Home / Technical Articles / Qatar General Electricity and Water Corporation – Recommendations for Safety Clearance
Qatar General Electricity and Water Corporation - Recommendations for Safety Clearance
Qatar General Electricity and Water Corporation (Kahramaa) has awarded Leighton Contracting Qatar, a subsidiary of Australia’s HLG, the contract to carry out the work at Al Duhail and Umm Qarn reservoir and pumping stations. Qatar will build nine six million gallon reservoirs and one 25 million gallon reservoir. (photo from bigprojectme.com)
Minimum Safety Clearance of Pipelines from Electrical Tower
ServiceVertical Clearance (Min)
Water Line (to cross below EHV cable level)0.5 Meter
Sewerage Mains (to cross below EHV cable level)1.0 Meter
Drainage Mains (to cross below EHV cable level)0.5 Meter
Gas pipes0.6 Meter
Telephone lines0.5 Meter
LV / 11kV cables0.5 Meter
Safety Clearance for Excavation of Land
Voltage kVMin. Distance
380/220V0.5 Meter
20KV2 Meter
63KV7 Meter
132KV10 Meter
230KV and above20 Meter
Distance between underground power cables to wall of gas pipelines in parallel routes
Voltage kVMin. Horizontal DistanceMin. Vertical Distance
380/220V1 Meter0.5 Meter
20KV2 Meter1 Meter
63KV3 Meter1.5 Meter
(B) Outside of Towns
Distance between Tower’s foundation to Pipeline in parallel and intersections
Voltage KVMin. Distance in Parallel Route
(Up to 5 Km)
(Above 5 Km)
20KV20 Meter30 Meter
63KV30 Meter40 Meter
132KV40 Meter50 Meter
230KV50 Meter60 Meter
400KV60 Meter60 Meter
Distance between overhead lines to gas pipelines at intersections
20KV8 Meter
63KV9 Meter
132KV10 Meter
230KV11 Meter
400KV12 Meter
Distance between Tower’s foundations to gas pipelines at intersections
20KV20 Meter
63KV and higher30 Meter
Right Of Way (R.O.W) From Roads
HighwayDistance
High Way: (38 meter from one side of Central Line of Highway)76 Meter
First Class State Road=(22.5 meter from one side of Central Line of Highway)45 Meter
Second Class State Road=(17.5 meter from one side of Central Line of Highway)35 Meter
Third Class State Road =(12.5 meter from one side of Central Line of Highway)25 Meter
Forth Class State Road=(7.5 meter from one side of Central Line of Highway)15 Meter
General Electrical Safety Clearance
Voltage KVDescriptionDistance
Up to 11 KVAt points where the lines cross roads or railwaysMin 6 Meter Height
Up to 11 KVParallel to the roadsMin 5.5 Meter Height
Up to 11 KVLines cross totally desert regions where no traffic is possibleMin 5.5 Meter Height
20 KV to 66 KVAll LocationMin 6 Meter Height
Up to 11 KVConductor JointNo joint shall be closer than 3 meters to a point of support
33 KV & 66 KVConductor JointNo tension joints shall be used unless specially approved.
Jignesh Parmar
6 Comments
  1. SHYAM KOTLA
    Nov 14, 2018
    Dear sir
    Natural gas pipeline can be laid below the 66 KVA lines and what is the minimum distance should be maintained between tower footing and gas pipeline. what Precautionery measures to protect the pipelines laid near high tension power lines .
    S.P.Kotla
  2. SHYAM KOTLA
    Nov 14, 2018
    Dear sir
    Please clarify natural gas pipeline can be laid below the 66 KVA lines and what is the minimum distance should be maintained between tower footing and gas pipeline. Precautionery measures to protect the pipelines laid near high tension power lines .
    S.P.Kotla
  3. rachel
    Mar 28, 2015
    sir what is the distance between overhead line and traction system upto voltage of 33 KV?
  4. Mohamed
    Feb 23, 2015
    What is the reference for the attached information ? did you get it from KAHRAMAA standards ?? can send to me the reference of these information ,
    I tried to use it against the contractor , but the contractor told me that what is your reference !!!
  5. Saurabh Dubey
    Sep 25, 2012
    Hello sir
    I want to know about improving power factor.Suppose that we have a DG of 1000kw and the power factor is .7.If we want to change our power factor to .9 Then with help of capacitor bank how we can do it.Which How we find that which Capacitor bank we should use.
Leave a Reply to rachel
eighty nine  −    =  eighty one
