Ultimate Course To Electrical Drawings Design Using AutoCAD, DiaLUX and ETAP Software
Learn to design electrical drawings using AutoCAD, DiaLUX, and ETAP software, as well as to perform voltage drop calculation and short-circuit analysis. 64 lectures in 8h 5m total course length.
This course is essential for electrical power engineers who want to work in the electrical distribution field; this will guide you from zero even if you don’t know anything. You will learn to work and design electrical installations using the most common software like AutoCAD, DiaLUX, and ETAP, as well as to perform voltage drop calculation and short-circuit analysis.
The course covers the following topics:
  • All necessary tools and commands required by electrical power engineers in AutoCAD.
  • Basic definitions of lighting.
  • Different types of electrical drawing, various lighting schemes, and lighting situations.
  • Requirements for a good lighting scheme, maintenance, and utilization factors.
  • Lighting design steps.
  • Using lighting catalogs and photometric data in Dialux.
  • Manual calculation for lighting instead of Dialux.
  • Starting the interior design drawing in Dialux, by taking a factory floor, creating rooms, adding luminaries to each room, creating control groups, and adding to emergency and normal lighting scenes.
  • Using AutoCAD and connect the luminaries with wires to a lighting control panel.
  • Adding standard sockets and power sockets, and wiring to the panel.
  • Lighting panel schedule for the project.
  • Selecting circuit breakers and cables for project.
  • Calculate the voltage drop and short circuit analysis using ETAP.
  • Earthing system design.
  1. Introduction To AutoCAD
  2. Complete Electrical Design Drawing Of Distribution System
  3. Voltage Drop and Short-Circuit Analysis
  4. Earthing System Design
Electrical power engineers who want to learn about interior electrical design
Dialux and AutoCAD installed.
Downloadable course documents
  • DIAlux 4.11.0.3 Setup (EXE)
  • Power Cables Catalogue (PDF)
  • Emco Catalogue.rar
  • Industrial network protection guide (PDF)
  • Basic principles of lighting control (PDF)
  • Lighting - Illumination (PDF)
  • Manual Calculations (PDF)
  • Lift And Escalator Motor Sizing With Calculations and Examples (Study) (PDF)
  • Design Of Transformers (PDF)
  • Power Factor Correction Example (PDF)
  • AutoCAD and Dialux Lessons Slides (PPSX)
  • Apartman-Drawing (DWG)
  • Dialux Task Done (DWG)
  • Lighting Situations (PDF)
  • Circuit Breakers values (PNG)
Engr. Ahmed
I am Ahmed Mahdy an electrical power engineer, researcher, and the founder of Khadija Academy. I have helped over 100,000 students from 202 countries achieve career success through simple, easy courses over the last 10 years.​ In addition, I have a YouTube educational engineering channel called "Engr. Ahmed / Khadija Academy", where I regularly post videos related to electrical engineering. I have received the award for the best master's thesis in the Faculty of Engineering - Ain Shams University for 2022/2023. Some of my published research works in the top electrical engineering journals worldwide: 1- ​Transient stability improvement of wave energy conversion systems connected to power grid using anti-windup-coot optimization strategy - Energy Journal - Impact Factor of 9.0. 2- Nonlinear Modeling and Real-Time Simulation of a Grid-Connected AWS Wave Energy Conversion System - IEEE Transactions on Sustainable Energy - Impact Factor of 8.8. 3- Modeling and optimal operation of hybrid wave energy and PV system feeding supercharging stations based on golden jackal optimal control strategy - Energy Journal - Impact Factor of 9.​0. 4- State-of-the-Art of the most commonly adopted wave energy conversion systems - Ain Shams Engineering Journal - Impact Factor of 6.0. 5- Optimal Design of Fractional-Order PID Controllers for a Nonlinear AWS Wave Energy Converter Using Hybrid Jellyfish Search and Particle Swarm Optimization - Fractal and Fractional - Impact Factor of 5.4 6- Dynamic performance enhancement of nonlinear AWS wave energy systems based on optimal super-twisting control strategy - Ain Shams Engineering Journal - Impact Factor of 6.0. 7- A novel maximum energy extraction strategy using lithium-ion batteries for Archimedes wave swing wave energy conversion systems - Renewable Energy - Impact Factor of 9.1
17 Courses
+180 enrolled
  • 6 Lessons
  • 60 Topics
