Power System Analysis, Modelling, Load Flow and Fault Studies for True Engineers
Learn everything about power system analysis, single-phase and three-phase electric systems, designing and modeling generators, transformers, and transmission lines. The power system study comprises load flow studies and fault analyses. 121 lectures in 21h 41m total course length.
In this class, you will learn everything there is to know about power system analysis, beginning with the fundamentals of single phase and three phase electric systems, moving on to the designing and modeling of various power system components like generators, transformers, and transmission lines, and concluding with a complete power system study that includes load flow studies and an analysis of power system faults.
Therefore, you can consider this class to be your comprehensive reference to one of the most important subfields of power engineering: an examination or analysis of the power system.
The course consists of 15 chapters, 121 lectures and 21h 41m total length.
The course is structured as follows: Firstly, an overview on the power system structure is illustrated through the following topics:
  1. Generation, transmission, distribution, and consumption of electric power
  2. How to draw a single line diagram (SLD) of any power system
After that, the following lessons will deal with the fundamental ideas related to electrical engineering, which will serve as a short refresher for you. The following subjects will be discussed in depth:
  1. Different types of powers in power system
  2. Complex power, power triangle, and power factor definitions
  3. Power factor correction
  4. Complex power flow in any power system
Then, because three phase systems are used in 99 percent of practical electric networks, a comprehensive examination of three phase systems is presented. Thus, three phase circuits are thoroughly covered in the following topics:
  1. Why we need three phase systems?
  2. Three phase supply and load.
  3. Different 3-ph connections (star-star), (star-delta), (delta-star), (delta-delta).
  4. Difference between (3-wire) and (4-wire) 3-ph systems.
  5. The relations between line and phase currents and voltages.
  6. Power analysis in 3-ph systems.
  7. Power factor improvement in 3-ph circuits.
The next topic deals with the modeling and characteristics of generators in power systems, beginning with the operation and construction of alternators and progressing to the measurement of synchronous generator performance indices. The following subjects will be discussed:
  1. Construction and operation of alternators.
  2. Salient pole vs. cylindrical rotor generators.
  3. Generator model in power systems.
  4. Generator phasor diagram and characteristics.
  5. Generator performance parameters.
  6. Power angle curve of synchronous generators.
The following topic is about transformers and their applications in power systems. Through the following overview, we will discuss how transformers work and their role in power systems:
  1. Construction and operation of transformers.
  2. Transformer equivalent circuit.
  3. Tests performed on transformers.
  4. Transformer efficiency and regulation.
  5. Three-phase transformer types and connections.
  6. Per phase model of three phase transformer.
Following that, we will conduct a comprehensive modeling of various types of transmission lines, as well as an assessment of transmission line performance in electric networks, using the following topics:
  1. Overhead lines vs. Underground cables (UGC).
  2. Transmission line modelling and performance.
  3. Short, medium, and long line models.
  4. Lossless transmission lines.
  5. Surge impedance loading (SIL).
After modeling and evaluating various power system components, let us move on to the per unit system and learn about the concept and importance of per unit in power system analysis by following the instructions below:
  1. Concept nd calculations of per unit.
  2. How to draw per unit reactance diagram.
  3. Change of base.
  4. Numerical examples on practical power systems.
Then we will perform a thorough power flow study to determine the electrical parameters for any power system under any operating conditions. The following subjects are addressed.
  1. Concept and importance of power flow study.
  2. Definitions in power flow analysis.
  3. Types of power system buses.
  4. Formation of Ybus.
  5. Approximate method.
  6. Iterative methods for load flow analysis.
  7. Gauss-Seidal method.
  8. Power flows and losses analysis.
  9. DC power flow method.
  10. Numerical examples on practical power systems.
The power systems are then subjected to a comprehensive fault analysis to determine the fault current, bus voltages, and line current during the fault. All of these frameworks are discussed.
  1. Definition, causes, types, and consequences of electric faults.
  2. Complete symmetrical fault analysis using Thevenin and Zbus.
  3. Symmetrical components and sequence networks.
  4. Complete unsymmetrical fault analysis using thevenin and Zbus.
Finally, after completing the power system analysis, the following practical projects are carried out using MATLAB:
  1. Project 1 – Standalone synchronous Generator.
  2. Project 2 – Synchronous Generator connected to the grid.
  3. Project 3 – Simulation of 3-ph transformers.
  4. Project 4 – Transmission line design.
  5. Project 5 – Power flow study in MATLAB.
  6. Project 6 – Fault analysis in MATLAB.
  1. Anyone who wants to learn electric protection and control from scratch
  2. Electrical Engineering Students
  3. Electrical Engineering Graduates
  4. Electrical Engineers who work in the field of substations and switchgear
  5. Electrical Control Engineers
  6. Power/Utility Engineers
  • Passion to learn power system
  • The basic electrical principles
  1. Electronic book of the course (PDF)
  2. ETAP: Synchronous mc with grid (SLX)
  3. ETAP: Simulation of 3-phase transformer (SLX)
  4. ETAP: Short transmission line design (SLX)
  5. ETAP: Load flow analysis (SLX)
  6. ETAP: Fault analysis (SLX)
  7. ETAP: Emf control of synchronous generator (SLX)
  8. Trip and control circuit schemes of signaling between relays and circuit breakers (PDF)
  9. The basics of power system protection that every engineer should know about (PDF)
  10. Relay protection failures and their impact on the 380 kV substation reliability (PDF)
  11. Practical handbook for relay protection engineers (PDF)
  12. Overcurrent protection study for power network - Solving relay setting miss-coordination (PDF)
  13. Lecture notes in relay protection for students: Generator, motor and transformer (PDF)
  14. Lecture notes in power system protection (PDF)
  15. Advanced protection scheme for power transformers based on IEC 61850 standard (PDF)
Expand All
Amr Saleh
I'm an Electrical Power and Machines Engineering Teaching Assistant at Ain Shams University. Throughout my career, I have taught many courses related to different topics of electrical power engineering, including Power Systems, Power Electronics, Electric Machines, High Voltage and Electric controls and protection. I gained knowledge in these areas of Electrical Engineering during my undergraduate studies and my Masters's degree, as well as during my professional career.
5 Courses
+70 enrolled
  • 15 Lessons
  • 119 Topics
