Home / Technical Articles / 10 Factors To Consider When Specifying Transformers
Guidelines to specifying transformers
There are many factors that influence final specification of a transformer. However, the following ten factors MUST be considered when specifying transformers.
10 Factors To Consider When Specifying Transformers (photo credit: interelectric.co.il)
Let’s name these ten factors:
  1. Kilovoltampere (kVA) Rating
  2. Voltage Ratings, Ratio, and Method of Connection (Delta or Wye)
  3. Voltage Taps
  4. Typical Impedance Values for Power Transformers
  5. Insulation Temperature Ratings
  6. Insulation Classes
  7. Sound Levels
  8. Effects of Transformer Failures
  9. Harmonic Content of Load
  10. Paralleling transformers
Table 1 gives the preferred kVA ratings of both single-phase and three-phase transformers according to IEEE C57.12.00-2010, IEEE Standard General Requirements for Liquid-Immersed Distribution, Power, and Regulating Transformers (ANSI).
Transformer nameplate
Go back to Specifying Factors ↑
All the preferred kVA ratings in Table 1 are obviously not available as standard at all voltage ratings and ratios. In general, the smaller sizes apply to lower voltages and the larger sizes to higher voltages.
Voltage ratings and ratios should be selected in accordance with available standard equipment that is indicated in manufacturers’ catalogs. This is recommended, if at all possible, both from the viewpoint of cost and time for initial procurement and for ready replacement, if necessary.
In most small size commercial projects, the 208Y/120V secondary voltage is used because the majority of load is lighting and small appliances. A secondary voltage of 480Y/277 V, in addition to the 208Y/120 V circuits, may be required when loads are electric motors or have large lighting requirements.
Table 1 – Preferred Kilovoltampere Ratings
Single-phase [kVA]Three-phase [kVA]
39
515
1030
1545
2575
37.5112.5
50150
75225
100300
167500
250750
3331000
5001500
8332000
12502500
16673750
25005000
33337500
500010000
Generally, a three-phase transformer secondary voltage should be selected at 480Y/277 V. This has become standard and is compatible with three-phase motors, which are now rated 460 V standard.
Under normal circumstances, a 460 V rating for the transformer secondary should not be selected unless the load is predominantly older motors rated 440 V and located close to the transformer. Phase-to-neutral 277 V circuits can serve fluorescent and high-intensity discharge (HID) lighting.
3. Voltage Taps
Taps are used to change the ratio between the high- and low-voltage windings. Manual de-energized tap changing is usually used to compensate for differences between the transformer ratio and the system nominal voltage. The tap selected in the transformer should be based upon maximum no-load voltage conditions.
For example, a standard transformer rated 13 200 V to 480 V may have four 2.5% taps in the 13 200 V winding (two above and two below 13 200 V). If this transformer is connected to a system whose maximum voltage is 13 530 V, then the 13 530 V to 480 V tap could be used to provide a maximum of 480 V at no-load.
Tap changers are classified as follows //
On-load tap changers
Taps can be changed when the transformer is energized and loaded. These taps are used to compensate for excessive variations in the supply voltage. They are infrequently associated with commercial building transformers except as part of outdoor substations over 5000 kVA.
Load tap changers can be controlled automatically or manually.
No-load tap changers
Taps can be changed only when the transformer is de-energized. Tap leads are brought to an externally operated tap changer with a handle capable of being locked in any tap position. This is a standard accessory on most liquid filled and sealed-type transformers.
On very small liquid filled transformers and most ventilated-dry-type transformers, the taps are changed by moving internal links that are made accessible by a removable panel on the enclosure.
Manually adjustable (handle- or link-operable) taps are suitable for correcting long-term voltage conditions. They are not suitable for correcting short-term (hourly, daily, or weekly) voltage variations.
Automatic tap changing or voltage regulating transformers are relatively expensive so that one of the following solutions might be more appropriate //
  • Request improvement of the utility power supply regulation.
  • Segregate the circuits so that heavy variable loads are separated from more sensitive loads. When a source transformer constitutes a significant part of the impedance to a sensitive load, use a separate transformer (or secondary-unit substation) for such loads.
  • Use voltage regulating supplies for just the sensitive loads.
Typical impedance values for power transformers are given in Table 2. These values are at the self-cooled transformer kVA ratings and are subject to a tolerance of ±7.5%, as set forth in IEEE C57.12.00-1987 (ANSI).
Non-standard impedances may be specified at a nominally higher cost: Higher impedances to reduce available fault currents or lower impedances to reduce voltage drop under heavy-current, low-power factor surge conditions.
When specifying transformers, best would be to consult manufacturers’ bulletins for impedances of small transformers because they can vary considerably.
Table 2 – Transformer Approximate Impedance Values
Design impedance (percent)
High-voltage rating (volts)Low voltage,
rated 480 V
Low voltage,
rated 2400 V or higher
Power Transformers
2400 to 22 9005.755.5
26400, 34 4006.06.0
43 8006.56.5
67 0007.0
Rated kVADesign impedance (percent)
Secondary-Unit Substation Transformers
112½ through 225Not less than 2
300 through 500Not less than 4.5
Above 5005.75
Network Transformers
1000 and smaller5.0
 Above 10007.0
Transformers are manufactured with various insulation material systems (as shown in Table 2).
Performance data with reference to conductor loss and impedances should be referenced to a temperature of 40°C over the rated average conductor temperature rise as measured by resistance.
While Table 3 represents the limiting standard requirements, transformers with lower conductor losses and corresponding lower temperature rises are available, when longer life expectancy and reduced operating costs are desired.
A Class 105 insulation system allows for a 55°C rise with a total ultimate temperature of 105°C. A Class 120 insulation system allows a 65°C rise with a total permissible ultimate temperature of 120°C. An 80°C rise is allowed for a Class 150, a 115°C rise is allowed for a Class 185, and a 150°C rise is allowed for a Class 220. Materials or combinations of materials that may be included in each insulation material class are specified in IEEE C57.12.00-2010 (ANSI).
Table 3 – Insulation Temperature Ratings in °C
Average conductor temp. rise *
°C
Maximum ambient temperature
°C
Hot-spot temperature differential *
°C
Total permissible ultimate temperature
°C
Class of insulation system
°C
554010105105
654015120120
804030150150
1154030185185
150 †4030220220
* Maximum at continuous rated load.
† Dry-type transformers using a 220°C insulation system can be designed for lower temperature rises (115°C or 80°C) to conserve energy, increase life expectancy, and provide some continuous overload capability.
Voltage insulation classes and BILs are listed in Table 4.
Table 4 – Voltage Insulation Classes and Dielectric Tests
  Dry transformersOil immersed distribution transformersOil immersed power transformers
Nominal system voltage (kV)Insulation classBasic impulse level (kV)Low- frequency test (kV)Basic impulse level (kV)Low- frequency test (kV)Basic impulse level (kV)Low- frequency test (kV)
 1.1.210430104510
2.42.5201045156015
4.85.0301260197519
8.328.7451975269526
14.415.06031953411034
23.025.0110371254015050
34.534.5150501505020070
7. Sound Levels
Permissible sound levels are listed in Tables 5 and 6. Transformer sound levels can be a problem in commercial building interiors, especially where relative quiet is required, such as in conference rooms and certain office areas.
Technical specifications can require transformer sound levels to be below those specified in these two tables.
The effects of transformer sound levels can be minimized by placing the transformers in separate rooms, avoiding direct attachment of transformers to structural members, use of sound isolating pads or vibration dampers for mounting, and avoiding the mounting of transformers near plenums or stairwells where the sound will be directed into work areas.
For large units, providing flexible connections from the transformer to long busway runs will reduce the transmission of vibrations.
Table 5 – Sound Levels for Dry-Type Transformers in dB
Equivalent two-winding
kVA
Self-cooled ventilated
[1]
Self-cooled sealed
[2]
Forced-air cooled ventilated
[3]
0-94545
10-505050
51-1505555
151-3005857
301-506059
501-7006261
701-10006463
1001-15006564
1501-20006665
2001-30006866
3001-40007068
4001-50007169
5001-60007270
6001-75007371
0-116767
1168-166768
1668-200069
2001-333371
3334-500073
5001-666774
6668-833375
8334-10 00076
Columns 1 and 2 — Class AA rating, column 3 — Class FA and AFA rating.
Table 6 – Sound Levels for Single-Phase and Three-Phase Oil Cooled Transformers in dB
kVA
Without fans
With fans
0-30056
301-50058
501-7006070
701-10006270
1001-15006370
1501-20006470
2001-30006571
3001-40006671
4001-50006772
5001-60006873
6001-75006973
7500-10 0007074
Transformer failures are rare. However, in high-rise buildings and in other buildings where the conditions for evacuation are limited, the effects of the failure of larger transformers can be serious. Air from transformer vaults should be exhausted directly outdoors.
Dry-type transformers will usually be preferred to liquid filled transformers (even the less-flammable, liquid insulated types) where fire and smoke considerations are critical.
Well-designed transformer protection can minimize the extent of damage to any type of transformer. Dry-type transformers, including the cast-coil-type, if subjected to faults for an extended period, can burn and generate smoke. Liquid filled transformers can burst, burn, and generate smoke. Provisions can be made for dealing with these rare but still possible failure modes for large transformers in critical areas.
Very recent developments have indicated failures of certain types of transformers due to nonlinear loads, which cause third and higher harmonics to flow through the windings.
When these harmonics are present, due to loads like computers, variable speed drives, electronic ballasts, HID lighting, arc furnaces, rapid mode switching devices, and similar electrical loads, consideration should be given to specifying a special transformer that is designed to withstand these harmonic currents and the fluxes they produce in the cores.
When a transformer is able to be paralleled with another transformer, specifying %IR, %IX, and %IZ is required. Read more about matching transformers for parallel operation.
Reference // Recommended Practice for Electric Power Systems in Commercial Buildings (IEEE STD 241)
16 Comments
  1. JONAS WULME
    Jul 04, 2022
    Very good article. It is very insightful. Can I get a similar one on electrical motors. Good work.
  2. Sudhir Sharma
    Dec 22, 2021
    Per me transformer designer or the person who sign the transformer test report should be Professional engineer License holder of that particular state in which transformer is manufactured and tested. This clause must be added in each specification designed by each utility, which will compel transformer manufacturer to be more liable about their product and stop them to avail and recruit cheap engineer working from remote location who even never seen the transformer and its related issue for the unit they designing by sitting in India and China.
  3. Richard Barnes
    Aug 19, 2021
    We have a large transformer in our parking lot that is now leaking oil. Our power company had notified us of the problem since the transformer has obviously failed. At the same time, we have had two Trane compressor motors on our roof that have suddenly failed. Our HVAC guy said “they just froze up”…. Now we are wondering if the two events could be related. If so, how can we check before the transformer is disconnected and hauled away? Is there a chance that once the new transformer is in place, it will supply enough power to get out Trane compressors running? Or should we not expect miracles….. Please respond since we are having a real crisis here…. Thank you.
  4. Ricardo Nielo Apuyo
    Mar 27, 2021
    Impedance Temperature Ratings and Voltage Ratings are some of the important things we need to consider in the specifications of a Transformer as they are the basic entities that determines the type of Transformer for our needs and requirements. And to specify a Power Transformer it is also necessary to define the Type of Oil Immersed with or without Conservator or Dry Type Transformer, Type of Installation Indoors, Outdoors, and Pole Mounted, and Pad Mounted, and others. Standards that shall be accomplished, Primary and Secondary Voltages, Vector Group, Cooling Method and built-in Protections, Gas Temperature and Pressure of Oil or Windings Temperature. According to IEC (International Electro-Technical Commission) Standards preferred Rated Power for Medium Voltage / Low Voltage (MV/LV) Transformer are the followings : 25 kVA, 50 kVA, 100 kVA, 125 kVA, 160 kVA, 200 kVA, 250 kVA, 315 kVA, 400 kVA, 500 kVA, 630 kVA, 800 kVA, 1000 kVA, 1250 kVA, 1600 kVA, 2000 kVA, 2500 kVA, to 3000 kVA.
  5. Er. Parimal Astik
    Jul 08, 2020
    Well Mentioned.
  6. Musab Haider
    Oct 13, 2019
    Kindly make your articles pdf to be downloaded.
  7. Iryna Bilokopytova
    May 14, 2019
    It could be useful to add data on built-in current transformers as well – in case we have it (quantity, class, current ratio). And data regarding cooling system also.
  8. Mathew Paul
    Mar 08, 2019
    There are over 130 parameters to completely specify a transformer. Some are very critical. some are not.
    This gives a good idea. But I would also add Ambient conditions and Altitude at the location where this transformer will operate.
  9. Frindi mohamed
    Mar 08, 2019
    Excellent article
  10. Musaib Haider
    Mar 08, 2019
    May we get a pdf file for this topic .
  11. Alaa Mohamed
    Feb 26, 2019
    good
  12. Nazi Hussein
    Dec 17, 2018
    Witch Harmonics are produced from Power transformer when it its Not loaded? , then witch Harmonics are produced after loading ?, then how can be solved ?
    is it necessary to mention the rates of Harmonics during purchasing power transformer.
  13. Tony Bartlett
    Dec 17, 2018
    excellent articles very good at knowledge base
  14. Santosh Salunke.
    Dec 16, 2018
    How should I get the Hard copies of all articl which your forwarding on ELECTRICAL portal continues every week ?
    I am intreseted in keeping / stacking in Library.
  15. Pradeep Kumar
    Apr 25, 2016
    Impedance Temperature Ratings and Voltage Ratings are some of the important things we need to consider in the specification of a transformer as they are the basic entities that determines the type of transformer for our needs and requirements.
  16. Manuel Bolotinha
    Mar 29, 2016
    To specify a power transformer it is also necessary to define type (oil immersed – with or without conservator – or dry type), type of installation (indoors; outdoors; pole mounted; pad mounted; etc.), standards that shall be accomplished, primary and secondary voltages, vector group, cooling method and built-on protections (gas, temperature and pressure of oil or windings temperature).
    In Europe, according to IEC standards preferred rated power for MV/LV transformers are: 25, 50, 100, 125, 160, 200, 250. 315, 400, 500, 630, 800, 1000, 1250, 1600, 2000 and 2500 kVA.
Leave a Reply to Santosh Salunke.
  +  eighty five  =  ninety one
