HVAC Guides
Introduction to HVAC
The goal for a HVAC (Heating, Ventilation and Air Conditioning) system is to provide proper air flow, heating, and cooling to each room. In this process HVAC systems can provide reduce air infiltration and maintain pressure relationships between spaces. In HVAC Industries there are so many standard organizations such as ASHRAE, SMACNA, ACCA, Uniform Mechanical Code, International Mechanical Code, and AMCA have been established to support the industry and encourage high standards and achievement.
Sometimes HVAC Design (heating, ventilation, air conditioning) systems have been compared to a mystical science, part alchemy, part religious ritual.
Following the basic steps of HVAC System Design:
  • Design HVAC systems for people living inside buildings, not for the buildings alone.
  • You can’t fit a 24″ deep duct into a 23″ space, or, it’s the coordinated space
  • Be as fair as you can with and to all manufacturers
  • Dig deep into a given piece of equipment’s technical specs, and find nuggets of information that might save the owner and/or contractor money
  • Use nature to help your design
  • Have pity on the poor SOB’s that have to come behind you and service the system you design
  • In the end, only complaints or the lack of them matter
HVAC Process
In HVAC System, Ventilating is the process of replacing air in any space to control temperature or remove smoke, heat, dust and airborne bacteria. Ventilation includes both the exchange of air to the outside as well as circulation of air within the building. It is one of the most important factors for maintaining acceptable indoor air quality in buildings.
There are different types of standard heating process in HVAC system design. Central heating is often used in cold climates to heat residential houses and commercial buildings. Heating can also be provided from electric, or resistance heating using a filament that becomes hot when electricity is caused to pass through it. Air conditioning and refrigeration are provided through the removal of heat. An air conditioning system, or a standalone air conditioner, provides cooling, ventilation, and humidity control for all or part of a house or building.
All documents, software and books are free to download and preserved only to registered users. Login and registration links are located at the top-right of portal.
No.DescriptionDownload
1Handbook of PE pipe
2Fundamentals of air pollution engineering
3GeoSource Heat Pump Handbook
4Heat Exchanger and Boilers – Energy Conversion Guide
5Primer on spontaneous heating and pyrophoricity
6Recommendations for loop sizing, piping guidelines, piping arrangements
8Thermodynamics Heat Transfer and Fluid Flow Handbook
9User Guide for Desiccant Dehumidification Technology
10Danfoss – The Heating Book
11Refrigeration and air conditioning
12Control Valve Handbook
13Heating and Cooling With a Heat Pump star
14Ground-Source Heat Pump Project Analysis star
15Guide to Combined Heat and Power Systems newbook
Don't miss anything!
Powered by MailChimp
  1. [...] ElectricCAHIER TECHNIQUESSiemensBASICS OF ENERGYABB DrivesTECHNICAL GUIDESDanfossTHE HEATING BOOKHVACDESIGN GUIDESRelaysRELAY IN DETAILSPower SubstationsMAINTENANCE, LANRenewable energySOLAR, WIND, [...]
  2. Dharmendra Sharma
    Dec 15, 2010
    for eduction purpose
Leave a reply!
Engineering Trainings
Top EEP’s Technical Writers
Technical Categories
Fundamentals training The Thermodynamics, Heat Transfer, and Fluid Flow Fundamentals Handbook was developed to assist nuclear facility operating contractors provide...
Retentive Instructions OTL and OTU
Notice that our inputs are momentary push buttons and that button B is wired normally closed in the field. One...
EU Council Directives
This guide’s purpose The aim of this Technical guide No. 2* is to give a straight-forward explanation of how the...
Close
