Home / Technical Articles / Field practice in moving from an old SCADA-based to a modern substation automation system (SAS)
Estimated Study Time: 35 minutes
Digital Substation Automation Systems
This article gives a systematic and pragmatic look into Substation Automation Systems, dealing with the constraints of traditional (now old) SCADA-based substations and advancing to modern SAS systems. We’ll discuss the strong arguments and field practice in moving from hardwired automation, panel-centric configurations, to communication-oriented, system-centric solutions. Sounds good!
Field practice in moving from an old SCADA-based to modern substation automation system (SAS)
Field practice in moving from an old SCADA-based to a modern substation automation system (SAS) (photo credit: Odai Yousif Mahmud via Linkedin)
Modern power systems are undergoing a fundamental transformation driven by increasing network complexity, higher reliability expectations, and the need for efficient remote operation. Substations, once designed as locally operated and heavily hardwired installations, are now required to function as intelligent, remotely supervised nodes within a highly interconnected grid. This shift has given rise to the widespread adoption of Substation Automation Systems (SAS).
A Substation Automation System (SAS) is an integrated framework that enables monitoring, control, protection, data acquisition, and communication within a substation using digital technologies and standardized communication protocols.
Rather than relying on extensive copper wiring and local-only operation, SAS combines Intelligent Electronic Devices (IEDs), high-speed communication networks, and centralized software platforms to deliver safe, reliable, and efficient substation operation.
This article provides a structured and practical overview of Substation Automation Systems, starting from the limitations of conventional SCADA-based substations and progressing toward modern SAS architectures. It explains how automation has evolved from hardwired, panel-centric designs to communication-based, system-centric solutions.
The functional architecture of SAS spanning process, bay, and station levels is explored in detail, along with the critical role of Bay Control Units (BCUs) and Local Control Cubicles (LCCs) in modern substations.
By combining theoretical concepts with real-world operational experience, this article provides engineers and students with a clear understanding of how Substation Automation Systems are designed, implemented, and operated in modern power networks.
Ok, let’s dive into the details!
  1. What is a Substation Automation System (SAS)?
    1. Why Do We Need Substation Automation Systems?
  2. Disturbance Monitoring and Power Quality
  3. Engineering Access – A Major Evolution in SAS
  4. Remote Engineering and Operational Flexibility Enabled by SAS:
    1. A Practical Operating Scenario
    2. Limitations of Conventional Substation Operation
    3. Remote Analysis Using Substation Automation Systems
    4. Remote Setting Adjustment and System Recovery
    5. Operational Benefits of Modern SAS Implementations
  5. IEC 61850 – The Real Breakthrough in SAS
  6. Conventional (Old) Substations:
    1. How Conventional SCADA Worked
    2. Analog Signals and Transducers
    3. Limitations of Conventional Substations
    4. Automated Substations
    5. From Copper to Communication
    6. Industry-Wide Transformation
  7. SAS Functional Architecture:
    1. Process Level (Gathering Information)
    2. Bay Level (Processing Data)
    3. Station Level (Overall Supervision and Control)
  8. Bay Control Units (BCUs) and Local Control Cubicles (LCCs) in Substation Automation Systems:
    1. Local Control Cubicle – Concept and Purpose
    2. Evolution of LCCs from Conventional to Automated Systems
    3. Role of the Bay Control Unit
    4. Control and Interlocking Philosophy
    5. BCU Human–Machine Interface
    6. Operational Flexibility and Maintenance Features
    7. Rear Panel Configuration and Inputs
    8. Communication and Networking
    9. Time Synchronization and Event Accuracy
  9. Attachment (PDF) 🔗 Download ‘Design Guide for Generating Power Stations and Industrial Plants’
A Substation Automation System (SAS) is an integrated system that enables monitoring, control, protection, data acquisition, and communication within a substation using digital technologies and standardized communication protocols.
Rather than relying on extensive hardwiring and local-only operation, SAS brings together intelligent electronic devices (IEDs), communication networks, and centralized software platforms to allow power substations to operate safely, efficiently, and remotely.
Importantly, SAS is not a single device or product. It is a coordinated system, where hardware, software, communication infrastructure, and operational philosophy must work together reliably.
As you probably noticed, power substations worldwide becomes strongly based on fast changing technologies. This reality may be incompatible with the traditional (old) trend of utilities in terms of systems standardization. The integration tendency in function/devices calls for a revision of professional staff profiles, in particular the old figures of dedicated protection engineer or control engineer.
New SAS functionality includes information and means useful for replacing time‐based maintenance with the more reasonable condition‐based maintenance practice (e.g., number of operations of primary switchgear and self‐supervision of IEDs)
Figure 1 – Engineer managing substation automation system (SAS)
Design, implementation and commissioning of substation automation systems (SASs)
1.1 Why Do We Need Substation Automation Systems?
To understand the need for SAS, engineers and students must first understand how modern substations are operated. Most substations nowadays are remotely located, unmanned or minimally manned, and spread across large geographical areas. At the same time, manpower costs are continuously increasing, and utilities cannot afford to staff every substation locally.
This creates a strong requirement that:
  • Substations must be controlled remotely.
  • Equipment must be monitored continuously.
  • Faults must be detected and analyzed without physical presence.
This is exactly where Substation Automation Systems play a critical role.
Figure 2 – Substation Automation System (SAS)
Another major advantage of SAS is the ability to monitor and analyze system disturbances, such as frequency deviations, voltage dips and swells, transient events, or harmonic distortion.
Through event recorders, disturbance recorders, and power quality functions embedded in modern IEDs, engineers can identify abnormal conditions, analyze system behavior, and finally take corrective action proactively.
All of this can be done without visiting the substation.
Figure 3 – SAS System Monitoring
One important evolution I have personally observed during my career in the Middle East is the increasing integration of Engineering Workstations (Engineering PCs) into Substation Automation Systems.
Traditionally, engineering access to protection relays was only available locally at the substation. Today, in many advanced utilities engineering PCs are connected to the SAS network. Secure communication links extend this access to remote locations, including control centers.
This means engineers can:
  1. Download fault records from protection relays
  2. Retrieve disturbance and event files
  3. Reset relays
  4. Update or modify protection settings remotely
This capability significantly improves response time, efficiency, and operational flexibility.
4.1 A Practical Operating Scenario
Consider a realistic operating scenario frequently encountered in modern power systems. An engineer, while away from the substation, observes that repeated protection operations are occurring on a feeder or transformer.
Simultaneously, system loading has increased due to evolving network conditions, and it becomes apparent that the existing protection settings originally configured for lower load levels are now overly sensitive.
More About Loading – Loading issue that seriously affects transformer operation
4.2 Limitations of Conventional Substation Operation
In a conventional substation environment, addressing such a situation would typically require a physical site visit. Engineers would need to travel to the substation to retrieve fault records, review disturbance data, and implement any corrective adjustments.
This approach not only increases response time but also leads to higher operational costs and prolonged system instability.
Figure 4 – Substation disturbance analyser desktop-based user interface in available in mobile version
4.3 Remote Analysis Using Substation Automation Systems
In contrast, a substation equipped with a properly engineered Substation Automation System enables rapid and informed decision-making from a remote location.
Through secure engineering access, the engineer can review real-time loading conditions, access detailed fault and disturbance records stored within protection relays and accurately diagnose the root cause of repeated protection operations.
Muhammad Kashif
Profile: Muhammad Kashif
