Get access to premium HV/MV/LV technical articles, technical guides & papers. Apply a 20% discount code: 99AF8 for a 1-year plan!
Formulas
If an alternating voltage V of frequency f is applied across an insulation system comprising capacitance C and equivalent series loss resistance RS, then the voltage VR across RS and the voltage VC across C due to the resulting current I are:
VR = IRS
VC = IXC
V = (VR2 + VC2)½
The dielectric dissipation factor of the insulation system is the tangent of the dielectric loss angle d between VC and V:
tand = VR / VC = RS / XC = 2pfCRS
RS = XCtand = tand / 2pfC
Note that an increase in the dielectric losses of a insulation system (from an increase in the series loss resistance RS) results in an increase in tand. Note also that tand increases with frequency.
The dielectric power loss P is related to the capacitive reactive power QC by:
P = I2RS = I2XCtand = QCtand
The power factor of the insulation system is the cosine of the phase angle f between VR and V:
cosf = VR / V
so that d and f are related by:
d + f = 90°
tand and cosf are related by:
tand = 1 / tanf = cosf / sinf = cosf / (1 – cos2f)½
so that when cosf is close to zero, tand » cosf
Note that the series loss resistance RS is not related to the shunt leakage resistance of the insulation system (which is measured using direct current).
NOTATION
The symbol font is used for some notation and formulae. If the Greek symbols for alpha beta delta do not appear here [ a b d ] the symbol font needs to be installed for correct display of notation and formulae.
B
E
f
G
I
j
k
m
N
n
P
p
R
susceptance
induced voltage
frequency
conductance
current
j-operator
coefficient
number of phases
number of turns
rotational speed
power
pole pairs
resistance
[siemens, S]
[volts, V]
[hertz, Hz]
[siemens, S]
[amps, A]
[1Ð90°]
[number]
[number]
[number]
[revs/min]
[watts, W]
[number]
[ohms, W]
S
s
T
V
X
Y
Z
d
F
f
h
q
w
voltamperes
slip
torque
terminal voltage
reactance
admittance
impedance
loss angle
magnetic flux
phase angle
efficiency
temperature
angular speed
[volt-amps, VA]
[per-unit]
[newton-metres, Nm]
[volts, V]
[ohms, W]
[siemens, S]
[ohms, W]
[degrees, °]
[webers, Wb]
[degrees, °]
[per-unit]
[centigrade, °C]
[radians/sec]
Get email alert whenever we publish new electrical guides and articles.
New Online Training Courses
World class online training for electrical engineers and industrial electricians.
