Home / Technical Articles / Few Words About Frequency Converters
Few Words About Frequency Converters (photo credit: bpa.ru)
Introduction
Since the late 1960’s, frequency converters have undergone extremely rapid changes, largely as a result of the development of microprocessor and semi-conductor technologies and their reduction in prices. However, the basic principles of frequency converters remains the same.
Frequency converters can be divided into four main components:
Simplified frequency converter
Figure 1 – Simplified frequency converter
1. Rectifier
The rectifier, which is connected to a single/three-phase AC mains supply and generates a pulsating DC voltage. There are two basic types of rectifiers – controlled and uncontrolled.
2. Intermediate circuit
The intermediate circuit. There are three types:
  1. One, which converts the rectifier voltage into a direct current.
  2. One, which stabilises or smoothes the pulsating DC voltage and places it at the disposal of the inverter.
  3. One, which converts the constant DC voltage of the rectifier to a variable AC voltage.
3. Inverter
The inverter which generates the frequency of the motor voltage. Alternatively, some inverters may also convert the constant DC voltage into a variable AC voltage.
Control circuit
The control circuit electronics, which transmit signals to- and receive signals from the rectifier, the intermediate circuit and the inverter. The parts that are controlled in detail depends on the design of the individual frequency converter (see Figure 2).
What all frequency converters have in common is that the control circuit uses signals to switch the inverter semi-conductors on or off. Frequency converters are divided according to the switching pattern that controls the supply voltage to the motor.
In figure 2, which shows the different design /control principles:
  1. Is a controlled rectifier,
  2. Is an uncontrolled rectifier,
  3. Is a variable DC intermediate circuit,
  4. Is a constant DC voltage intermediate circuit,
  5. Is a variable DC intermediate circuit,
  6. Is a PAM inverter and
  7. PWM inverter.
Different design / control principles of frequency converter
Figure 2 – Different design / control principles of frequency converter
Current Source Inverter: CSI
(1 + 3 + 6)
Pulse-amplitude-modulated converter: PAM
(1 + 4 + 7) (2 + 5 + 7)
Pulse-width-modulated converter: PWM/VVCplus
(2 + 4 + 7)
Direct converters, which do not have an intermediate circuit should also be briefly mentioned for completeness. These converters are used in the Mega-watt power range to generate alow-frequency supply directly from the 50 Hz mains and their maximum output frequency is about 30 Hz.
Resource // Fact Worth Knowing About Frequency Converters – Danfoss
6 Comments
  1. Rolando
    Oct 18, 2014
    Hello my friends
    I Have a Problem with a 40HP VLT . I changed Powercard and it is runnig Ok . But when the VLT is Stoped The LCP shows an Warning alarm W66 next time the fan cooler is run for abaut 5″ and the w66 is not shows in the LCP.
    Could you helpme please?
    • eugen
      May 29, 2016
      This could indicate that the temperature sensor is defect.
  2. fadymohamed
    Oct 22, 2013
    very helpfull
  3. anbarasan
    Nov 26, 2012
    very gud explination
  4. expertautomation2011@gmail.com
    Nov 23, 2012
    this panel view just remember me “STARLINGER AUSTRIA” MACHINES PANELS
  5. LaithAlazawy
    Nov 21, 2012
    So Good So Helpful
Leave a Reply to expertautomation2011@gmail.com
16  ⁄  2  =
