Theory and operation
This manual contains a generalized overview of the fundamentals of transformer theory and operation. The transformer is one of the most reliable pieces of electrical distribution equipment.
It has no moving parts, requires minimal maintenance, and is capable of withstanding overloads, surges, faults, and physical abuse that may damage or destroy other items in the circuit.
Although the transformer may continue to operate as before, repeat occurrences of such damaging electrical events, or lack of even minimal maintenance can greatly accelerate the even failure of the transformer. The fact that a transformer continues to operate satisfactorily in spite of neglect and abuse is a testament to its durability. However, this durability is no excuse for not providing the proper care.
Most of the effects of aging, faults, or abuse can be detected and corrected by a comprehensive maintenance, inspection, and testing program.
Scope
Substation transformers can range from the size of a garbage can to the size of a small house; they can be equipped with a wide array of gauges, bushings, and other types of auxiliary equipment.
The basic operating concepts, however, are common to all transformers.
These activities will increase the transformers’s service lie and help to make the transformer’s operation both safe and trouble-free.
| Title: | Power Transformer Maintenance And Acceptance Testing |
| Format: | |
| Size: | 3.3 MB |
| Pages: | 62 |
It’s an a great article. Everyone should want to read this article.
3phase bank transformer drawing more current in y phase in primary at no load and temperature increasing.what is the possible cause?
its good and help to other
thanks for the info…great stuff here
Many thanks
could not download
I want to know about transformer neutral ground related. if transformer neutral is not grounded. that time we connected one bulb transformer phase with ground . that time bulb will glow or not.
Yrs, lamp will glow across one phase of transformer and ground. Ground is considered as zero potential if it is adequately earthed.
On the other hand, Lamp will also glow across one phase of trafo and trafo neutral point or Star point even un earthed. Reason being trafo star point tefered as at zero potential as per kirchaf Law when 2 currents meering at a same point in same direction with same magnitude results zero.
Yes, if groung is adequatey earthed remains at zero potential like wise trafo neutral point even not earthed rrmains at zero point as pee Kirchaf Law..,when 2 or more current meeting at same point in same direction with same magnitude results zero potential.So lamp will glow either way you chose.
Hi
the link is dead please upload it again.
I just checked the link and it works. Maybe Box.com had some hickup in the moment you tried to download guide. Please try again, it should work now.
VERY HELPFUL BOOK
Avery simple detels but it is helpfull.
