Home / Technical Articles / What details a motor nameplate shows and how to use them
Motor nameplate details
We have all seen the motor nameplate attached on the motor side (or on top). All motors have a permanent nameplate which lists all important data, further data is usually available in the motor catalogue.
What details a motor nameplate shows and how to use them (photo credit: eng-tips.com)
The motor nameplate details
Figure 1 – The motor nameplate
Example nameplate
The nameplate for a two-pole 15 kW motor may have the following important data:
Data #1
The motor has three phases and is for a mains supply with a frequency of 50 Hz.
Data #2
The rated output of the motor is 15 kW, i.e. the motor is able to supply a shaft output of at least 15 kW if connected to the mains supply as indicated. The rated output of the asynchronous motor has been written into a standard. This allows the user a free choice of the different motor makes for various applications.
The standard series has output levels such as displayed in Table 1 – Motor output series:
kW0.060.090.120.180.250.370.550.751.11.502.203.00
kW4.005.507.5011.015.018.522.030.037.045.055.075.0
Horsepower (HP) is not now a commonly used unit for measuring motor output and it can be converted as follows:
1 HP = 0.736 kW
Data #3 and #4
The stator windings can be connected in a “star” or “delta” formation. If the mains voltage is 400 V, the windings must be connected in a “star” formation. The motor current is then 27.5 A per phase. If the mains voltage is 230 V, the windings must be connected in a “delta” formation. The motor current is then 48.7 A per phase.
At start-up, when the current is between 4 and 10 times higher than the rated current, the mains supply may be overloaded.
This has led supply companies to issue regulations ordering the start-up current of large motors to be reduced. This can be achieved by, for example, having the motor start up in a star connection and subsequently switching to a delta connection.
Motor torque and current in star (γ) and delta (∆) connections
Figure 2 – Motor torque and current in star (γ) and delta (∆) connections
With the star connection power and torque are reduced to 1/3rd, and the motor cannot start at full load. A motor designed for star connection will be overloaded if there is no switch-over to star connection for full-load operation.
Data #5
The motor protection rating indicates the degree of protection provided by the motor enclosure against the penetration of liquids and foreign bodies. Designations used are described in the international standard IEC Publication 34-5.
Protection is indicated by the two letters IP (International Protection) and two digits. These are used to specify the protection level against contact and foreign bodies (first digit), and as liquid (second digit). If required, extra letters can be added.
The basic layout of the IP code is as follows:
IP 2 3 C S
  • IP – Code letters
  • 2 – first digit (from 0-6) contact and foreign bodies protection
  • 3 – second digit (from 0-8) water protection
  • C – supplementary letter A, B, C, D (optional)
  • S – complementary letter H, M, S, W (optional)
You should also note that:
  • If a digit does not have to be stated, it can be replaced by the letter “X”.
  • Supplementary and/or complementary letters can be removed without being replaced by anything else.
  • If more than one complementary letter is required, the alphabetical sequence must be followed
Figure 3 – Listing of the protection of motors under IEC 34-5
DigitFirst digitSecond digit
Contact protectionForeign body protectionWater protection
0No protectionNo protectionNo protection
1Protection against contact with the back of the handProtection against solid foreign bodies with 50 mm dia.Protection against vertically dripping water
2Protection against contact with the fingersProtection against solid bodies 12.5 mm dia.Protection against water dripping at a slope (15°)
3Protection against contact with toolsProtection against solid foreign bodies 2.5 mm dia.Protection against water sprayed to an angle of 60°
4Protection against contact with a wireProtection against solid foreign bodies 1 mm dia.Protection against water sprayed from all directions
5Protection against contact with a wireDust protectionProtection against beamed water
6Protection against contact with a wireDust protectionProtection against strongly beamed water
7Protection against temporary sub-mersion in water
8Protection against permanent sub-mersion in water
Optional supplementary letter
The optional supplementary letter indicates that people are protected against access to hazardous components:
  • Back of hand: Letter A
  • Finger: Letter B
  • Tools: Letter C
  • Wire: Letter D
The optional complementary letter indicates that operating plant is protected and provides complementary information especially on:
  • High-voltage units: Letter H
  • Water test during operation: Letter M
  • Water test during standstill: Letter S
  • Weather conditions: Letter W
In case of operating plant protected against dust (first digit is 5), dust penetration is not completely prevented; however, dust is only allowed to enter in limited quantities and the unit will continue to operate without interfering with safety.
Water protection is offered up to digit 6, which means that the requirements for all lower numbers have also been fulfilled.
An operating unit with the designation IPX7 (temporary submersion) or IPX8 (permanent submersion) need not necessary also comply with the requirements concerning protection against water jets IPX5 or strong jets of water IPX6. If both equirements are to be fulfilled, the operating unit must be given a double designation to cover both, e.g. IPX5/IPX7.
Example // IP 65 says that the motor is contact-safe and holds tight against dust and water jets.
Data #6
The rated current Is, which the motor takes up, is called apparent current and can be divided into two: an active current Iw and a reactive current IB. Cosϕ indicates the share of the active current as a percentage of the motor current at rated operation. The active current is converted into shaft output, while the reactive current indicates the power required to build up the magnetic field in the motor.
When the magnetic field is subsequently removed, the magnetising power will be fed back to the mains supply. The word “reactive” indicates that the current moves to and from the wires without contributing to the shaft output.
The apparent current input to the motor from the mains is not determined by simply adding the active current to the reactive current. This is because these two currents are displaced in time.
The size of this displacement depends on the frequency of the supply network. At a frequency of 50 Hz, the displacement between the current is 5 milliseconds. A geometrical summation is thus required:
Motor rated current formulae
The currents can be seen as the sides of a right-angled triangle, where the long side equals the square root of the sum of the short sides squared (following Pythagoras’s geometry).
ϕ is the angle between the apparent current and the active current and cosϕ is the ratio between the size of the two currents:
cos-fi
cosϕ can also be shown as the ratio between the actual output P and the apparent output S:
cos-fi
Connection between apparent, reactive and active
Figure 4 – Connection between apparent, reactive and active
The phrase “apparent power” means that only part of the apparent current generates power, i.e. the part termed Iw, the active current.
Data #7
The rated speed of the motor is the motor speed at rated voltage, rated frequency and rated load.
Data #8
Electric motors are designed for different types of cooling. Normally the cooling method is stated in accordance with international standard IEC Publication 34-6. Figure 5 shows the designations of this standard and IC stands for International Cooling.
Motor cooling in accordance with IEC 34-6
Figure 5 – Motor cooling in accordance with IEC 34-6
Motor selection must be determined by the application as well as the installation. The international standard IEC 34-7 gives the mounting type of the motor in the form of two letters, IM (International Mounting) and four digits. Figure 6 shows some of the most common designs.
Using the data from the motor nameplate, other motor data can be calculated for example, the rated torque of the motor can be calculated from the following formula:
Rated motor torque formulae
Motor mounting according to IEC 34.7
Figure 6 – Motor mounting according to IEC 34.7
The efficiency η of the motor can be determined as the ratio between the power rating and the electrical input power:
Motor efficiency formulae
The motor slip can be calculated, since the nameplate gives the rated speed and frequency. These two data items indicate a twopole motor which has a synchronous speed of 3,000 rpm. The slip speed (ns) is thus 3,000-2,910 = 90 rpm.
The slip is normally stated as a percentage:
Motor slip formulae
Of course the motor catalogue contains some of the nameplate data. In addition other data is given as well:
Motor additional data from catalogue
Figure 7 – Motor additional data from catalogue
Shaft output, speed, cosϕ and motor current can be taken from the nameplate. Efficiency and torque can be calculated on the basis of the nameplate information. Furthermore, the motor catalogue says that the starting current of the 15 kW motor, Ia, is 6.2 times higher than the rated current, IN.
Ia = 29 × 6.2 = 180 A
The starting torque of the motor (Ta) is stated to be 1.8 times the rated torque Ta= 1.8 ×49 = 88 Nm. This starting torque requires a starting current of 180 A. The maximum torque of the motor, the stalling torque (Tk) is twice the size of the rated torque:
Tk = 2 × 49 = 98 Nm
Figure 8 – Motor torque and current
Finally, the moment of inertia and the weight of the motor are stated on the motor nameplate. The moment of inertia is used for calculating the acceleration torque. The weight may be of significance in connection with transportation and installation.
Some motor manufacturers do not publish the moment of inertia, and use the flywheel effect WR2 instead. However, this value can be converted as follows:
Moment of inertia formulae
  • g is the acceleration due to gravity
  • The unit for the flywheel effect WR2 is [Nm2]
  • The unit for the moment of inertia J is [kgm2]
Reference // Fact Worth Knowing About Frequency Converters by Danfoss
16 Comments
  1. Casey Marnocha
    Aug 24, 2021
    Just in case someone’s calculations aren’t adding up, there’s a typo. 1HP = 745.7 W ~ .746 kW.
  2. sikhumbuzo
    Mar 25, 2021
    you are good
  3. Daniel Idika
    Feb 22, 2021
    1. 15.5 kw motor with speed of 1445 and a 15 kw motor with speed of 1460 which one is higher? and why??
  4. Asif Iqbal
    Sep 09, 2020
    Dear sir ,
    Please what is this (IC 611, IM 1001) in motor nameplate .fu details plz
  5. Rajan.M.G
    Nov 30, 2019
    I used to visit EEP portal at intervals and go through several topics also.Today while going through a topic on motor and its energy & power etc it is noticed that IP protection the expansion of IP given as International Protection.Actually IP stands for INGRESS PROTECTION.
  6. Vadivel
    Nov 30, 2019
    A great effort and informative .I think Data 5 in Motor Name plate must be Ingress protection(IP) instead of International protection.Thanks
  7. Dumisani
    Jul 31, 2019
    Very useful and detailed information. Thank you
  8. Ed Keaveny
    Apr 04, 2018
    I have to replace a Toshiba motor model number TC 4060L 163837. My location is Brooklyn NY 11245. Can you advise of local distributor?
  9. Armstrong
    Mar 05, 2017
    Mr Edvard, to be candid in my excitement, since I liked this page the material so far has enriched my life career wise, I basically logs into my Facebook account just to eat from your selfless publications
    This latest publication has giving me a more insight on AC motors
    God bless you real Good “Boss”
  10. Adenna
    Sep 04, 2016
    Thanks Edvard.
    since you are specialized for design high power busbar trunking, please provide a guide for that.
  11. Emmanuel Conteh
    Aug 27, 2016
    Hi Edward. since you accepted my request to join this site, it has help me a lot in my career as pupil engineer. This article is the best so far. Continue to flourish us with the latest information on electrical and electronics. God bless you and the team.
      Thank you for the kind words Emmanuel!
      • chromexu
        Sep 06, 2016
        i would like this artcle
  12. Khalid Pervez
    Aug 27, 2016
    Hi Edvard – you’re doing a marvelous work. All your articles are highly informative and rich in content, theoretical and practical, as the situation demands.
    This particular article is of great value for beginners, O&M personnel, people engaged in energy conservation, etc.
    Looking forward to keep learning from you.
      Thank you Khalid, I’m doing my best… there will be more, I promise :)
  13. Gandhi Hardoyo
    Aug 26, 2016
    Very nice, thank for information about name plate of electric motors.
Leave a Reply to Adenna
  ×  5  =  ten
