeter symbolAmmeterA letter is usually shown to designate the meter type (A = ammeter, V = voltmeter, etc.)
Instantanaeous overcurrent protective relay symbolInstantaneous overcurrent protective relayThe device number designates the relay type (50 = instantaneous overcurrent, 59 = overvoltage, 86 = lockout, etc.)
Emergency generator symbolEmergency generatorThe symbol is frequently shown in conjuction with a transfer switch.
Fused disconnect switch symbolFused disconnect switchThe symbol is a combination of a fuse and disconnect switch with the switch in the open position.
Low voltage motor control symbolLow voltage motor controlThe symbol is a combination of a normally open contact (switch), overload relay, motor and disconnect device.
Medium voltage motor starter symbolMedium voltage motor starterThe symbol is a combination of a drawout fuse, normally open contact (switch) and motor.
 Meter center symbolMeter centerA series of circle symbols representing meters usually mounted in a common enclosure.
 Load center panelboard symbolLoad center or panelboardOne circuit breaker representing a main device and other circuit breakers representing feeder circuits usually in a common enclosure.
Transfer switch symbolTransfer switch• Circuit breaker type transfer switch
• Non-circuit breaker type transfer switch
Current transformer with ammeter symbolCurrent transformer with connected ammeterThe instrument connected could be a different instrument or several different instruments identified by the letter.
Protective relay connected to current transformer symbolProtective relays connected to current transformerDevice numbers indicate types of relays connected, such as:
• 67 – Directional overcurrent
• 51 – Time overcurrent
Simple electrical circuit
Now, that you are familiar with electrical symbol, let’s look at how they are used in interpreting single line diagrams. Below is a simple electrical circuit.
Simple single line diagram
Figure 1 – Simple single line diagram
You can tell by the symbols that this single line diagram has three resistors and a battery. The electricity flows from the negative side of the battery through the resistors to the positive side of the battery.
Industrial single line diagram
Now, lets go through a industrial single line diagram. When interpreting a single line diagram, you should always start at the top where the highest voltage is and work your way down to the lowest voltage. This helps to keep the voltages and their paths straight.
To explain this easier, we have divided the single line into three sections.
A typical industrial single line diagram
Figure 2 – A typical industrial single line diagram
Area A //
Starting at the top, you will notice that a transformer is feeding power to the whole system. The transformer steps the voltage down from 35kV to 15kV, as indicated by the numbers next to the transformer symbol. Once the voltage has been stepped down, a drawout circuit breaker (a1) is encountered.
Do you recognize the drawout circuit breaker symbol?
You can assume this circuit breaker can handle 15kV, since it is attached to the 15kV side of the transformer, and nothing different is indicated on the single line diagram. Following the drawout circuit breaker (a1) from the transformer, it is attached to a heavier, horizontal line.
This horizontal line represents an electrical bus, which is a means used to get electricity to other areas or circuits.
Area B //
You will notice that two more drawout circuit breakers (b1 and b2) are attached to the bus and feed other circuits, which are at 15kV, since there has been no indication of voltage change in the system. Attached to the drawout circuit breaker (b1), a step-down transformer is used to take the voltage in that area of the system from 15kV down to 5kV.
SLD area B
SLD area B
On the 5kV side of this transformer, a disconnect switch is shown. The disconnect is used to connect or isolate the equipment below it from the transformer. The equipment below the disconnect is at 5kV, since nothing indicates the contrary.
Do you recognize the equipment attached to the lower side of the disconnect switch as being two medium-voltage motor starters?
A number of starters could be connected depending upon the particular system requirements. Now locate the second drawout circuit breaker (b2). This circuit breaker is attached to a fused disconnect switch and it is connected to a step-down transformer. Notice that all the equipment below the transformer is now considered low voltage equipment, because the voltage has been stepped down to a level of 600 volts or lower.
The last piece of electrical equipment in the middle portion of the diagram is another circuit breaker (b3). This time, however, the circuit breaker is a fixed low voltage circuit breaker, as indicated by the symbol.
Moving to the bottom area of the single line diagram, notice that the circuit breaker (b3) in the middle is connected to the bus in the bottom portion.
Area C //
To the bottom left and connected to the bus is another fixed circuit breaker. Look carefully at the next grouping of symbols.
Do you recognize the automatic transfer switch symbol?
Also, notice that a circle symbol which represents an emergency generator is attached to the automatic transfer switch. This area of the single line diagram tells us that it is important for the equipment connected below the automatic transfer switch to keep running, even if power from the bus is lost. You can tell from the single line diagram that the automatic transfer switch would connect the emergency generator into the circuit to keep equipment running, if power from the bus were lost.
SLD area C
SLD area C
A low-voltage motor control circuit is attached to the automatic transfer switch through a low-voltage bus. Make sure you recognize these symbols. Although we do not know the exact function of the low voltage motor control in this circuit, it is obvious that it is important to keep the equipment up and running. A written specification would normally provide the details of the application.
On the right side of the third area there is another fixed circuit breaker connected to the bus. It is attached to a meter center, as indicated by the symbol formed by three circles. This indicates that the electric company is using these meters to keep track of power consumed by the equipment below the meter center.
Below the meter center is a load center or panelboard that is feeding a number of smaller circuits. This could represent a load center in a building that feeds power to the lights, air conditioning, heat and any other electrical equipment connected to the building.
Few more words //
This over-simplified analysis of a single line diagram gives you an idea of the kind of story such diagrams tell about electrical system connections and equipment.
Just keep in mind that although some single line diagrams may appear overwhelming by virtue of their size and the wide variety of equipment represented, they can all be analyzed using the same step-by-step method.
Reference // Fundamentals of Electrical Distribution by EATON
71 Comments
  1. Nathan Egdorf
    Jul 04, 2023
    I was just looking up a few electical symbols. Not sure what i did that caused a problem. Very sorry was an accident. Im an electrician not a hacker
  2. Alejandro Nava
    Dec 04, 2022
    The first figure is NOT a one-/single-line diagram. It’s a circuit diagram. The one you find in circuit analysis textbooks.
  3. Bello Ahmad
    Nov 30, 2022
    Thankd for this opportunity given is an eye opening one for me
  4. Nilesh Raut
    Nov 04, 2022
    What is the symbol of VFD.
    PLEASE
    • Trevan Ainsworth
      Dec 12, 2022
      Variable Frequency Drive
  5. Jeffrey Evans
    Sep 21, 2022
    Interesting article, thank you.
    How would you you display a power meter on an 11kv SLD?
  6. Mohamed
    Jun 02, 2022
    Thanks so much for sharing your ideas.
  7. Muhammad Sayyed
    Nov 22, 2021
    Is there a standard symbol list by IEC or ANSI?
  8. ASIS MAJUMDER
    May 11, 2021
    We can learn from excellent described in details of this electrical SLD
  9. Wendy Dedo Larbi
    Mar 07, 2021
    Please I need trial question for the section
  10. Wendy Dedo Larbi
    Mar 07, 2021
    Thank you for this interpretation .It was so easy to understand.
  11. REX ANDREW
    May 26, 2020
    very impressive work
  12. Glen Decker
    Jan 31, 2020
    Great job on the symbols! I have an AutoCAD template filled with all of the blocks that I use on a daily basis for one-line, or single line, diagrams. I see a couple of symbols on your page that I don’t have in my template yet; I’ll be making the changes to include them.
    The only difference is I use attributes in my blocks instead of values so the power systems design software I use (aeriescars.com) can create the one-line diagrams for me automatically.
    Thanks for the great info!
  13. Santosh Purushottam Patil
    Dec 08, 2019
    Every Explanation please download options
  14. Balakrishnan
    Dec 08, 2019
    Sir Very useful Information
  15. baryalai tareen
    Oct 13, 2019
    Dear Edward .
    thank you from more information about electrical SLD. you can tell whats first work in distribution projects.
  16. Samuel Olusegun
    Oct 01, 2019
    This is really impactful and easy to understand
  17. Shame Nziramasanga
    Sep 26, 2019
    Hi may you please send me a pdf copy of this info please. Its very helpful
  18. FIRASSE H. MASSERIE
    Aug 07, 2019
    excellent & simple informative
  19. Jim Aquino
    Aug 02, 2019
    Can i get a copy please Sir, thank you very much.
  20. Terry Sanders
    Jul 08, 2019
    Very thorough and informative, great job! Can you please send me PDF file to study? Thank you
  21. mariane
    Apr 27, 2019
    Can you please send me pdf copy. TIA :)
  22. L. Bangar Raju
    Mar 15, 2019
    Please send me trial access to my e-mail for limited period.
    Thanks,
    L. Bangar Raju,
    cELL NO : +919963348277
  23. Charles Ngozi Emmanuel
    Mar 02, 2019
    Please can you send me the pdf copy to my email [email protected], [email protected]
  24. mohamed
    Mar 02, 2019
    fantastic article
  25. Moises M. Meca
    Mar 02, 2019
    Thank you so much EEP & to you Sir For sharing this topic God Bless you all
  26. DODI HIDAYAT
    Mar 02, 2019
    Please send my email [email protected]
  27. NAGESWARA RAO PENNAM
    Mar 01, 2019
    THIS IS A GOOD LITERATURE FOR ELECTRICAL ENGINEERING PERSONS. PLEASE SEND ME THE PDF COPY TO ME
    THANKS
    • Freab demissie
      Aug 11, 2019
      Please soft copy about SLD.
  28. Anil Paul Jacob
    Mar 01, 2019
    Number 52 most commonly represents a circuit breaker especially in drawings made by USA, Mexican, S Korean Engineers. Recently the EU drawings are not with number 52. Also a NO contact or NC contact in an ACB control circuit we names as 52 other than power contacts. Nice Explanation. Ed can you give your email since I had few clarifications to be made, may be you might have published in your earlier versions. My mail is [email protected]. if you send a test mail I would start my mail or else comment here
    Thanks for the informative publication
  29. Somtochukwu
    Mar 01, 2019
    This is real good and educating. Please a PDF copy of this lecture would be appreciated. Thanks
    Email: [email protected]
  30. Vivek shaikh
    Mar 01, 2019
    Please send me this Valuable information on my email Address. so that i can give this to my friend and your work is very great.
    email – [email protected]
  31. Aikins larbi kwabena
    Mar 01, 2019
    Kindly send me the pdf through my email
    [email protected]
  32. Rahis
    Jan 25, 2019
    Possible send me PDF … [email protected]
  33. Mike Betts
    Jan 24, 2019
    can someone please tell me the meaning of the number 52 in the square of the drawout circuit breaker symbols on these single line diagrams. It is obviously not the CB number as they are all the same!
    Mike
      Number 52 represents a circuit breaker according to ANSI/IEEE Standard C37.2 (Standard for electrical power system device function numbers, acronyms, and contact designations).
  34. JR
    Dec 23, 2018
    Good information I need to learn more about this.
  35. Abu Kayonde
    Nov 27, 2018
    Thank you for this insightful and educative information, kindly share with me the PDF.
  36. Lynn
    Nov 03, 2018
    Super helpful, can you please share the pdf with me…..thanks
  37. Abdul kashif
    Oct 08, 2018
    Excellent explanation
  38. Joshua Pacana
    Sep 25, 2018
    Hi Sir Edvard can i please ask for a PDF copy of this? thank you very much.
  39. JHON
    Aug 28, 2018
    Please send me a PDF file form as this article is very useful as reference.
    [email protected]
    [email protected]
  40. Tanveer
    Aug 25, 2018
    Very useful information can you send me pdf on my Gmail.id [email protected]
  41. Danish khan
    Jul 28, 2018
    Can you please send me PDF soft copy @ [email protected]
  42. SANTOSH PRASAD
    Jul 15, 2018
    Thanks Edvard Csayani Sir for the excellent work of guidance on Electrical Articles.
  43. Godswill Samuel Benjamin
    Jul 03, 2018
    Very useful information.Credits to EEP and the author i really appreciate.please kindly send it in pdf format for me through my email [email protected] thanks.
  44. Beryl
    Jun 03, 2018
    Very informative,would appreciate it if this was sent to my email
  45. C Boojum
    May 27, 2018
    Excellent info. For a customized excel template that performs fault calculations, please feel free to email me at [email protected]
  46. Isaac w Toe jr
    Apr 17, 2018
    Thanks clarity..I love the way you simply the single line diagram..it’s at the simplest form and,every one can understand it well.
    Pls send me file on Siemens substation and transmissions line protection
  47. Anandadeb Chatterji
    Feb 01, 2018
    Very good. Just add few lines on why & where use of particular type of line breaking equipment( draw-out / non draw-out CBs / Disconnecting Sws. etc. in conjunction in the same line) need to be shown.
  48. sonam ongchuk lepcha
    Jan 11, 2018
    Thank you Edvard Csyani sir for your valuable lessons.EEP has been very helpful,especially for freshers like me who lacks practical experience.I look forward to more important articles.
  49. Zeeshan Ali
    Dec 14, 2017
    I was looking for that stuff,
    Well explained.
    This engineering portal is very helpful for beginner like me.
  50. Akporotu Akpomedaye
    Oct 18, 2017
    i really appreciate you sir, i am a beginner, for this reason, i would appreciate if more training on how to interpret SLD is sent to me. thank you sir.
  51. tarek
    Jun 02, 2017
    if you can provide with this explanation or simillar to it in pdf format.
  52. Shaukat Hussain
    Mar 31, 2017
    This is a great explanation of the ANSI symbols used in SLD’s, I’m used to that standard. However, I’m not so clear on the IEC symbols. Do you have anything that can help out to understand them? A comparison table would be great.
    Great blog!! Thanks!
  53. Thomas Dats
    Mar 02, 2017
    Thanks very much for those information, its very helpful and informative.
    However, could you be able to send me a simple systematic drawing from point of generation to transmission and distribution please.
    I will really appreciate your help.
    Dats Pukma
    Papua New Guinea
  54. Muhammad Saad
    Feb 26, 2017
    Sir, there is this component in a SLD i m given to read which contains a circle with MF written in it, what would that be?
  55. Madhavan.D
    Jan 25, 2017
    I want Editable Electrical single diagram
  56. Sara
    Jan 19, 2017
    The best resource on SLD for beginners. Very lucid!!!!
  57. Muhammad Rafiq
    Dec 05, 2016
    there is not get PDF option
  58. Basant Sharma
    Dec 02, 2016
    Nice blog for beginners, keep updating same.
  59. Bethuel Rmogaela
    Nov 30, 2016
    Is it technically recommended/compulsory to connect lighting system to earth leakage???
  60. James
    Nov 29, 2016
    Mate want to earn some holiday money helping with line diagrams?
  61. Nasir Zaidi
    Nov 24, 2016
    Bravo!! The way you simplified the SLDs I don’t think any one can do better then this.
    Please send me this file if possible.
  62. Víctor Bohórquez
    Nov 08, 2016
    Excelente me gustaría soy técnico en electricidad recidencial y estudio técnico en electricidad industrial me gustaría el Ártico completo gracias
  63. Emmanuel
    Sep 30, 2016
    I really love this site, more informative
  64. Azam
    Jun 10, 2016
    Kindly send me this complete article.
    My email address is: [email protected]
  65. Ken Sonntag
    May 16, 2016
    Great stuff, please add me on your email list.
  66. hossien
    May 09, 2016
    hi .. i want this file ..(( Learn To Interpret Single Line Diagram (SLD) )) … please send me on my yahoo mail .. thanks …
  67. Mwanyara Mangunda
    Apr 02, 2016
  68. Ramon Burgos
    Dec 19, 2015
Leave a Reply to Santosh Purushottam Patil
sixty two  +    =  sixty seven
