Home / Technical Articles / Purpose and Working Principle of Inductive Sensors
Purpose and Working Principle of Inductive Sensors (on photo: Omron 5mm 6-36VDC inductive proximity sensor switch PNP NC)
Inductive sensors use currents induced by magnetic fields to detect nearby metal objects. The inductive sensor uses a coil (an inductor) to generate a high frequency magnetic field as shown in Figure 1 below. If there is a metal object near the changing magnetic field, current will flow in the object.
This resulting current flow sets up a new magnetic field that opposes the original magnetic field. The net effect is that it changes the inductance of the coil in the inductive sensor.
By measuring the inductance the sensor can determine when a metal have been brought nearby.
These sensors will detect any metals, when detecting multiple types of metal multiple sensors are often used.
Inductive Proximity Sensor
Figure 1 – Inductive Proximity Sensor
Note: these work by setting up a high frequency field. If a target nears the field will induce eddy currents. These currents consume power because of resistance, so energy is in the field is lost, and the signal amplitude decreases. The detector examines filed magnitude to determine when it has decreased enough to switch.
The sensors can detect objects a few centimeters away from the end. But, the direction to the object can be arbitrary as shown in Figure 2 below.
Shielded and Unshielded Sensors
Figure 2 – Shielded and Unshielded Sensors
The magnetic field of the unshielded sensor covers a larger volume around the head of the coil. By adding a shield (a metal jacket around the sides of the coil) the magnetic field becomes smaller, but also more directed. Shields will often be available for inductive sensors to improve their directionality and accuracy.
Reference:  Automating Manufacturing Systems with PLCs – Hugh Jack
  1. MICHAEL JAMES UDOH
    Jul 21, 2020
    Very useful information.
  2. Venkat
    Dec 10, 2019
    I am looking to develop purchase a sensor for detecting the possible cracks in metallic structure.,
    Pls focus some light on this sir.
  3. RAJA
    Nov 05, 2017
    Dear sir,
    please I want PLC training
  4. alberto alvarez
    Apr 28, 2014
    Hola,soy permanente visitante de la pagina electrical-engineering y consulto como puedo proceder a bajar documentos,articulos y tambien el contenido preferentemente en Español,si existe un procedimiento incluido en el sitio ,etc Me dara una considerable facilidad y velocidad en la lectura e interpretacon de los textos. Gracias ,atte. alberto alvarez electrical engineers.
    • Israel
      Dec 07, 2019
      Aprenda Ingles es mejor.
Leave a Reply to RAJA
sixty seven  −    =  fifty seven
