PLCs in substation automation
Reliability, a large installed base, extensive support resources and low costs are some of the benefits of using PLCs as a basis for substation automation and SCADA systems. PLCs are extremely reliable. They have been developed for application in harsh industrial environments.
They are designed to operate correctly over wide temperature ranges and in very high electromagnetic noise and high vibration environments. They can operate in dusty or humid environments as well. The number of PLCs (in the millions) which have been applied in various environments has allowed the designers of PLCs to perfect the resistance to the negative effects of harsh environments.
The large installed base of PLCs offers the advantages of reduced costs, readily available and low cost spare parts and trained personnel to work on PLCs.
The large installed base also allows the manufactures more opportunity to improve design and offer new products for more varied applications.
PLCs have extensive support throughout the US and most of the world. PLC manufactures have extensive of field offices, distributors and authorized control system integrators. Most technical schools and colleges offer courses in PLC application, programming and maintenance.
With the lower cost solutions PLC based systems offer in substation and distribution automation applications along with the other benefits, it is no surprise that there is so much interest in the application of PLCs in a substation.
How new technologies can improve monitoring and control?
Substations are a critical component for maintaining electrical supply and load control in low voltage, medium voltage and high voltage electrical distribution networks.
In order to ensure the proper functioning of substations and related equipment such as line-mounted switches and capacitors, most utilities use SCADA (supervisory control and data acquisition) systems to automate monitoring and control.
Not only will a new or upgraded SCADA system provide better monitoring and control, it can also extend the life of substations and related equipment by providing current data for troubleshooting small problems before they escalate.
Furthermore, the ample historical data provided by SCADA systems can improve preventive maintenance scheduling and cut associated.
| Title: | Substation automation based on PLCs and SCADA system – Chitapure Sirajuddin Burhanuddin, Ansari Sameer Riyaz Ahmed, Shaikh Adnan Salahuddin and Kondkari Faizaan Ahmed Nizamuddin at University Of Mumbai |
| Format: | |
| Size: | 5.30 MB |
| Pages: | 98 |
This would be great, although, I understand that certain industrial standards need to be met. For example, IEEE 1613 and/or IEC61850.
The PLCs may not be certified to these standards currently.
Dear Edvard,
Thanks for your revert. I’m appreciating your team to consider this content is an excellent work & uploaded on EEP also feeling me to be proud, helpful & contributed to our community.
Hope this will help people to explore this technology in better way in future.
Title: Substation automation based on PLCs and SCADA system
Thanks & Regards,
SIRAJUDDIN CHITAPURE
Please correct the pictorial presentation. It is symbolizing a Low Voltage Circuit Breaker used in between High Voltage Isolators.
ground grid step and touch voltage of a generating plant
do you have formula equation can use to get step and touch voltage of a switchgear installation on a pad?
