Residential Power Distribution
Power distribution systems are used in every residential, commercial buildings and industrial fascilities to safely control the distribution of electrical power throughout the facility.
The Basics of Panelboards For Electrical Engineers (Beginners)
Most of us are familiar with the power distribution system found in the average home. Power, purchased from a utility company, enters the house through a metering device. The power is then distributed from a load center to various branch circuits for lighting, appliances, and electrical outlets.
Commercial and Industrial Power distribution
Power distribution systems used in multi-family, commercial, and industrial facilities are more complex. A power distribution system consists of metering devices to measure power consumption, main and branch disconnects, protective devices, switching devices to start and stop power flow, conductors, and transformers. Power may be distributed through various switchboards, transformers, and panelboards.
Good distribution systems don’t just happen. Careful engineering is required so that the distribution system safely and efficiently supplies adequate electric service to existing loads and has expansion capacity for possible future loads.
Panelboard Definition
The National Electrical Code® (NEC®) defines a panelboard as a single panel or group of panel units designed for assembly in the form of a single panel, including buses and automatic overcurrent devices, and equipped with or without switches for the control of light, heat, or power circuits; designed to be placed in a cabinet or cutout box placed in or against a wall, partition, or other support; and accessible only from the front (Article 1 00-Definitions).
In summary, according to the NEC® definition, panelboards are:
  • Used to control light, heat, or power circuits
  • Placed in a cabinet or cutout box
  • Mounted in or against a wall
  • Accessible only from the front
For additional information, refer to National Electrical Code® Article 408, Switchboards and Panelboards. Panelboards are frequently divided into two categories:
  • Lighting and appliance branch-circuit panelboards
  • Power panelboards (also called distribution panelboards)
Prior to the publication of the National Electrical Code®, the distinction between these two panelboard types was described in Articles 408.34 and 408.35. These articles have been removed from the 2008 code. However, it will take time for the industry to adapt to this change. Therefore, Articles 408.34 and 408.35 of the 2005 National Electrical Code® still warrant discussion.
Title:Basics of Panelboards – SIEMENS
Pages:76
Basics of Panelboards - SIEMENS
  1. Anguyo Lawrence
    Sep 29, 2024
    I have really loved this portal already
    Do you offer major industrial maintenance for electrical engineering technician
    Are there offers like free access for a month
  2. XAVIER THANKARAJ
    Oct 02, 2016
    RESPECTED SIR,
    I HVE DOUBT IN LV MV HV .I NEED CLARIFICATION BELOW MENTIONED ITEM WHICHEVER ITEM WILL BE IN LV SWITCH GEAR AND WHICH ONE WILL BE ADD IN MV SWITCH GEAR, WHICH ONE WILL BE ADD HV SWITCH GEAR
    LV PANELS, MCC, CONTROL
    PANEL, DISTRIBUTION
    BOARDS, SWITCHGEAR
    COMPONENTS
    Capaciter Bank
    11 KV Switchgear
    • PRAKASH BHATT
      Dec 30, 2023
      11KV to 33kv Panels are called MV (medium voltage)
      415V panels ” (Low voltage)
      above 33KV panels are called HV
  3. gowtham42
    Jan 18, 2013
    thank u so much sir….plz keep posting new articles…
  4. Kittu
    May 05, 2012
