Philosophy of Protection
The purpose of an Electric Power System is to generate and supply electrical energy to consumers. The power system should be designed and managed to deliver this energy to the utilization points with both reliability and economically.
The capital investment involved in power system for the generation, transmission and distribution is so great that the proper precautions must be taken to ensure that the equipment not only operates as nearly as possible to peak efficiency, but also must be protected from accidents.
The normal path of the electric current is from the power source through copper (or aluminium) conductors in generators, transformers and transmission lines to the load and it is confined to this path by insulation.
Nature of Faults:
- Short circuit fault- current
- Open circuit fault- voltage
Classification of short circuited Faults:
- Three phase faults (with or without earth connection)
- Two phase faults (with or without earth connection)
- Single phase to earth faults
Classification of Open Circuit Faults:
- Single Phase open Circuit
- Two phase open circuit
- Three phase open circuit
Causes of Faults: The insulation, however, may break down, either by the effect of temperature and age or by a physical accident, so that the current then follows an abnormal path generally known as Short Circuit or Fault.
- Any abnormal operating state of a power system is known as FAULT.
- A fault in general consists of short circuits as well as open circuits.
- Open circuit faults are less frequent than short circuit faults, and often they are transformed in to short circuits by subsequent event.
Consequences of occurrence of faults:
- Expensive damage to the equipment due to abnormally large currents, unbalanced currents, or low voltages produced by the short circuits.
- Explosions which may occur in equipment containing insulating oil during short circuits and which may cause fire resulting in serious hazard to personnel and to other equipment.
- Sever drop in voltage which is likely to cause the individual generators in a power station or a group of generators in different stations to loose synchronism and fall out of step with consequent splitting of the system.
- A risk of synchronous motors in large industrial premises falling out of step and tripping out.
| Title: | Lecture notes on power system engineering – A course in 7th semester of Bachelor of technology programme in electrical engineering by Department of electrical engineering Veer Surendra Sai University of technology, Burla |
| Format: | |
| Size: | 5.40 MB |
| Pages: | 206 |
| Download: | Here đź”— (Get Premium Membership) | Video Courses | Download Updates |
Good work
I optimistic that one day my quest to be among the best Engineers in the World will materialise, despite the lack of opportunity to practice and to learn more.
I am thinking that my helper will surely locate me some day
very educative site
