Get access to premium HV/MV/LV technical articles, technical guides & papers. Apply a 20% discount code: 99AF8 for a 1-year plan!
Formulas
The synchronous rotational speed ns and synchronous angular speed ws of a machine with p pole pairs running on a supply of frequency fs are:
ns = 60fs / p
ws = 2pfs / p
The output power Pm for a load torque Tm is:
Pm = wsTm
The rated load torque TM for a rated output power PM is:
TM = PM / ws = PMp / 2pfs = 60PM / 2pns
Synchronous Generator
For a synchronous generator with stator induced voltage Es, stator current Is and synchronous impedance Zs, the terminal voltage V is:
V = Es – IsZs = Es – Is(Rs + jXs)
where Rs is the stator resistance and Xs is the synchronous reactance
Synchronous Motor
For a synchronous motor with stator induced voltage Es, stator current Is and synchronous impedance Zs, the terminal voltage V is:
V = Es + IsZs = Es + Is(Rs + jXs)
Note that the field excitation of a parallelled synchronous machine determines its power factor:
  • an under-excited machine operates with a leading power factor,
  • an over-excited machine operates with a lagging power factor.
The field excitation of an isolated synchronous generator determines its output voltage.
NOTATION
The symbol font is used for some notation and formulae. If the Greek symbols for alpha beta delta do not appear here [ a b d ] the symbol font needs to be installed for correct display of notation and formulae.
B
E
f
G
I
j
k
m
N
n
P
p
R
susceptance
induced voltage
frequency
conductance
current
j-operator
coefficient
number of phases
number of turns
rotational speed
power
pole pairs
resistance
[siemens, S]
[volts, V]
[hertz, Hz]
[siemens, S]
[amps, A]
[1Ð90°]
[number]
[number]
[number]
[revs/min]
[watts, W]
[number]
[ohms, W]
S
s
T
V
X
Y
Z
d
F
f
h
q
w
voltamperes
slip
torque
terminal voltage
reactance
admittance
impedance
loss angle
magnetic flux
phase angle
efficiency
temperature
angular speed
[volt-amps, VA]
[per-unit]
[newton-metres, Nm]
[volts, V]
[ohms, W]
[siemens, S]
[ohms, W]
[degrees, °]
[webers, Wb]
[degrees, °]
[per-unit]
[centigrade, °C]
[radians/sec]
  1. akash
    Aug 11, 2014
    i think there is an error in this article. a synchronous motor in under-excited mode has lagging power factor and during over-excited mode has leading power factor. they mentioned it in reverse.
  2. puppala
    Apr 06, 2013
    why the alternators rated power factor is 0.8 lag only.
    why we are not producing 0.99 pf lag or unity induction motors.
    if possible give a technical article over the above said.
    The data u are giving is most useful to the EE.
    thanks and regards
    Ganesh
  3. Upendra
    Feb 17, 2013
    How is the generation voltage of generators like 0.4, 6.6, 11, 13.2 kv are selected for design?
Get email alert whenever we publish new electrical guides and articles.
New Online Training Courses
World class online training for electrical engineers and industrial electricians.
