Home / Technical Articles / Ten most dangerous mistakes in the operation of low voltage switchgear (you should be aware of)
Estimated Study Time: 15 minutes
Operation of Low-Voltage Switchgears
Low-voltage equipment is generally classified as any equipment that requires a rating of less or equal to 1000 volts to operate. With a majority of electrically driven equipment falling under this category in industrial environments, this technical article focuses on highlighting dangerous mistakes that are inadvertently made in the operation of low-voltage switchgear which possesses the high hazardous potential to equipment and/or personnel.
  1. Bypassing Switchgear Protective Devices
  2. Switchgear Guiderails/Jaw Collectors
  3. Lock-out Tag-out Systems (LOTO)
  4. Isolator Switches (Operation On Load)
  5. Single Line diagram / Electrical Schematic Drawings
  6. Power Terminals: Verification of Torque Values
  7. Operation In Hazardous Areas
  8. Earth Switches
    1. Safe Operation of Earth Switches
  9. Minimum Safety Distance
  10. Personal Protective Equipment (PPE)
The Austrian Accident Prevention Association (AUVA) in 2008, found that nearly 25% of all machine-related accidents occurred as a result of working around factory-installed protection devices.
More frequently than not, bypassing electrical protective devices such as Safety Relays, Emergency Shut-down (ESD) trip signals from a Process Safety System (PSS) and Emergency Push Buttons (EPBs) are subtly expected from Operations & Maintenance personnel due to perceived operational exigencies and management pressure to reduce production downtime.
LV Control drawing
Figure 1 – LV Control drawing (click to expand schematics)
This practice, especially when a sudden trip event is insufficiently analyzed before the feeder is re-instated to service, may lead to even greater losses such as permanent equipment damage or possible fire outbreaks. Similar event occurs in a situation where a trip event is caused by a triggered hazardous gas monitor which is assumed to be spurious and hastily bypassed to allow for continuous operation.
Hazardous gas monitor
Proper care must be taken by personnel to follow company-specific procedures for such events while striking a balance between a ‘Safety-First’ approach and operational exigency needs.
LV Drawer Safety relay
Figure 2 – LV Drawer Safety relay
Go back to Contents Table ↑
2. Switchgear Guiderails / Jaw Collectors
As an electrical operations personnel, consider a low-voltage switchgear that had been previously racked out for preventive/corrective maintenance activities and is scheduled to be put back into service.
Jaw collectors & LV drawer – A dangerous mistake involves racking in the switchgear without the ‘incoming’ and ‘outgoing’ busbars being firmly gripped by the jaw-collectors due to misalignment of the guiderails or other factors. This condition results in electrical arcs and subsequent generation of abnormal heating at the connection points while the switchgear is live and in operation.
Read here about what are good practice rules for in-process inspection of low voltage switchboard.
Air is dielectric in nature and as rated voltage is applied to the downstream loads, the resultant current flow breaks down the airgap(s) created at the connection points which as previously mentioned, produces electrical arcs.
In the absence of Arc detectors and/or switchgear cubicle heat sensors, a pending disaster is imminent.
Heat sensor
Heat sensor
In Electrical Safety toolbox talks across the globe, one of the most emphasized topics discussed and rightly so, is the importance and safety of Lock-Out Tag-Out Systems, LOTO.
Factors such as planned preventive/corrective maintenance amongst others may require a low voltage feeder or switchgear to be disconnected. In such a scenario, it is a recognized best practice to rack out the switchgear, apply safety locks and clearly display a signage stating the reason for which the feeder has been disconnected.
Multiple parties, each presenting unique locks to be jointly used in the LOTO activity, alongside preparing and validating the relevant documentation such as Isolation certificates and Permit-To-Work systems describe best practices in performing LOTO activities.
The primary purpose of this system is to ensure that all parties are present and work activities on the Isolated equipment are completed before the equipment is powered up. However, due to the seemingly cumbersome LOTO procedure required to be performed before an activity that may be considered as minor is performed on an equipment, there is a tendency for operations personnel to seek out shortcuts.
This frequently turns out to be a huge mistake and precedes an accident just waiting to happen. Learn here more about lock-out tag-out practice and seven other steps that save lives.
Ezeala Winner - Author at EEP-Electrical Engineering Portal
Ezeala Winner
I'm an electrical and controls engineer with core strengths in electrical protection and PLC-based control systems. My excellent performance in design, commissioning, maintenance, and troubleshooting of HV/LV switchboard controls and power equipment positions me as a valuable asset to an industrial environment.
Profile: Ezeala Winner
