Home / Technical Articles / Selection of Induction Motors for Industrial Applications (part 1)
Introduction to Induction Motors
All types of industries are invariably required to install different types of electric motors as prime mover for driving process equipment participating in their respective production line up. The continuous process of technical development has resulted into availability of highly diversified types of electric motors.
Selection of Induction Motors for Industrial Applications (part 1) – photo credit: fwworldwide.com
Hence, an utmost care should be exercised in selection of most appropriate type of motor considering number of technical factors for each application, so that the motor would provide desired and optimum performance.
The characteristics of motors vary widely with the nature of their application and the type of duty they are expected to perform. For example, the applications like constant speed, constant torque, variable speed, continuous/intermittent duty, steep/sudden starts, frequent start/stops, etc. should be taken into consideration carefully when deciding for the type of a motor for that specific application.
Moreover, the motors are required to perform quite often under abnormal conditions during their total service life.
In view of above, an incorrect selection of motor always lands the industrial buyer into all sorts of problems, including premature failure of the motor, causing severe production curtailments.
Like one mentioned above, a number of other factors and design features like weather conditions, stringent system conditions, abnormal surroundings, hazardous area, duty cycle, motor efficiency, etc. should be considered while deciding the rating and subsequently drawing out the technical specifications of the motor.
Stator and Rotor Damages
Abnormal conditions and effects
The usual abnormal conditions encountered by the motors are given below.
1. Abnormal System Conditions
  1. Voltage
    1. Undervoltage
    2. Overvoltage
    3. Unbalance in 3-phase
    4. Single phasing
    5. Voltage surges
  2. Frequency
    1. Low frequency
    2. High frequency
2. Abnormal Operating conditions
  1. Locked rotor or stalled rotor
  2. Reswitching/Frequent start-stops
  3. Momentary interruption/Bus transfer
  4. Overloading
  5. Improper cable sizing
3. Environmental conditions
  1. High/low ambienttemperature
  2. High altitude
  3. High humidity
  4. Corrosive atmosphere
  5. Hazardous atmosphere/surroundings
  6. Exposure to steam/salt-laden air/oil vapour
4. Mechanical problems
  1. Seized bearings
  2. Incorrect alignment/foundation levelling
  3. Incorrect fixing of coupling
  4. High vibration mounting
  5. External shock due to load
5. Condition at location
  1. Poor ventilation
  2. Dirt accumulation
  3. Exposure to direct sunlight
Though, above mentioned abnormalities may prevail for short or long duration or may be transient in nature, major impact of the listed abnormal conditions is overheating of the motor along with one or several of the other effects as follows.
Change in the motor performance characteristics like drawl of more power and consequent deterioration in motor efficiency, etc.
Increase in mechanical stresses leading to:
  1. Shearing of shafts
  2. Damage to winding overhang
  3. Bearing failures
  4. Insulation failures
Increase in stator and rotor winding temperature leading to:
  1. Premature failure of stator or rotor insulation (For wound rotor motor)
  2. Increased fire hazard
  3. Breakage of rotor bar and/or end ring (For squirrel cage motors)
All the motors encounter few or several of these abnormalities during the course of their service lives. Consideration of listed abnormal conditions at design stage greatly helps to minimise the effects of abnormal conditions to maintain a consistent performance.
Design Considerations
Following are the most important design factors required to be considered when selecting a motor for any of the diversified industrial applications.
Output in kW/HP
There are two principle limitations for selecting the motor output:
1. Mechanical limitation
The breakdown torque, which is the maximum torque that the motor can produce when operating without stalling. This is a critical design factor in motor applications, particularly for the motors subjected to occasional extreme load conditions.
Another critical factor is the locked-rotor torque, which is the maximum torque that the motor can produce during startup from steady-state condition, a critical design feature for conveyor drives.
2. Electrical limitation due to insulation provided on the motor windings
The electrical load on the motor can be imposed till the winding insulation is able to withstand the prescribed temperature rise over an ambient for that particular class of insulation. Life of the motor greatly depends on the temperature rise of the windings.
Anticipated life-span of the motor can be achieved provided it is operated at its rated output without overloading and the prescribed preventive maintenance practices are religiously followed.
Speed of the Motor
Most of the motors are directly coupled with the driven equipment where in the speed of the motor and the driven equipment will be same.
In order to meet the speed of the driven equipment, the devices like gearbox, chains or belts are introduced between motor and driven equipment. In this case, it may be necessary to provide the rotor shaft suitable for its attachment with the speed decreasing or increasing device and hence the specification should include such specific requirement.
In case a variable speed drive is to be used for the speed variation, the motor should be compatible for this specific application. The standard motor may not provide desired performance when operated via variable speed drive.
Power Supply Voltage and Frequency Variations
Variations in the power supply parameters, i.e. voltage and frequency significantly affect overall performance of the motor. As provided in IS:325-1996, the permissible voltage variation is ±5 to ±10%, permissible frequency is 50Hz ± 3%, and permissible combined variation is ±6 %.
The effect of undervoltage is more serious than that of overvoltage.
The higher torque, resulting from overvoltage, can handle a little overload without undue heating of the winding, but only for a short duration. Continuous operation with undervoltage condition increases the current at the rate of about 20% for every 5% reduction in the supply voltage, increasing the rated copper loss.
This results into heating and prolonged temperature rise, and finally the burning of winding. During a motor start-up, the torque reduces by 10% for each 5% reduction in the supply voltage, causing more starting current and consequently more rapid heating of the
winding.
Large burned out induction motor
The motor offers reduced efficiency at either overvoltage or undervoltage. Power factor drops sharply with higher voltage and improves with lower voltage. Even when motor is lightly loaded, over-voltage cause rise in current and temperature thus reducing the life of motor. The variation in frequency by +5 % decreases the torque by about 10% and vice-versa at – 5% frequency, the torque increases by about 10%.
It is, therefore, of utmost importance to consider the combined effect of variation in voltage and frequency both when purchasing the motor.
Unbalance in the supply voltage results into a current unbalance of 6 to 10 times the percentage voltage unbalance. This in turn results into generation of negative sequence currents in the rotor causing its overheating and premature failure.
It is therefore vital to specify the permissible limits of variations in the power supply parameters for the motor in accordance with the requirement of the driven equipment. However, the permissible limits should never be more than provided in the applicable Indian Standard IS:325-1996 (Reaffirmed in 2002).
Will be continued very soon…
Ashok Parikh
Working as Electrical Engineering Consultant located at Vadodara, India providing System Design & Engineering services to various industries, possessing 40 years of experience in diversified industries and consultancy.
34 Comments
  1. Aso
    Apr 03, 2020
    Hello, I am aso from Iraq, I work for the non-governmental Lan Network company, I also work for the North Refineries Company, working in the production of crude oil derivatives. I work as a provider for government companies I have a request for electric motors. It can be priced and prepared for his orders, taking into account the conditions of his order
    Aso Tariq
    +9647701408799
  2. Santosh Parade
    Jul 13, 2019
    Very useful for an electrical engineer
  3. Yuva Raj
    May 05, 2019
    Sir,
    Tell me how to select the motor ,tranformer, and generator? Because last week i attend an interview ,in that interview they asked about this topics( questions) . I don’t know what the answer is. So please tell me its really helpful for another interview.
  4. Niraj
    Dec 17, 2017
    Dear sir
    Describe the method of installation of induction motor in an industry
    • Ashok Parikh
      Dec 17, 2017
      Dear Niraj,
      Motor installation is to be carried out in accordance with the requirement of driven equipment and hence no specific method for installation can be described. However in all installations, basic requirement is to strictly maintain level of motor and its alignment with driven equipment (to avoid stresses on bearings), proper tightening of foundation blots, proper termination of power cable using glands and lugs with no undue stress on terminal plate, area of installation with good ventilation, shed over motor in case some chemical likely to fall from top, provision of earthing at correct point and of correct size, careful handling using lifting tools-tackles, etc. You can also refer to the installation manual supplied by the manufacturer with the motor.
  5. Kamlesh kalwani
    Aug 30, 2017
    Dear sir. I’m looking for industrial water pump motor. Only want motor.can u advise me the best price for motor.
    Motor: 22 kW. 30 HP.
    Input : 5″
    Output 4″
    Rpm : 1500. ( 3 phase ) 380-400 , 50Hz.
    Smaller Motor:
    Input : 3″
    Output 2″
    Rpm : 1500
    Pls advise me price a sap.
    Thanks. Kalwani.
    • Ashok Parikh
      Aug 31, 2017
      Sir, I am Engineering Consultant and not trader or dealer for any electrical materials.You may approach any of the reputed manufacturers such as Siemens, CG, Kirloskar, Laxmi, etc or any of their dealer, to get the price. Kindly provide them all possible technical specification for the best possible price offer.
  6. Prabhat Dashore
    May 16, 2016
    Dear Sir i want to run a 100 kg wheel from 1 single phase motor.
    kindly provide me specification for the same.
Leave a Reply to Aso
