Welcome to the ultimate, comprehensive course on MATLAB/Simulink for Electrical Engineering. The course covers various simulations in power electronics, electrical circuits, electrical machines, power system, solar and wind energy production.
The course includes 7 sections, 14 lessons and 108 lectures, with a total duration of 27h 19m. Matlab files and course slides are included.
In today’s rapidly evolving technological landscape, the ability to model, simulate, and analyze complex electrical systems is an indispensable skill for engineers, researchers, and students alike. This meticulously designed course bridges the gap between theoretical electrical engineering concepts and practical, software-based implementation.
By the end of this journey, you will transform from a novice to a proficient simulation engineer, capable of designing, testing, and validating complex electrical systems before they are ever built in the physical world.
What You Will Learn
This course is divided into specialized modules, each targeting a core pillar of electrical engineering:
Module 1 – Advanced Power Electronics Simulations
In this foundational module, you will learn to construct and simulate various converter topologies from the ground up. We start with the simulation of 1-phase rectifiers, covering controlled, uncontrolled, half-wave (HWR), and full-wave (FWR) rectifiers, before scaling up to robust 3-phase rectifier systems.
You will then master complete simulations of AC voltage controllers for both single and three-phase systems, including the critical application of closed-loop control to regulate voltage output dynamically.
Finally, you will apply industry-standard Pulse Width Modulation (PWM) techniques to control these inverters with high precision.
Module 2 – Dynamics of Electrical Circuits
This section delves into the transient behavior of electrical circuits. You will simulate DC transient circuits and deeply analyze R-L, R-C, and R-L-C configurations. By applying forced and free responses in Simulink, you will visualize how circuits react to sudden changes, switching events, and varying initial conditions.
Furthermore, you will simulate electric resonance—an essential phenomenon in both power and communication systems—understanding how to tune and analyze resonant frequencies using MATLAB’s powerful computational engines.
Module 3 – Comprehensive Electrical Machines Simulations
This extensive module covers the complete simulation lifecycle of various electrical machines. Starting with DC machines, you will build models for shunt, series, and separately excited DC motors, exploring crucial concepts like speed control and the implementation of motor starters to prevent high inrush currents. You will also simulate DC generators to understand power generation mechanics.
Transitioning to AC, we provide complete simulations of Induction motors and generators. You will learn how to implement speed control, design starting mechanisms, and integrate Variable Frequency Drives (VFDs) for modern industrial applications.
Finally, we cover Permanent Magnet Synchronous Motors (PMSM) and conduct comprehensive transformer simulations (1-phase and 3-phase), calculating efficiency, tracking losses, evaluating voltage regulation, and simulating open and short circuit tests.
Module 4 – Power Systems Analysis and Protection
This module provides you with the tools to model and analyze power systems. You will begin with the modeling and design of transmission lines, understanding how power flows across long distances.
You will then perform crucial load flow analysis to ensure system stability and efficiency under various operating conditions.
Because grids are prone to disturbances, we will dive deep into symmetrical and unsymmetrical fault analysis. To protect these systems, you will learn the logic design of overcurrent relays and apply complete overcurrent protection schemes against power system faults directly within the Simulink environment.
Module 5 – Renewable Energy – Solar and Wind Simulations
In the solar energy segment, you will engage in the step-by-step modeling and design of solar panels. You will extract and plot crucial I-V and P-V characteristics, and analyze how environmental factors like irradiation and temperature impact photovoltaic (PV) cell performance.
We will also utilize the specialized MATLAB Simscape library for advanced solar simulations.
In the wind energy section, you will master the step-by-step modeling of wind turbines. You will undertake a practical project designing a 5KW wind turbine and analyze how changing various turbine parameters affects the overall mechanical and electrical power output.
Who Is This Course For?
This course is tailored for electrical engineering students seeking a practical edge, academic researchers validating their theoretical models, and practicing industry professionals looking to upgrade their simulation skills.
Enroll today to bridge the gap between theory and practice, and master the art of electrical simulation!
Course Recap
1. Power Electronics Simulations
- Simulations of 1-phase rectifiers (controlled, uncontrolled, HWR and FWR)
- Simulations of 3-phase rectifiers
- Complete Simulations of AC voltage controllers ( 1-ph & 3-ph)
- How to apply closed loop control of AC voltage controllers in MATLABl/Simulink
- Complete MATLAB simulations of DC-DC converters
- Apply PID controller to DC-DC converters in MATLAB/Simulink
- Apply Hysteresis controller to DC-DC converters in MATLAB/Simulink
- Design different DC Regulators in MATLAB/Simulink
- Simulations of 1-ph inverter circuits (half bridge and full bridge)
- Apply pulse width modulation (PWM) techniques in MATLAB/Simulink
- Simulations of 3-ph inverter circuits
2. Electrical Circuits Simulations
- Simulations of DC transient circuits
- Simulations of R-L, R-C , R-L-C circuits
- Applying forced and free response in transient circuits in Simulink
- Simulations of the Electric Resonance in MATLAB/Simulink
3. Electrical Machines Simulations
- Complete MATLAB Simulations of DC motors (shunt, series and separately excited)
- Speed control of DC motors in MATLAB/Simulink
- Starting of DC motors using starters in MATLAB/Simulink
- Simulations of DC generators
- Complete simulations of Induction motors
- Speed control and starting of induction motors in MATLAB/Simulink
- Apply VFD with induction motors in MATLAB/Simulink
- Perform different induction motor tests in MATLAB/Simulink
- Complete simulations of Induction generators
- Complete MATLAB simulations of synchronous machines
- Apply voltage and frequency control of synchronous generator in Simulink
- Simulations of synchronous generator connected with grid
- Simulation of permanent magnet synchronous motors (PMSM)
- Simulations of transformers (1-ph & 3-ph) in MATLAB/Simulink
- Efficiency, losses and voltage regulation of transformer in Simulink
- Open circuit and short circuit tests of transformers in MATLAB/Simulink
4. Power Systems Simulations
- Modelling and design of transmission lines in MATLAB/Simulink
- load flow analysis in MATLAB/Simulink
- Symmetrical and unsymmetrical fault analysis in MATLAB/Simulink
- Logic design of overcurrent relay in MATLAB/Simulink
- Apply overcurrent protection against power system faults in MATLAB/Simulink
5. Solar Energy Simulations
- Step by step modelling and design of solar panels in Simulink
- Obtain I-V and P-V characteristics of solar panel in MATLAB
- Effect of irradiation and temperature on PV cell characteristics in MATLAB
- How to simulate solar panel using MATLAB Simscape library
6. Wind Energy Simulations
- Step by step Wind turbine modelling and design in MATLAB/Simulink
- Design of 5KW wind turbine in MATLAB/Simulink
- Effect of wind turbine parameters on turbine power in MATLAB/Simulink
After purchasing the course, students can download the course-related documents and files:
Course Materials (PDF)
- AC voltage controllers material.pdf
- DC choppers material.pdf
- DC machines material.pdf
- Inverters material.pdf
- Power systems material.pdf
- Rectifiers material.pdf
- Resonance materials.pdf
- Solar energy material.pdf
- Synchronous machines material.pdf
- Transient analysis materials.pdf
- Transformers material.pdf
- Wind energy materials.pdf
Matlab Files
- Single-phase transformer Matlab files
- Three-phase transformer Matlab files
- AC choppers Matlab files
- DC chopper Matlab files
- DC machines Matlab files
- Induction machines Matlab files
- Inverters Matlab files
- Power system Matlab files
- Rectifiers Matlab files
- Resonance Matlab files
- Solar energy Matlab files
- Synchronous machines Matlab files
- Transient Matlab files
- Wind energy Matlab files
1. Course Introduction and Download Course Materials
