Home / Technical Articles / Overview Of Power System Architecture
Overview Of Power System Architecture (Switchboard For Wind Farm Vessel Tokai; photo by By Gary Williams at Flickr)
Introduction
The various components of a power system can be arranged in different ways. The complexity of the resulting architecture determines the availability of electrical energy and the cost of the investment.
Selection of an architecture for a given application is therefore based on a trade-off between technical necessities and cost.
Architectures include the following:
  1. Radial systems
    • Single-feeder
    • Double-feeder
    • Parallel-feeder
    • Dual supply with double busbars
  2. Loop systems
    • Open loop
    • Closed loop
  3. Systems with internal power generation
    • Normal source generation
    • Replacement source generation
The table below lists the main characteristics of each architecture for comparison. Illustrations are provided below table.
ArchitectureUseAdvantagesDrawbacks
 Radial
Single-feeder radialProcesses not requiring
continuous supply
E.g. a cement works
Most simple architecture
Easy to protect
Minimum cost
Low availability
Downtime due to faults may be long
A single fault interrupts supply to the entire
feeder
Double-feeder radialContinuous processes: steel,
petrochemicals
Good continuity of supply
Maintenance possible on busbars
of main switchboard
Expensive solution
Partial operation of busbars during
maintenance
Parallel-feederLarge power systems
Future expansion is limited
Simple protection
Requires automatic control functions
Double busbarsProcesses requiring high
continuity of service
Processes with major load
changes
Flexible operation: no-break transfers
Flexible maintenance
Expensive solution
 Loop systems
Open loopVery large power systems
Major future expansion
Loads concentrated in
different zones of a site
Less expensive than closed loop
Simple protection
Faulty segment can be isolated during loop
reconfiguration
Closed loopPower system offering high
Does not require automatic control
functions
Expensive solution
Complex protection system
 Internal power generation
Normal source
generation
Industrial process sites
producing their own energy
E.g. paper plants, steel
Cost of energy (energy recovered
from process)
Expensive solution
Replacement source
(source changeover)
Industrial and commercial
sites
E.g. hospitals
Good continuity of supply for priority
outgoing feeders
Examples of Power System Architectures
Examples of power system architectures
Resource: Electrical network protection guide – Schneider Electric
  1. Ogunmola sulaimon
    May 26, 2015
    It is interesting and educative
  2. chandra shekhar
    Oct 01, 2014
    sir,
    I want to know about the design aspects of power system components and the grid systems .
    please give me suggestions that how can I enhance my knowledge in this field.
Leave a Reply to chandra shekhar
thirty five  ⁄  seven  =
