Home / Technical Articles / A transformer is only as strong as its weakest link
Transformer rating
Capacity (or rating) of a transformer is limited by the temperature that the insulation can tolerate. Ratings can be increased by reducing core and copper losses, by increasing the rate of heat dissipation (better cooling), or by improving transformer insulation so it will withstand higher temperatures.
A physically larger transformer can dissipate more heat, due to the increased area and increased volume of oil.
A transformer is only as strong as its weakest link, and the weakest link is the paper insulation, which begins to degrade around 100 °C. This means that a transformer must be operated with the “hottest spot” cooler than this degradation temperature, or service life is greatly reduced.
Presspahn - A proven surface insulation material, resistant to high voltage and a high capacity for impregnation with transformer oil (by UKi - one of Europe’s largest suppliers of electrical insulation materials)
Presspahn – A proven surface insulation material, resistant to high voltage and a high capacity for impregnation with transformer oil (by UKi – one of Europe’s largest suppliers of electrical insulation materials)
Reclamation typically orders transformers larger than required, which aids in heat removal and increases transformer life.
Ratings of transformers are obtained by simply multiplying the current times the voltage. Small transformers are rated in “VA,” volts times amperes.
As size increases, 1 kilovoltampere (kVA) means 1,000 voltamperes, 1 megavoltampere (MVA) means 1 million voltamperes. Large generator step-up (GSUs) may be rated in hundreds of MVAs.
A GSU transformer can cost well over a million dollars and take 18 months to 2 years or longer to obtain.
Each one is designed for a specific application. If one fails, this may mean a unit or whole plant could be down for as long 2 years, costing multiple millions of dollars in lost generation, in addition to the replacement cost of the transformer itself.
This is one reason that proper maintenance is critical.
Transformer paper insulation damaged due to poor maintenance
This transformer used to be strong, but… (on photo: Transformer paper insulation damaged due to poor maintenance; credit: gcequipment.com)
Reference: Transformers: Basics, Maintenance, and Diagnostics – U.S. Department of the Interior Bureau of Reclamation
  1. bongi
    Oct 21, 2015
    Pls sign me up on this one too
  2. bongi
    Oct 21, 2015
    This site is very good I hope you have one for constrution
  3. Helvin herman
    Mar 04, 2015
    good info
  4. Hammed Abdulgafar
    Jul 07, 2014
    so intresting
  5. Foluso Omolewa
    May 29, 2014
    I mistakenly unsubscribed so I want to subacribe again. You are doing a good job by helping others. Thank you
Leave a Reply to bongi
3  ×    =  27
