Spreadsheet For Calculating Size Of Motor Pump
Size of the motor pump
This spreadsheet calculates:
  • Pump hydraulic power
  • Motor-pump shaft power
  • Pump size and
  • Motor size
Some of the input information for pump:
  • Static Suction Head: (h1)
  • Static Discharge Head: (h2)
  • Is Pump Inlet Diameter equal to Outlet Diameter
  • Enter Pump Inlet Diameter
  • Enter Pump Outlet Diameter
  • Density of Liquid: (D)
  • Required Amount of Liquid at perticular Height
  • Required Time for getting Liquid at perticular Height
  • Frction Loass in Pipe
  • Pump Efficiency: (nP)
  • Motor Efficiency: (nM)
  • Safety Margin (As per Americal Petroleum Institute (API))
Software:Calculating Size Of Motor Pump
Version:
Developer:Jignesh Parmar
Price:Free
27 Comments
  1. satish
    Nov 13, 2023
    Good morning JIGNESH,
    i tried to calculate motor size for pump by using your spread sheet (calculator), but getting wrong results, please guide me.
    Details :
    Section head : 20m
    Discharge head : 160m
    Flow rate : 1.882 m3/sec
    Main Pipe dia : 48″
    Required height at perticuler point : 727m
    Please guide me
  2. Selvaraj
    Aug 03, 2023
    Pump select conversation
  3. Ally Aldina
    Apr 24, 2023
    What is the responsibilities of electrical technician in industry?
  4. Manoj kumar meena
    Apr 24, 2023
    Why motor efficiency is taken in calculation, as we are calculating motor mechanical output power, not electrical input power
  5. FASSIL ADUGNACHEW
    Aug 03, 2022
    Calculate pump – motor size
  6. Godfrey Johnbosco
    Feb 22, 2022
    Thanks for the good knowledge
  7. Nabeeh
    Sep 07, 2021
    I am an electrical engineer
  8. Rashid
    Apr 01, 2021
    Best software
  9. jarry
    Dec 21, 2018
    thank you so much
  10. tamer hanafy
    Dec 07, 2016
    thanks alot
  11. GOPI KIRAN GOGINENI
    Feb 14, 2015
    How can we check the capacitor is working or failed?
  12. Benz
    Nov 16, 2014
    nice…thanks
  13. ram
    Sep 17, 2014
    amazing website!!!
  14. ashraf
    Jun 15, 2014
    v good prog.
  15. D Datta
    Jan 09, 2014
    Excellent & very much helpful
  16. DANHTRAN
    Dec 26, 2013
    THANKS
  17. mohamed
    Dec 26, 2013
  18. mallikarjun
    Dec 23, 2013
    thanx
  19. parsoomash
    Sep 14, 2013
    Very usefull. thanx
  20. srinivasan ramakrishnan
    Aug 09, 2013
    please upload fan motor sizing calculation also
  21. Chandrakumar.T
    Aug 02, 2013
    i got download spreadsheet for calculating size of motor pump. it is in “.vcf” format then how can i open in excel format. please help me to use the software effectively.
      You didn’t download the right spreadsheet. Go to ‘Right Here’ link and download it. Format is .xlsx.
  22. VIKRAM GAJJAR
    Jul 30, 2013
    THIS IS QUITE SIMPLE AND EASY TO USE. THANKS A LOT.
  23. sidhartha
    Jul 29, 2013
    thanks for the calculation
  24. hendawysafan
    Jul 29, 2013
  25. Bassam alhaboob
    Jul 28, 2013
    THANKS
  26. marcelo palacios
    Jul 28, 2013
    Is nice have a place like this important one… congratulations
