Home / Technical Articles / Back To School – Let’s Calculate Current I3
Back To School - Let's calculate I3
Back To School – Let’s calculate I3
Techniques for solving DC circuits
Referring to the following circuit, calculate direct current I3:
  1. Using Kirchhoff’s laws;
  2. Using nodal analysis;
  3. Applying Thévenin’s theorem at nodes A and B.
Ok, let’s dive into calculation…
For start, let’s try to remember two Kirchhoff’s Laws //
Kirchhoff’s Current Law – The algebraic sum of currents at a node is zero.
Kirchhoff’s Voltage Law – The algebraic sum of voltages around a closed circuit loop is zero.
– KCL stands for Kirchhoff’s Current Law
– KVL stands for Kirchhoff’s Voltage Law
Currents I1, I2 and I3
The following equation can be written:
Deriving from KCL at node A
Substituting values, we obtain:
Uab
Finally,
Direct currents I1, I2 and I3
Thévenin’s voltage UTh at nodes A and B can be easily calculated by disconnecting the right part of the circuit:
Calculate Thévenins voltage
Thévenin’s equivalent resistance RTh is the resistance “seen” from nodes A and B, when all generators are deactivated (in our case, only E1 is present):
The left side of the circuit can now be substituted by its Thévenin equivalent, in order to calculate current I3:
This single-mesh circuit can be easily solved using KVL (Kirchhoff’s voltage law):
Readers should note that UAB0 ≠ UAB:
UAB = UTh – RTh · I3 = 8.333 – 4.166 · 0.041 = 8.163
Comparing the three methods, we can conclude that Thévenin’s theorem is very powerful, in particular when a single current value is needed.
Another Kirchhoff’s Laws Worked Example (VIDEO)
Thevenin’s Theorem. Example with solution (VIDEO)
Reference // Fundamentals of electric power engineering – Ceraolo, Massimo, Davide Poli.
  1. venkatesha
    Aug 10, 2015
    I want more information about electrical engineering.
  2. nitin
    May 04, 2015
    Nostalgic knowledge
  3. HESFORD QUAYE-LARBI
    Apr 13, 2015
    Very good materials for Electrical Engineering practice.
Leave a Reply to venkatesha
2  ×    =  6
