Electrical Design Course
This course is a step-by-step guide on designing low-voltage distribution systems in houses, apartmants and other commercial buildings. The design includes lighting, wiring of electrical components, selection of circuit breakers and fuses, creation of single-line diagram and riser of building, selection of generators, design of earthing systems, light current systems and much more.
The course consists in 20 lessons and 181 topics with a duration of 44 hours.
You will also learn how to calculate voltage drops and conduct short-circuit analyses.
This course includes over 181 lectures designed to provide a comprehensive and profound understanding of electrical design, progressing from novice to expert.
Throughout the course you will learn:
- Basics of lighting design including concepts and methods of design.
- Design of the lighting system using Dialux Evo.
- Design of the lighting system using Dialux Red.
- Basics of Autocad Electrical.
- Wiring of the electrical system in Autocad that includes luminaries, sockets, and more.
- Panel schedule for power and lighting systems.
- Selection of circuit breakers and cables.
- Drawing the single-line diagram of an electrical system and the riser of a building.
- Importance of load estimation process and how to do it with a step-by-step lesson.
- Load estimation using Excel program.
- Transformer room dimensions sizing.
- Generator room dimensions sizing.
- Voltage drop analysis using manual calculations and the ETAP program.
- Short circuit analysis using manual calculations and the ETAP program.
- Everything about cables including different types of cables, types of armouring systems, types of
- insulation, types of cable formation, derating factors, and more.
- Sizing of the neutral and the earthing conductors.
- Design of the earthing system using manual calculations and the ETAP program.
- Design of lightning protection system.
- Design of the UPS systems.
- The residual circuit breakers, fuses, and breakers used in low, medium, and high-voltage circuits.
- Construction, types, and components of an electrical panel.
- Everything about the ETAP program from zero to hero.
Bonus Gift for buying the course:
You will find also the course slides for those who are interested in them or having them as a revision for themselves:
- 81 Pages of Lighting Design
- 32 Pages of Earthing System Slides
- 49 Pages of Generator Sizing Slides
- 20 Pages of Notes about Electrical Design
- 70 Pages of Panel Board, Breakers, Fuses, and Cables
- 27 Pages of Power Factor and Lightning Protection Systems
- 8 Pages of Generator and Transformer Room Sizing
- 192 Pages of Conduits, ATS, Lighting Switches, and UPS.
- 92 Pages of NEC Sizing for Conductors, Overcurrent, and Overload.
Course Summary:
- Overview of Electrical Design Course
- Load Estimation, Generator Room, and Transformer Room
- Basics of Autocad for Wiring in Autocad
- Basics of Lighting Design
- Lighting Design Using Dialux Evo Program
- Lighting Legend, Switches, and Wiring in AutoCAD
- Power Legend, Sockets, and Mechanical Loads
- Disconnecting Switches and Wiring in AutoCad
- Panel Schedule
- Circuit Breakers and Fuses
- NEC Sizing for Overcurrent Protection
- Cables Course
- NEC Sizing for Conductors
- Panel Boards Construction and Types
- Power Factor Correction Using Capacitor Banks
- Voltage Drop and Short Circuit Analysis
- UPS System
- Generator Sizing
- Earthing System
- Lightning Protection System
Who Is This Course For?
- Electrical engineers
- Electrical engineering students
- Electrical power engineers
- Electrical power engineering students
- You should have a computer or laptop.
- You should have an Internet connection to download Dialux and Autocad.
After purchasing the course, students can download the course-related documents:
- Overview on Electrical Design Course (PDF)
- Demand and Diversity Factors (PDF)
- Load Estimation (PDF)
- Load Estimation Methods (PDF)
- Transformer and Generator Room Sizing (PDF)
- Basics of Lighting Design (PDF)
- Reading and Preparing Architectural Drawings (PDF)
- ABB - Disconnect Switch (PDF)
- Administration Building Project Design (DWG)
- AF, AT, FTU, FMU, MTU, and ATU of a MCCB (PDF)
- Autocad First Floor (DWG)
- Autocad First Floor - Lighting (DWG)
- Autocad First Floor - Lighting - Part 1 (DWG)
- Autocad First Floor - Lighting - Part 2 (DWG)
- Autocad First Floor - Lighting - Part 3 (DWG)
- Autocad First Floor - Power - Part 1 (DWG)
- Autocad First Floor - Power - Part 2 (DWG)
- Autocad First Floor - Power - Part 3 (DWG)
- Autocad Shortcut (PDF)
- Circuit Breakers values (PNG)
- Conduits, ATS, Lighting Switches, and UPS (PDF)
- Earthing System (PDF)
- Eaton Breakers (PDF)
- Electrical Design of a Panel (PDF)
- El Sewedy Cables (PDF)
- ETAP (PDF)
- Final Task 1 Lighting (DWG)
- Floor 1 - Dialux Evo (DWG)
- Floor 1 - Lighting (DWG)
- Generator Rooms (PDF)
- Generator Sizing and UPS Systems (PDF)
- IFMT2_TBS165 G 4XTL5-14W HFS C3 (LDT)
- Lighting Legend - Course (PDF)
- Load Estimation Excel (XLSX)
- MCCB Catalog (PDF)
- MCCB-UTS150N_Datasheet (PDF)
- NEC Sizing for Conductors, Overcurrent and Overload (PDF)
- NEMA Ratings (PDF)
- Panel Board, Breakers, Fuses, and Cables (PDF)
- Panel Schedule (XLSX)
- Panel Schedule - Cables (XLSX)
- Panel Schedule - Cad (DWG)
- Panel Schedule - NEC (XLSX)
- Power Factor and Lightning Protection (PDF)
- Power Factor Correction Example (PDF)
- Riser of Residential Building (DWG)
- Siemens Disconnect Switches (PDF)
- Single Line Diagram of Industrial Location (DWG)
- Transformers Catalogue ABB (PDF)
- Villa - Electrical Design (DWG)
- XC400-500 (PDF)
Learn AC Distribution Panel Drawings: Single-Line Diagrams, Wirings, and Interlocking Schematics
